صفحة 260 من 284 الأولىالأولى ... 160210250256 257 258 259 260261 262 263 264 270 ... الأخيرةالأخيرة
النتائج 2,591 إلى 2,600 من 2832
  1. [2591]
    فاطمةالمهاجرة
    إستشارية الهندسة المدنية
    الصورة الرمزية فاطمةالمهاجرة
    Received: 164
    Given: 149
    اقتباس المشاركة الأصلية كتبت بواسطة Ali.harmouch مشاهدة المشاركة
    Salam Alaykum, I want to take your opinion in that quation. The building is low rise, 4 floors building and consists of 10 Joints. each joint has 14m Width, about 40m Length and 4 floor height. Model in Etabs had been made for one typical joint with wind and earthquake design. Export to Safe had been done. What is the best foundation system to be used: A- Raft footing under each joint.(so we will have 10 raft footings with 2cm expansion joint between the rafts) this will give high pressure on the perimeter columns B- One Raft footing under the building. so we will have one raft footing with 14m width and 400 m length. the expansion joints will be for the superstructure only and will not be in the sub-structure. C- Isolated footings will be used under under each columns with top and bottom reinforcement. As my knowledge, this is should not be used since the building should be supported by raft footing in order to resist the lateral load (raft and wind) Note that in all the 3 cases, the soil pressure is less than the allowable soil pressure. Please advise. Salam
    what means 4 floors building and consists of 10 Joints. each joint has 14m Width: i have'nt understand yor question, is possible explain more?
  2. [2592]
    shamsou
    shamsou غير متواجد حالياً
    اريد حساب تأثير الحرارة على مبنى من الخرسانة المسلحة يبلغ طوله 45م ببرنامج etabs . عندما ادخل combinition الخاصة بالحرارة، لا ارى تغيرا في العزوم. ولهدا اريد شرحا على كيفية حساب تأثير الحرارة في برنامج etabs 9.7. مع كل احترامي.
  3. [2593]
    فاطمةالمهاجرة
    Received: 164
    Given: 149
    اقتباس المشاركة الأصلية كتبت بواسطة shamsou مشاهدة المشاركة
    تدخل من define /static load تضيف احمال الحراره وتعرفها على انها other .تختار العناصر المعرضة لهذه الاحمال الكمرات الطرفية والاعمدة والسطح ومن assign /frame/line loads تختار temperature عند load case name ستبحث عن حمل الحرارة الذي سبق واعطيته اسم عند تعريفه في static load القيمة موجودة في الكود عندكم وهي تخص كل منطقة ستظهر لك هذه القيمة في كل العناصر المختارة ,وكما قلت من combinaisons ندرس العناصر لتحديد التسليح ,يمكن كذلك دراسة الخرسانة على الاحمال السالبة للحرارة بستخدام -مع العدد وشكرا
