برنامج لإختيار طول وقطر المواسير الشعرية [Capillary Tube Selection]
النتائج 1 إلى 10 من 29
    الصورة الرمزية meshomat
    meshomat
    meshomat غير متواجد حالياً
    مرحباً بكم فى
    هو برنامج تابع لشركـــــــة دانفوس
    هذا البرنامج لحساب طول وقطر المواسير الشعرية
    برنامج لإختيار المواسير الشعرية [Capillary Tube Selection]
    شرح مبسط للبرنامج
    لضبط الوحدات بالبرنامج حسب النظام الذى تعمل عليه
    Introduction
    This software allows the user to calculate a capillary tube throttling device for a refrigeration system based on empirical formulas.
    The result is a start value for optimization, this start value
    typically giving a functioning system.
    In certain cases the best possible choice of capillary diameter and length might deviate remarkably from this calculated result.
    The capillary sizing is based on the assumption, that
    - the suction line is connected to the capillary tube in most of its length for internal heat exchange - no or little subcooling appears in continuous operation
    The refrigerant used is to be chosen from a list.
    Input values should be representative dimensioning
    values for the refrigeration system.
    The input value for - capacity is to be taken for the also to be input operating conditions, in terms of - evaporating temperature - condensing temperature - return gas temperature and- without subcooling for the compressor type used, preferably.
    The input data are limited per refrigerant according to
    experience and compressor application areas.
    Data like these could be according to data sheet performance data at ARI 540, EN 12900 or CECOMAF conditions, or taken from a software selection tool like Danfoss RS™.
    The list of capillary tube inner diameters does contain typically available sizes from different countries. They will not all be available at one place.
    A length value for an available diameter size is to be chosen by the user, or guessed, if not listed.
    The list of refrigerants and capillary tube diameters and the calculation formulas and limits might be altered at updates, based on new experience
    System requirements-
    Min. 200 MHz Pentium® or compatible
    32 MB RAM min., 64 MB recommended
    15 MB harddisk space
    Microsoft Windows 95®, 98, ME, XP, NT 4.0, 2000 or newer
    لم يتبقى إلا تحميل البرنامج
    هذا وبالله التوفيق والحمد لله رب العالمين
    لاتنسونى من صالح دعائكم
    م/سليمان333
    م/سليمان333 غير متواجد حالياً
    الف شكر يا ريس
    برنامج رائع ولكن للاسف محدد الى قدرة 34000 وحدة بس مشكووووووووووووووو
    meshomat
    اقتباس المشاركة الأصلية كتبت بواسطة م/سليمان333 مشاهدة المشاركة
    الف شكر يا ريس
    صحيح كلامك بابشمهندس وبالتوفيق لكـ وإن شاء الله يكون فى برامج أحسن نضعها بالمنتدى لإفادة مهندسى التبريد والتكييف هذا وبالله التوفيق
    سيأتى الضياءُ برغم الغيوم
    وتشدو الطيور بذاك القدوم
    ونمضى سوياً على دربنا
    وفى كفنا شعلة من علوم
    Eng. Mahmoud Shuman
    نور محمد علي
    نور محمد علي غير متواجد حالياً
    الصورة الرمزية نور محمد علي
    بارك الله فيك واتمنى من الجميع عندما يرفعو برنامج ما ان يرفعو معه الشرح
    000403
    000403 غير متواجد حالياً
    الصورة الرمزية 000403
    مشكوووووووووووووووووووووور
    ©§¤°يسلموو°¤§©¤ــ¤©§¤°حلوو°¤§©
    ©§¤°يسلموو°¤§©¤ـــــــــــــ¤©§¤°حلوو°¤§©
    ©§¤°يسلموو°¤§©¤ـــــــــــــــــــــ¤©§¤°حلووو و°¤§ ©
    ©§¤°يسلموو°¤§©¤ـــــــــــــــــــــــــــــــ ــ¤© §¤°حلوووو°¤§©
    ©§¤°يسلموو°¤§©¤ـــــــــــــــــــــــــــــــ ــــ ــــــــ ¤©§¤°حلوووو°¤§©
    ©§¤°يسلموو°¤§©¤ـــــــــــــــــــــــــــــــ ــــ ـــــــــــــــــــــ¤©§¤°حلوووو°¤§©
    ©§¤°يسلموو°¤§©¤ـــــــــــــــــــــــــــــــ ــــ ـــــــــــــــــــــــــــــــــ¤©§¤°حلوووو° ¤§©
    ©§¤°يسلموو°¤§©¤ـــــــــــــــــــــــــــــــ ــــ ــــــــــــــــــــــــــــــــــــــــــ¤©§ ¤°حلو ووو°¤§©
    ©§¤°يسلموو°¤§©¤ـــــــــــــــــــــ رائع جدا جدا جدا جدا ــــــــــــــــــــــ¤©§¤°حلو ووو°¤§©
    ©§¤°يسلموو°¤§©¤ـــــــــ يعطيك العافية والمزيد من الابداع--- ــــــــ¤©§¤°حلو ووو°¤§©
    ©§¤°يسلموو°¤§©¤ـــــــــــــــــــــــــــــــ ــــــــــــــــــــــــ¤©§¤°حلو ووو°¤§©
    ©§¤°يسلموو°¤§©¤ـــــــــــــــــــــــــــــــ ــــ ــــــــــــــــــــــــــــــــــــــــــــ¤ ©§¤°ح لو ووو°¤§©
    ©§¤°يسلموو°¤§©¤ـــــــــــــــــــــــــــــــ ــــ ـــــــــــــــــــــــــــــــــــــــــ¤©§¤ °حلو ووو°¤§©
    مقاطــع خماسية الدقائق
    ثمرة الايمان والصبر
    http://www.islamup.com/download.php?id=73443
    والمتوكـئون في الجنة قلـيل
    http://www.islamup.com/download.php?id=90642
    يا دين محمد اذا دكدك الله الارض
    http://www.factway.net/vb/uploaded/5735_01276694412.mp3
    الحمـو المـوت
    http://www.factway.net/vb/uploaded/5735_01279358773.rar
    مقطع مؤثر
    http://www.islamup.com/download.php?id=84860
    000403
    ياريت تعطينا كيفية عمل البرنامج
    بمعني كيف يمكنني اخد درجات الحرارة والوحدة لم يتم تشغيلها لعدم معرفة قطر الانبوبة الشعرية
    ومن ناحية اخري ان درجات الحرارة تختلف من وقت لاخر
    وبالنسبة .....Heat laod هل المقصود به cooling capacity
    بالفعل مشاركة طيبة وبرنامج جدا رائع ... فقط نحتاج الي الكثير من التوضيح لي ولغيري
    وبارك الله فيك
    ثمرة الايمان والصبر
    الحمـو المـوت
    مقطع مؤثر
    noorsadaqa
    noorsadaqa غير متواجد حالياً
    مشكور جدا على البرنامج زماااااااااااااان بور على هاد البرنامج واتخيل اكون مندب مبيعات وما اكون اعرف احدد طول منتج لازم اسوقه
    midofm
    midofm غير متواجد حالياً
    حياكم الله وجزاكم الله خيرا ورفع من قدركم
    عبدالباسط ابراهيم
    عبدالباسط ابراهيم غير متواجد حالياً
    شكرا على هذه المعلومات القيمة
    benyagoub
    benyagoub غير متواجد حالياً
    شكرا للبرنامج بما انني لم اعرف تشغيله
