إختصارات لوحة المفاتيح لتفعيل أوامر AutoCAD
النتائج 1 إلى 7 من 7
    الصورة الرمزية إسلام علي
    إسلام علي
    إسلام علي غير متواجد حالياً
    Received: 1,093
    Given: 2,479
    These examples include most frequently used commands.
    Shourt command
    3A 3DARRAY
    3DO 3DORBIT
    3F 3DFACE
    3P 3DPOLY
    A ARC
    ADC ADCENTER
    AA AREA
    AL ALIGN
    AP APPLOAD
    AR ARRAY
    ATT ATTDEF
    -ATT -ATTDEF
    ATE ATTEDIT
    -ATE -ATTEDIT
    ATTE -ATTEDIT
    B BLOCK
    -B -BLOCK
    BH BHATCH
    BO BOUNDARY
    -BO -BOUNDARY
    BR BREAK
    C CIRCLE
    CH PROPERTIES
    -CH CHANGE
    CHA CHAMFER
    COL COLOR
    COLOUR COLOR
    CO COPY
    D DIMSTYLE
    DAL DIMALIGNED
    DAN DIMANGULAR
    DBA DIMBASELINE
    DBC DBCONNECT
    DCE DIMCENTER
    DCO DIMCONTINUE
    DDI DIMDIAMETER
    DED DIMEDIT
    DI DIST
    DIV DIVIDE
    DLI DIMLINEAR
    DO DONUT
    DOR DIMORDINATE
    DOV DIMOVERRIDE
    DR DRAWORDER
    DRA DIMRADIUS
    DS DSETTINGS
    DST DIMSTYLE
    DT DTEXT
    DV DVIEW
    E ERASE
    ED DDEDIT
    EL ELLIPSE
    EX EXTEND
    EXIT QUIT
    EXP EXPORT
    EXT EXTRUDE
    F FILLET
    FI FILTER
    G GROUP
    -G -GROUP
    GR DDGRIPS
    H BHATCH
    -H HATCH
    HE HATCHEDIT
    HI HIDE
    I INSERT
    -I -INSERT
    IAD IMAGEADJUST
    IAT IMAGEATTACH
    ICL IMAGECLIP
    IM IMAGE
    -IM -IMAGE
    IMP IMPORT
    IN INTERSECT
    INF INTERFERE
    IO INSERTOBJ
    L LINE
    LA LAYER
    -LA -LAYER
    LE QLEADER
    LEN LENGTHEN
    LI LIST
    LINEWEIGHT LWEIGHT
    LO -LAYOUT
    LS LIST
    LT LINETYPE
    -LT -LINETYPE
    LTYPE LINETYPE
    -LTYPE -LINETYPE
    LTS LTSCALE
    LW LWEIGHT
    M MOVE
    MA MATCHPROP
    ME MEASURE
    MI MIRROR
    ML MLINE
    MO PROPERTIES
    MS MSPACE
    MT MTEXT
    MV MVIEW
    O OFFSET
    OP OPTIONS
    ORBIT 3DORBIT
    OS OSNAP
    -OS -OSNAP
    P PAN
    -P -PAN
    PA PASTESPEC
    PARTIALOPEN -PARTIALOPEN
    PE PEDIT
    PL PLINE
    PO POINT
    POL POLYGON
    PR OPTIONS
    PRCLOSE PROPERTIESCLOSE
    PROPS PROPERTIES
    PRE PREVIEW
    PRINT PLOT
    PS PSPACE
    PU PURGE
    R REDRAW
    RA REDRAWALL
    RE REGEN
    REA REGENALL
    REC RECTANGLE
    REG REGION
    REN RENAME
    -REN -RENAME
    REV REVOLVE
    RM DDRMODES
    RO ROTATE
    RPR RPREF
    RR RENDER
    S STRETCH
    SC SCALE
    SCR SCRIPT
    SE DSETTINGS
    SEC SECTION
    SET SETVAR
    SHA SHADE
    SL SLICE
    SN SNAP
    SO SOLID
    SP SPELL
    SPL SPLINE
    SPE SPLINEDIT
    ST STYLE
    SU SUBTRACT
    T MTEXT
    -T -MTEXT
    TA TABLET
    TH THICKNESS
    TI TILEMODE
    TO TOOLBAR
    TOL TOLERANCE
    TOR TORUS
    TR TRIM
    UC DDUCS
    UCP DDUCSP
    UN UNITS
    -UN -UNITS
    UNI UNION
    V VIEW
    -V -VIEW
    VP DDVPOINT
    -VP VPOINT
    W WBLOCK
    -W -WBLOCK
    WE WEDGE
    X EXPLODE
    XA XATTACH
    XB XBIND
    -XB -XBIND
    XC XCLIP
    XL XLINE
    XR XREF
    -XR -XREF
    Z ZOOM
    سيفيل انج
    سيفيل انج غير متواجد حالياً
    Thumbs up
    تسلملنا ايدك يا بشمهندس bishr الشورت كاتات ديه بتختصر كتير من الوقت وانا لاقيت اختصارات كتير كان نفسي اعرفها .
    انا جربت معظمها علي autocad 2007 و شغاله تمام هي بتختلف في النسخ الاحدث ولا هي نفسها؟
    مره اخري لك جزيل الشكر
    إسلام علي
    Received: 1,093
    Given: 2,479
    مشكور حبيبي ... بس مش عارف ولكن متهيألي بتزيد لأوامر أكتر ولكن القديم ثابت
    Abo Fares
    Abo Fares غير متواجد حالياً
    Received: 344
    Given: 291
    مشكور أخي bishr
    سليمان81
    سليمان81 غير متواجد حالياً
    الصورة الرمزية سليمان81
    جزاك الله خيرا
    نحن فداك يا رسول الله
    م.محمد النوافله
    م.محمد النوافله غير متواجد حالياً
    شكرا اخي العزيز على هذه الاختصارات
    هذا الملف المرفق فيه اختصارات اتوكاد جميله حصلت عليه من احدى المشاركات للاخوه في المنتدى
    mnci
    mnci غير متواجد حالياً
    تم إيقافه لمخالفة القوانين
    الصورة الرمزية mnci
    Received: 103
    ما رائيكم بهذا الموقع الذى قدمته سابقا واطرحه هنا لتناسبه مع الموضوع يشرح كل امر من اوامر برنامج الاوتوكاد
    http://cadcommands.blogspot.com/