    1 Not allowed!
  4. [2594]
    م احمد خيال
    م احمد خيال غير متواجد حالياً
    الصورة الرمزية م احمد خيال
    Received: 44
    Given: 13
    انت اخترت نقطتين لعمل hinged بينما عليك اختيار كل joint وعملها hinged ثم اجمعها كلها ثم قسمها على هذا الطول وانظر الى رسوماتك ان كانت السلالم على طول الكمرة فستوزعها على الكمرة كما في الرسمة الاولى طول من رقم 3 الى 3 لكن من الجهة الاخرى لا يكون الحمل على طول الكمرة جزء من الكمرة ليس عليه احمال ,هو ليس حمل مركز لحتى تضعه في نقطة هو حمل t/ml وشكرا
    عندما اقول كل joint اقصد بذلك تاخذ جهة اي كما في الصورة هذه
    ملف مرفق 86895
    شكرا لحضرتك على الرد جزاك الله خيرا 1- لا يوجد كمرة فى منسوب نصف الدور
    2- الارقام فى الرسمة الاولى هى ردود الافعال الناتجة من التحليل
    3- حضرتك انا مش عارف احسب الحمل اللى هيكون على جزء من الكرة الموجوده فى منسوب الدور
    شكرا جزيلا جزاك الله خيرا
  5. [2595]
    Ali.harmouch
    Ali.harmouch غير متواجد حالياً
    The building is too long so it is divided to 14 sub-building by expanssion joints. the total building dimension is rectangle with about 400 m Length and 14 m width bute after putting the expanssion joints, it is now pieces each one has 14m width and arround 35 to 40 m length. Thanks,
  6. [2596]
    محمودالبرلسى
    محمودالبرلسى غير متواجد حالياً
    الصورة الرمزية محمودالبرلسى
    شرح للزلازل بطريقة الطيف الخطى ولو سمحت شيت اكسل
  7. [2597]
    فاطمةالمهاجرة
    Received: 164
    Given: 149
    اقتباس المشاركة الأصلية كتبت بواسطة م احمد خيال مشاهدة المشاركة
    اذا مفيش كمرفي المنسوب نصف الدور السلالم تكون متركزة على ايه ؟هل يوجد shear wall ,لهذا النوع من الدرج لازم يكون طريقة استناد السلالم في نصف الدور لو كانت نوع اخر ربما , ممكن تحط لنا صورة معماري لكن حسابها عادي انت ممكن توزعها على كل طول الكمرة ليس بهذا الدقة لكن ممكن لو فرضنا طول الكمرة 3.7 م اخذت المثل علشان دا الي وجدتو امامي مثلا انت تحمل 3م من الاحمال و0.7م دون احمال نفرض 3.7 تمثل 1 اي 100 % معناه 3م تمثل 3/3.7= 0.81 ولدينا حمل =5 وهو مجموع reactions /L
    انت تقصد انه لديك بنايات ب4 طوابق متلاصقة على طول 400 م وتريد اي نوع من الاساسات لهذه البنايات ؟اريد تذكريك م.Ali.harmouch ان الاساسات متعلقة بالاحمال التي تاتي بها البناية اي الاربع طابق وخصائص التربة ومن بينها bearing capacity ممكن جدا تكون مثلا continous او حتى isolated الحسابات تقرر ذلك وهي حسابات بسيطة اذا كانت التربة ليست جيدة وطلع معاك raft ليست مشكلة ولا وجود للضخط على محيط البناية كذلك الحسابات تقرر يمكنك ان تقسم وزن كل البناية وقسمها على bearing capacity لتقترب من المساحة المطلوبة يمكن اضافة اجنحة للraft ان لم اخطا في التعبير وهذا في اي اتجاه مسموح يعني مش لازم على محيط البناية ,دراسة الاساسات متعلق بعدد الطوابق اي بالاحمال العائدة من superstructure وليس بطول المباني فقط في حالة اخترت اقصد حسبت وطلع معاك لraft متلاصق على هذا الطول هناك تكون مشكلة وارى ان تفصل كما قلت تحت كل بناية لان الخراسانة المسلحة من مساوئها طول العنصر ليست post tension or steel . اكيد البنايات المتلاصقة دي على طول 400م سيكون مشروع خاص جدا ,هذا والله اعلم وشكرا
  8. [2598]
    م احمد خيال
    Received: 44
    Given: 13
    هيكون السلم بالشكل ده كما بالصورة وده متنفذ كتير فى البانى السكنيه العادية
  9. [2599]
    lordamoor
    lordamoor غير متواجد حالياً
    Received: 11
    Given: 4
    سؤال في برنامج سيف عند عرض ال soil pressure تظهر معي قيم موجبه سؤالي هو كيف اتفاداها و ما اقصى قيمه موجبه مسموح بها ؟
    و شكرا
  10. [2600]
    Ali.harmouch
    Thank you for your reply. I fully understand what you mentioned. therefore, my question is, if the soil bearing capacity is Ok, can I use the isolated footing with the lateral loads (Quake and Wind). in case of lateral load, the connection between column / foundation should be fixed. is the connection between the column and the isolated foundation fixed or hinged?
