ICF Middle East نظام بناء حديث
النتائج 11 إلى 20 من 29
    مهندس سابا
    مهندس سابا غير متواجد حالياً
    Thumbs up JIDAR ICF Middle East
    What is an ICF ?
    Jidar is an Insulated Concrete Form (ICF) consisting of 2 panels of expanded polystyrene (EPS) married with high impact polystyrene inserts used to hold patented webs/spacers designed to secure rebar as needed.
    Once stacked together, these forms represent a mold ready for concrete placement, similar to a traditionally poured concrete wall; however,
    ICF forms never leave the concrete providing a multitude of tasks:
    1. Structural Support: (Concrete & Steel)
    2. Super Insulation: (EPS panels & Thermal Mass, 40+ R- Performance)
    3. Strapping/Furring: (1 5/8" Spacers at 8" on center)
    4. Air/Vapor Barrier: (Low permeate EPS in continuous contact with concrete)
    5. Finishing Substrate: (Single material EPS Type II)
    All in 1 step, with 1 crew/contractor, in less time.
    ICF Benefits
    What are the major benefits in using an ICF?
    1. Energy Efficiency
    With the combination of a solid concrete core in full contact with an interior and exterior insulation panel, a super energy efficient wall is created protecting the indoor air temperature. A “heat sink” is created from the thermal mass of the concrete which is now very difficult to penetrate. The total wall system is greater than the sum of its parts, reducing air leakage and increasing the “R” Performance to 40+. Owners enjoy energy savings up to 70%.
    2. Safe
    An ICF wall is also a superior structural combination of concrete and steel. When compared to stick framed buildings, an ICF wall offers greater protection from high winds in hurricane and tornado areas and from the often dangerous projectiles hurled during these storms. The strong “bond beams” created within the walls from the steel rebar protect in earthquake and mudslide prone areas stabilizing the structure when the ground has shifted or fallen.
    3. Quiet
    ICF walls provide an STC rating of 50 or greater when combined with other sound reduction materials. This creates a quiet environment from external noise in high traffic areas, high wind areas or other noisy neighborhoods dealing with trains, airports, etc. Conversely, ICF walls also offer sound protection from within, as is necessary in music and sound studios.
    4. Healthy
    One of the great concerns in older homes today is mold and mildew found growing behind drywall, in the attic and in basements. ICF walls eliminate the moisture commonly experienced seeping through concrete block or conventional poured concrete walls and condensation commonly found in stick framed homes. Expanded Polystyrene is a safe material without glues and does not off-gas Volatile Organic Compounds (VOC) commonly found in material such as form oil release agents, plywood and chip board. Persons suffering from such allergies can feel relief.
    5. Fast & Reliable
    When using an ICF, you are getting 5 steps in one; structural superior walls, super insulation, strapping/studs, air and moisture barrier, completed professionally. This replaces concrete block, conventional poured concrete, stick framing, exterior sheathing, house wrap, plastic wrap and insulation. Depend on one crew including a certified contractor to quickly perform all these tasks in one step. For your peace of mind, JIDAR demands that any installation of their product include supervision by a certified installer.
    Jidar.biz
    best wishes for all of you
    الصور المرفقة
    مهندس سابا
    لا تعليق ؟؟؟
    راسم النعيمي
    راسم النعيمي غير متواجد حالياً
    الصورة الرمزية راسم النعيمي
    اذا كان بالامكان تحديد الكلفة الحالية بالنسبة للمتر المربع الواحد بناء في الاردن مثلا بالدينار الاردني او الدولار الامريكي وكيفية استخدام هذه الطريقة في بلد ثاني من حيث النقل والعمالة في البلدان المجاورة كالعراق مثلا اي هل بالامكان فتح فرع للشركة او عن طريق اخر .............مع الشكر والتقدير
    النعيـ ع ح ـــمي
    مهندس سابا
    الاخ الفاضل راسم النعيمي
    بعد التحية والسلام .....
