وقود الطائرات Emergency Fuel Dump
النتائج 1 إلى 10 من 10
    الصورة الرمزية Eng-Maher
    Eng-Maher
    Eng-Maher غير متواجد حالياً
    مشرف قسم الهندسة البحرية.
    Received: 103
    Given: 408
    Emergency Fuel Dump
    The reason planes are equipped to release fuel in flight is in case of an emergency landing shortly after takeoff. Landing gear and the structure of most aircraft are only designed to absorb the impact of landing up to a certain weight. When fully loaded with fuel, most planes are simply too heavy to land safely without risking a landing gear collapse or other disastrous structural failure. Planes are therefore fitted with emergency fuel dump systems that release enough fuel to lighten the aircraft until they can land safely. You may also recall Harrison Ford fooling with the fuel release system in the movie Air Force One with nothing more than a butter knife, but this was clearly for different reasons!
    - answer by Jeff Scott, 25 November 2001
    Related Topics:
    When a plane dumps fuel, where does the fuel go? Does it land on my car or in somebody's swimming pool? Does it evaporate? Or does it mess up the ozone layer even more than it already is?
    Did the JetBlue Airbus A320 that had to make an emergency landing because of a landing gear problem have the ability to eject fuel in flight? If so, why did they fly around for three hours?
    الرابط
    http://www.aerospaceweb.org/question...s/q0054a.shtml
    Eng-Maher
    Received: 103
    Given: 408
    الحمد لله
    Eng-Maher
    Received: 103
    Given: 408
    معلومات بسيطه عن
    FUEL CELL TODAY
    Opening doors to fuel cell commercialisation
    http://www.fuelcelltoday.com/media/p...l%20Planes.pdf
    الحمد لله
    م المصري
    م المصري غير متواجد حالياً
    Received: 16
    سلمت يداك مشرفنا القدير
    و اهلا بقسم البحريه ها هنا
    لا اله الا الله محمد رسول الله
    تفضل , هنا تقرأ القرآن
    الأمواج الرقمية
    الأمواج الرقمية غير متواجد حالياً
    شكراً عزيزي ...
    Eng-Maher
    Received: 103
    Given: 408
    اقتباس المشاركة الأصلية كتبت بواسطة م المصري مشاهدة المشاركة
    وسلمت انت اخى العزيز ( المصرى ) وبعدين دى حاجه بسيطه من اهتمامك بقسمنا ايضا
    نورت اخى الفاضل
    الحمد لله
    Eng-Maher
    Received: 103
    Given: 408
    اقتباس المشاركة الأصلية كتبت بواسطة الأمواج الرقمية مشاهدة المشاركة
    شكراً عزيزي ...
    نورت اخى الفاضل وشكرا
    الحمد لله
    Eng-Maher
    Received: 103
    Given: 408
    يرفع للافاده
    الحمد لله
    emad35
    emad35 غير متواجد حالياً
    بارك الله بك
    mostafa.b
    mostafa.b غير متواجد حالياً
    رد: وقود الطائرات Emergency Fuel Dump
    بارك الله فييك
