who have experience in high chloride and TDS ??
النتائج 1 إلى 4 من 4
    نهاية المالانهاية
    نهاية المالانهاية غير متواجد حالياً
    i work in a petrol refinery .. in utility area.. ..
    in these days we are facing problem in desalination unit ,so the water we r using is not enough for process which forced us to use goverment water , but goverment water is having high TDS and high chloride in the boilers even if we keep the intermediate blow down crack open whole the day..
    so please could an experience people help me in this problem??
    and i ll be thnx full for them
    من مواضيع نهاية المالانهاية :
    نهاية المالانهاية
    no body can help me ?!!
    en_shaabi
    en_shaabi غير متواجد حالياً
    TDS & Chloride
    Would you please give us the amount of the TDS that you have it from the Goverment water , and the amount of the TDS from ur desalination process and what the Amount of the TDS you need to use in ur boiler??......and the amount of the chloride too.
    Are you using a preteatment for the boiler???
    Are you using chemicals to treat the boiler???
    معتصم الوطن
    معتصم الوطن غير متواجد حالياً
    U can use activated carbon and softener to remove chlorid and salts
