لماذا لا يتم عمل القواعد الدائرية للاعمدة الدائرية(موضوع للمناقشة )
النتائج 1 إلى 3 من 3
    الصورة الرمزية step6
    step6
    step6 غير متواجد حالياً
    Received: 38
    ريان خرسان
    ريان خرسان غير متواجد حالياً
    En Fait Par Ce Que Les Semelles Travaillent Au Systeme Des Bielles Donc Avoir Des Semelles Conique C Plus Efficace Mais On Aure Plus De Plus De Problemes Lors Du Coffrage C Est Pour Ce La On Utilise Des Semelle De Forme Cubique
    mekkawi
    mekkawi غير متواجد حالياً
    You do not need acircular footing because you supposidly know iwhere your maximum soil pressure is going to be and the additional cost of forming a circular footing and the design of radial reabr. You do consider circular footing in towers and stacks where your wind load can act in any direction and hence, your maximum soil pressure can occure at any point or about any axis. most designers uise octagonal footing instead of circular footing to facilitate rebar layout. actual differences between true circular anf octagonal shapes were found to be minimal.
