Micro-Tunneling
النتائج 1 إلى 7 من 7
    الصورة الرمزية مهندس مصطفى
    مهندس مصطفى
    مهندس مصطفى غير متواجد حالياً
    Received: 9
    مهندس مصطفى
    Received: 9
    تقريبا هذا مجال لم تسمعوا عنه!!!!
    samersss
    samersss غير متواجد حالياً
    الصورة الرمزية samersss
    Received: 20
    هلا بك اخ مصطفى
    هل بحثت في مكتبة الكتب الهندسية ؟
    ستجد هناك كل ما يتعلق بالكتب
    مع تحياتي
    سامر
    رزق حجاوي غير متواجد حالياً
    الصورة الرمزية رزق حجاوي
    Received: 4,985
    Given: 1,442
    اقتباس المشاركة الأصلية كتبت بواسطة مهندس مصطفى مشاهدة المشاركة
    أريد أى كتب أو مواد تتعلق بمجال الأنفاق Micro-Tunneling
    المقصود هو microtunneling=Micro -Tunneling
    Microtunneling
    is a process that uses a remotely controlled Microtunnel Boring Machine (MTBM) combined with the pipe jacking technique to directly install product pipelines underground in a single pass. This process avoids the need to have long stretches of open trench for pipe laying, which causes extreme disruption to the community. In the U.S., microtunneling has been used to install pipe from twelve inches to twelve feet in diameter. Therefore, the definition for microtunneling in the U.S. does not necessarily include size. Microtunneling has evolved in the US to describe a tunneling process where the workforce does not routinely work in the tunnel. Microtunneling is currently the most accurate pipeline installation method. Line and grade tolerances of one inch are the microtunneling industry standard. This can be extremely important when trying to install a new pipeline in an area where a maze of underground utility lines already exists.
    Microtunneling was developed by the Japanese in the early 1970’s to replace open sewers in urban areas with underground gravity sewers. The first microtunneling project in the U.S. occurred in south Florida in 1984.This was a 600 foot crossing with 72" pipe under I 95 and the FEC Railroad. Although originally designed for gravity sewer construction, microtunneling installations include underground crossings of highways, railroads, runways, rivers, and environmentally sensitive areas for a variety of utilities. This process has also been used to install plant intakes and outfalls. Microtunneling is also used in the pipe arch technique of supporting large underground openings with an arch or roof made up of
    small
    ولمزيد من المعلومات يمكنك عمل بحث في الانترنت للموضوع وستجد العديد من الابحاث في هذا الموضوع.
    مهندس مصطفى
    Received: 9
    أهلا بالأخوة الكرام شكرا للرد
    و أنا أعمل بمشروع به ميكرو تنل حاليا و كنت اريد مراجع فى المجال وليس تعريف فأنا عند مرحلة أعلى من ذلك الحمد لله
    Received: 4,985
    Given: 1,442
    اتمنى بعد ان تنتهي من مشروعك ان تفيدنا من علمك.
    المشاركات والردود في هذا المنتدى لا تخص شخص بعينه فالنسبة لي لم اسمع في حياتي Micro -Tunnelingولحب المعرفة دخلت البحث في الانترنت ووجدت ان الاسم الصحيح لها هو microtunneling وحتى يستفيد غيري ويعرف معنى هذا المصطلح كتبت التعريف( وهو بالاختصار عمل انفاق تحت الشوارع او الابنية في انفاق ذات قطر صغير نسبيا لمرور الخدمات من انابيب مياه او صرف صحي او كوابل ) وفي النهاية وضعت عبارة لمن يريد المزيد يمكنه اجراء البحث وهو سهل جدا والكل يعلمه وقد وجدت العشرات من الابحاث في هذا الموضوع وانا مع مبدأ الحكمة الصينية ( لا تعطه سمكا بل علمه كيف يصطاد السمك )
    وستجد في البحث عن الاجهزة المستعمله وطريقة العمل
    مع تحياتي للجميع
    م.رزق حجاوي
    مهندس مصطفى
    Received: 9
    جازاك الله خيرا
