صفحة 140 من 284 الأولىالأولى ... 4090130136 137 138 139 140141 142 143 144 150190240 ... الأخيرةالأخيرة
النتائج 1,391 إلى 1,400 من 2832
  1. [1391]
    فاطمةالمهاجرة
    إستشارية الهندسة المدنية
    الصورة الرمزية فاطمةالمهاجرة
    Received: 164
    Given: 149
    اقتباس المشاركة الأصلية كتبت بواسطة محمد دهشورى مشاهدة المشاركة
    عند تعريف القطاعات من قائمة define يتم وعند اختيار reinforcement وتحديد هل هو قطاع عمود او كمرة
    هناك تحت اسم cocrte cover خانتين top و bottom
    واسفلهم ايضا تحت اسم reinforcement اربع خانات
    ممكن تشرحلنا القيم دى بتعبر عن ايه؟؟
    وشكراااااا
    السلام عليكم للاجابة على سؤالك يمكنك من الدخول في help حيث تحصل على الجواب
    Reinforcement Data Form
    • Beams option
      • Concrete Cover to Rebar Center edit boxes. Specify rebar cover at the top and bottom of the beam.
        The top cover is measured from the top of the beam to the centroid of the top longitudinal reinforcing.
        The bottom cover is measured from the bottom of the beam to the centroid of the bottom longitudinal reinforcing.
      • Reinforcement Overrides for Ductile Beams edit boxes. Specify areas of longitudinal reinforcing steel that occur at the top and bottom of the left and right ends of the beam. These overrides are used by ETABS as follows:
    In the Concrete Frame Design postprocessor
        • When the design shear in a concrete beam is to be based on provided longitudinal reinforcement (that is, the shear design is based on the moment capacity of the beam), ETABS compares the calculated required reinforcement with that specified in the reinforcement overrides and uses the larger value to determine the moment capacity on which the shear design is based.
        • When the minimum reinforcing in the middle of a beam is to be based on some percentage of the reinforcing at the ends of the beam, ETABS compares the calculated required reinforcement at the ends of the beam with that specified in the reinforcement overrides and uses the larger value to determine the minimum reinforcing in the middle of the beam.
        • When the shear design of columns is to be based on the maximum moment that the beams can deliver to the columns, ETABS compares the calculated required reinforcement with that specified in the reinforcement overrides and uses the larger value to determine the moment capacity of the beam.
    For any degree of freedom in the frame nonlinear hinge properties assigned to a concrete member that is specified as default, ETABS calculates the hinge force-deformation properties based on the larger of the calculated required reinforcement at the ends of the beam (assuming you have run the design through the Concrete Frame Design postprocessor) and the specified reinforcement over
    اعتقد انه واضح وشكرا
  2. [1392]
    فاطمةالمهاجرة
    Received: 164
    Given: 149
    اقتباس المشاركة الأصلية كتبت بواسطة asd salim مشاهدة المشاركة
    Dear Eng Fatima
    pls why u not answer me how we design inclined surfaces
    السلام عليكم بالنسبة لتمثيل المساحات المائلة كالسقف والسلالم يمكنك النتقال من المستوين عن طريق
    move up in list كما هو ممثل هنا
    فقط عليك ان تنتبه عندما تبدا من اليمين الى الشمال في النقطتين الاولين من المستوى الاول عليك في المستوى التاني ان تبدا من حيث النتهين من المستوي الاسفل اي من الشمال الى اليمين
  3. [1393]
    فاطمةالمهاجرة
    Received: 164
