r o
النتائج 1 إلى 6 من 6
    الصورة الرمزية عبد الله الغيلاني
    عبد الله الغيلاني
    عبد الله الغيلاني غير متواجد حالياً
    r o
    أرجو إفادتي في الفرق بين قياس conductivity ما هو وبين قياس TDS
    أليس القياسان يخصا درجة الملوحة وشكرا
    صبرى ابوعجيلة
    صبرى ابوعجيلة غير متواجد حالياً
    1ppm = 1.56 micro simes /sec cm
    محمد عبد اللطيف عب
    محمد عبد اللطيف عب غير متواجد حالياً
    µS/cm x 0.5 = mg/l of TDS
    هذا هو التحويل الصحيح و اعتقد ان التحويل السابق خاطئ
    صبرى ابوعجيلة
    the electric conductivity (EC) of a water is a measure of the ability of a solution to conduct an electrical current. because the electrical current is transported by the ion in solution, the conductivity increases as the concentration of ions increases. in effect, the measured EC value is used as a surrogate measure of total dissolved solids (TDS) concentration. at present , the EC of a water is one of the important parameters used to determine the suitability of a water for irrigation. the salinity of treated wastewater to be used for irrigation is estimated by measuring its electrical conductivity.
    the electrical conductivity in SI units is expressed as millisiemens per meter mS/m and in microomhos per centimeter micromho/cm in U.S. customary units. it should be noted that 1 mS/m is equivalent to 10 micromho/cm . equation *** can be used to estimate the TDS of a water sample based on the measured EC value
    Tds (mg/L) = EC (ds /m or MICRO mho /cm)* (0.55-0.7) **************
    the above relationship does not necessarily apply to raw wastewater or high- strength industrial wastewater. the above relationship can also be used to check the accepatability of chemical analysis.
    the electric conductivity can be used to estimate the ionic strength of a solution using the following relationship
    I= 1.6*10e-5* EC (dS / m or Micro mho/cm )
    equation ************** is used to estimate the ionic strength of treated wastewater in groundwater recharge application.
    صبرى ابوعجيلة
    the previous explaine has taken from wastewater treatment and reuse, fourth edition by eddy, 2003.
    عبد الله الغيلاني
    شكر يا شباب بارك الله فيكم
    شكر يا شباب بارك الله فيكم و نفع الله بكم البشرية و دمتم في رعاية الله و الى الامام .....
س, r