    ان النظام بسيط جدا ومرن بالنسبة لموضوع التعامل معه حيث انك تستطيع الذهاب بفكرك الى موضوع
    العاب الليجو الخاصة بالاطفال وتطبيقيها على النظام لكن الفرق الوحيد ان العاب الليجو مغلقة والنظام مفرغ من الهواء
    من الداخل حتى يتسنى صب الخرسانة بداخله
    من حيث الزاويا والكيرفات فبكل بساطه يمكنك ان تتعامل معاها حتى يتسنى لك عمل الديكورات التي تحتاجها
    كل ما هو مطلوب فكر جديد يستوعب نظام جديد مرن بسيط
    بالنسبة للعراق فأنه يوجد مجمع لأدارة العقود العراقية حديث سوف يتم تنفيذه بواسطة هذا النظام
    من خلال شركة عراقية وشركة جدار لتكنولوجيا البناء
    بالنسبة لسعر البناء بواسطة هذا النظام فان المتر المربع تسليم مفتاح تشطيب عادي تقريبا يكلف
    بحدود الثلاثمائة دينار
    بالنسبة لموضوع النقل لكافة الدول المجاورة فهو متوفر مع امكانية تدريب الكوادر الفنية لتأهيلها للعمل
    بهذا النظام خلال فترة زمينة بسيطة جدا
    في حالة يوجد اي استفسار اخر ارجو التفضل بذكره
    تقبلوا خالص تحياتي
    مهندس سابا
    مبروك عليكم شهر رمضان
    تقبلوا تحياتي
    راسم النعيمي
    بارك الله فيك وجزاك كل خير ورمضان كريم وكل عام وانتم بخير اشكرك على سعة صدرك واجابتك وان شاء الله ننتظر الشركه بالعراق علما بان الكلفة مقاربه للبناء العادي في العراق والسلام عليكم شكرا جزيلا مرة ثانية
    النعيـ ع ح ـــمي
    مهندس سابا
    اخي راسم النعيمي بعد التحية والسلام
    اشكر تواصلك بهذا الموضوع معلوماتي تقول ان سعر متر البناء بالعراق اكثر بكثير من هذا
    الرقم الذي ذكرته سابقا وعلى كل حال هذا ليس موضوع النقاش حتى في حالى تساوت الارقام
    فانظر الى موضوع توفير الطاقة للتبريد والتدفئة اليس جديرا بنا النظر الى هذه النقطة الاساسية للنظام
    احصائياتي تقول انك تحتاج لما مساحته مائة متر مربع ما يعادل خمسة اطنان فما فوق وحدات تبريد وتكييف
    في نظام البناء العادي التقليدي
    اما في هذا النظام فانك تحتاج فقط الى طن ونص لكل مائة متر مربع
    هنالك فرق كبير وواضح بالنسبة لموضوع توفير الطاقة تأمل جيدا يرعاك الله
    وكل رمضان والجميع بالف الف خير
    مهندس سابا
    back to see if there are any new comment
    best wishes
    مهندس سابا
    جدار لتكنولوجيا البناء jidar building technology
    قامت شركة جدار لتكنولوجيا البناء بالانتهاء من تسجيل شركتها
    لتباشر فورا البدء بتطبيق نظام البناء بواسطة الجدران الحاملة المعزولة
    Insulated Concrete Forms ICF
    لتغطي بذلك منطقة الشرق الاوسط من خلال مكتبها الكائن بالمملكة
    الاردنية الهاشمية
    حيث تم مباشرة توقيع عقد انشاء مبنى ادارة العقود العراقية الجديد
    داخل العراق بواسطة هذا النظام كمقدمة للعديد من المجمعات السكنية
    المراد انشائها بواسطة نظام البناء بواسطة الجدران الحاملة المعزولة
    تقبلوا خالص تحياتي
    الصور المرفقة
    مهندس سابا
    ترقبوا جديد الموضوع والنظام بأذن الله تعالى
    تقبلوا خالص تحياتي
