اسطوانة ... Symantic Norton 2008 Golden Edition-aio ... للمهندسيين
النتائج 1 إلى 3 من 3
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    SYMANTIC NORTON 2008 GOLDEN EDITION-AIO
    Windows OS | Size: 490 Mb
    المجموعة الكاملة لحماية الجهاز والمتنوعة من شركة SYMANTIC
    norton 360 all in one v2
    norton internet security 2008
    norton antivirus 2008
    norton save &restore v2
    norton ghost v 14
    norton antibot v2
    INSTALLATION INSTRUCTIONS
    1. Unrar, Burn or mount with Daemon Tools.
    2. DISCONNECT FROM THE INTERNET! THIS IS IMPORTANT!
    3. Run the installer, and run the keygen located in the EDGE dir.
    4. Select your product then generate and copy the Product Key from
    the keygen to the Norton Setup then press the I Agree button..
    5. Complete installation and finally you will get to the activation,
    it's important that you are NOT connected to the Internet!
    Press the Next button.
    6. You will get to a screen that tells you that you will need Internet
    connectivity to continue, just press the Next Button two times until
    Internet Explorer opens and tells you "Internet Explorer cannot
    display the webpage"
    7. Now copy the entire long URL from Internet Explorer into the keygen
    in the Request URL field, select how many years you would like to
    activate for and press the bottom most generate button.
    8. Wait a few secs, magic is happening, then you will again be told
    that you need Internet connectivity to create your Norton Account,
    just press the Skip button.
    9. Make a big smile as you see your subscription status
    10. Enjoy a fully unlocked copy, and naturally DO NOT register this
    software with Symantec, you can now reconnect to the Internet.
    this is a DVD image ( RARs when extracted = 891MB )
    also the SplashScreen needs your display to be set at
    1280x1024 minimum resolution to see the all selections.
    ابو نضال
    ابو نضال غير متواجد حالياً
    الصورة الرمزية ابو نضال
    zahran2009
    zahran2009 غير متواجد حالياً
    شكرا على الاسطوانة
    الاسطوانة جامدة والمفاتيح شغالة بس لازم تعمل اكتف على النت يعنى شغالة لمدة 15 يوم بس
