نظام بناء حديث غير مستخدم بالشرق الأوسط
صفحة 8 من 14 الأولىالأولى ... 4 5 6 7 89 10 11 12 ... الأخيرةالأخيرة
النتائج 71 إلى 80 من 132
  1. [71]
    اشرف العراقي
    اشرف العراقي غير متواجد حالياً
    الصورة الرمزية اشرف العراقي
    شكرا جزيلا
  2. [72]
    مهندس سابا
    مهندس سابا غير متواجد حالياً
    الاخ اشرف العراقي
    جزيل الشكر على مرورك
    جدار لتكنولوجيا البناء
  3. [73]
    م.ضياء علاء
    م.ضياء علاء غير متواجد حالياً
    الصورة الرمزية م.ضياء علاء
    Dear Eng saba
    I am a civil engineer working and living in Canada , the system you are recommending is a good system however there is a better insulation wall system in which non-bearing wall system is adapted
    the system is Exterior Insulation Finishing System often called "synthetic
    stucco",
    widely used in Canada and US
  4. [74]
    م.ضياء علاء
    EIFS consists of a number of layers that are installed in the following order. The most basic EIFS (a barrier EIFS) consists of 3 layers:
    A layer of foam plastic insulation (also called simply "foam") that comes in the form of sheets 2' x 4'. If an adhesive is used to attach the insulation, the adhesive is applied to the foam with a trowel. Most EIFS use a type of insulation called Expanded Polystyrene, also known as EPS. EPS is 1 lb. density Expanded Polystyrene, similar to the white foam that coffee cups are made of. The usual range of thickness for EIFS insulation is 3/4" to 4", although thicker pieces are sometimes used for decoration accents - called foam shapes.
    A reinforced layer that is applied onto the face of the insulation with a trowel, consisting of a fiberglass reinforcing mesh ( or "mesh") embedded in a cementitous adhesive. The mesh has an open weave, somewhat like window screening but with opening about 1/4" square. It is made of fiberglass and can be cut with a utility knife. The mesh is available in various weights, the "heaviness" determines the impact strength of the surface (resistance to damage by being "hit"). The standard weight is 4oz, the high-impact mesh weight goes up to 15 or 20oz. This 2-part layer is called the Base Coat.
    A final topcoat,or finish, which is a colored, textured paint-like material that is applied with a trowel or, very rarely, by spraying. A wide range of colors and textures are available as well as custom colors. Available textures include smooth surfaces, rough "stucco-like" textures, embedded stone chips, multi-color (granite-like mixtures,) and even brick-like treatments. This layer is called the finish. It is acquired by floating.
  5. [75]
    م.ضياء علاء
    If you need more information ,I will help
    I am Jordanian Canadian ,I graduated from J.U.S.T
    ALA ABU OBEID ,BSc.Eng,Professional Engineer
  6. [76]
    مهندس سابا
    ICFs Middle East جدار لتكنولوجيا البناء
    نظام بناء حديث غير مستخدم بالشرق الاوسط
    البناء بواسطة الجدران الخراسانية المسلحه الحاملة المعزولة
    ICFs Insulted Concrete Forms
    1- صورة مبنى متعدد الطوابق تم الانتهاء من تنفيذه بواسطة هذا النظام
    http://www.uparab.com/files/G74-nhWBv3R4gwVh.bmp
    2- صورة تشطيبات لأحد المباني التي تم الانتهاء من تنفيذها بواسطة هذا النظام
    http://www.uparab.com/files/H9Yhmp4vr1yxkFFP.jpg
    3- تشطيبات ايضا لاحد المباني
    http://www.uparab.com/files/Zh3J4QiD0x4oPDGM.jpg
    4- ملف فيدو يظهر سرعة العمل بهذا النظام
    http://www.uparab.com/files/QxvWSq3SeyrLYqdR.wmv
    5- الكورس الأول في البناء بواسطة هذا النظام الحديث للشرق الاوسط
    http://www.uparab.com/files/ziD63S9N-X8ZnHm8.rar
    لمزيد من المعلومات الهندسية والفنية يرجى التفضل بالدخول الى محرك جوجل وكتابة
    او
    ICF Middle East
    مرفق أيضا ملف لبناية مكونة من ستة طوابق فوق الأرض
    تم الانتهاء من تنفيذها خلال اربعة أشهر مكونه من ثلاثمائة وعشرون غرفة
    أرجو ان تنال إعجابكم
  7. [77]
    مهندس سابا
    thanks alot
    اقتباس المشاركة الأصلية كتبت بواسطة diyaala2003 مشاهدة المشاركة
    can u send ur e mail pm
    thx, regards
  8. [78]
    مهندس سابا
    i will visit ountario soon to take course for ICFs buildings
  9. [79]
    مهندس سابا
    في حالة لم تعمل الروابط السابقة فتفضلوا هذه روابط جديده على موقع اخر
    للملفات التي تستطيعون التعرف اكثر واكثر على النظام
    وتشاهدون كيف تستطيع ان تبدأ البناء بواسطة هذا النظام الحديث
    سواء بيوت او فلل او بنايات او مسابح ومسطحات مائية
    http://www.gulfup.com/dldeCG06692.rar.html
    http://www.gulfup.com/dld5Sq06691.rar.html
    http://www.gulfup.com/dldMpj06691.rar.html
    المدير التنفيذي
  10. [80]
    م.ضياء علاء
    MY e-mail is ×××××××××××××××× and if you are visiting Ontario,Canada I can meet you thanks
    يمنع وضع أي وسيلة من وسائل الاتصال الخاصة ضمن المشاركات..
    مع تحيــــــــــــــاتي.. أبو الحلول