    Given: 149
    اقتباس المشاركة الأصلية كتبت بواسطة hhhhh_bbbb198811 مشاهدة المشاركة
    كنت عايز اعرف ازاى اوصف شريحه من خزان( open chanell) على الساب
    علما بان الخزان مرتكز على اربع اعمدة فى الاطراف والشريحه فى الوسط
    فازاى هقول للبرنامج ان ارضيه الخزان متشاله على الحوائط التى تعمل ككمرة مقلوبه بالنسبه للارضيه
    السلام عليكم انا لم افهم السؤال هل انت تتحدث عن الجزء العلوي ام تتحدث عن الاساسات فان كنت تريد تمثيل الكمرات في الاسفل فالبرنامج لن يقبل هذا انت تنقل reaction وتصدرها لبرنامج سيف والله اعلم
  4. [1394]
    فاطمةالمهاجرة
    Received: 164
    Given: 149
    اقتباس المشاركة الأصلية كتبت بواسطة كيمو الزيات مشاهدة المشاركة
    نتيجة لكثرة الشروحات الموجودة لبرنامج ساب واختلافها في طريقة ادخال البيانات وكذلك كثرة اختلاف الاراء في كثير من الامور بالنسبة لهذا البرنامج اريد ان اعرف الطريقة المثلي لتصميم منشا علي برنامج ساب ؟ وهل من الممكن ان اجد مثال لمنشا كامل مصمم علي برنامج ساب( غير مستشفي د/عاطف العراقي ) ؟ وهل من الافضل ان اقوم بحساب التحليل الانشائي علي برنامج الساب ثم اقوم بعمل التصميم علي ملفات اكسل ام اقوم بالتصميم عن طريق برنامج الساب ؟ وهل من الافضل ان اقوم بتحليل البلاطات مع الكمرات مع الاعمدة ام اقوم بتحليل السقف للحصول علي قيم ردود الافعال فقط ولا اعتمد علي العزوم الناتجة علي الshell من الساب ؟
    عندي اسئلة كثيرة جدا خاصة ببرنامج الساب وارجوكم اني اشعر بالتششت ارجو المساعدة ؟
    السلام عليكم في الحقيقة على حد علمي توجد دروس كثيرة وشروحات عليك فقط ان تبحث وتبحث دون ان تمل اما عن سؤالك فيما اعتقد وهذه طريقتي انا في الحقيقة لا اكتفي ببرنامج واحد فقط للحصول على افضل النتائج استعمل الساب او الايتاب بالنسبة للنتائج في العناصر الشقولية اعني الاعمدة وجدران القص اما بالنسبة العناصر الافقية كالكمرات و الاسقف اصدر لسيف حيث ان برنامج سيف مصمم خصيصا لهدذ العناصر والاساسات فمثلا في البلاطات ذات الفتحات يقوم سيف باعطائك نتيجة ادق والدروس في سيف متوفرة في منتدانا والحمدلله وانا قبل سيف كنت اعيد تمثيل القطعة الكبرى بلالعمدة الاربعة التى تحوي على البلاطة الكبيرة على روبوت حتى احصل على نتائج ادق فانا لا اعتمد مطلقا على برنامج واحد انا هذه هي طريقتي في العمل والله اعلم
  5. [1395]
    فاطمةالمهاجرة
    Received: 164
    Given: 149
    اقتباس المشاركة الأصلية كتبت بواسطة step6 مشاهدة المشاركة
    كيف يتم تعريف الاحمال الحرارية في الساب
    السلام عليكم لتعريف احمال الحرارة يتم تعريف من قائمة define load pattern type temperature بعدها نختار العناصر الكمرات والاعمدة نختص الخارجية الاكثر عرضة للحرارة ثم
    assign frame load temperature ومن dead نبحث على الاسم الذي اعطيناه لtemperature في define load pattern type ومن ثم نعطي قيمة الحرارة التي في الكود حسب المنطقة اما gradient فحسابه مختلف ويعتمد على فرق الحرارة بين الداخل والخارج تقسيم سمك العنصر فيما اعتقد نسيت ان كنت تريد gradient سوف ابحث عنه والله اعلم
  6. [1396]
    محمد إبراهيم شحاته
    محمد إبراهيم شحاته غير متواجد حالياً
    الصورة الرمزية محمد إبراهيم شحاته
    Given: 3
    اقتباس المشاركة الأصلية كتبت بواسطة محمد إبراهيم شحاته مشاهدة المشاركة
    أولا شكرا على هذا الموضوع الرائع والمهم جدا
    ثانيا كان عندي سؤال أرجو الإفادة فيه للضرورة، وهو:
    كيف يمكن عمل Fiber Section أو بمعنى آخر تمثيل الـ Plastic Hinge كـ fiber modeling على برنامج الساب؟
    وجزاكم الله كل خير
    أرجو يا إخواني ألا تنسوني لأني فعلا محتاج لتعريف الـ Fiber Section في الساب حتى لوكان مقدمات وأنا بحاول أكمل وأبلغكم بالبقية
    كذلك قمت بفتح موضوع طريقة الـ Fiber Modeling بصفة عامة للمناقشة على الرابط التالي لاعتقادي بتعقيده:
    http://www.arab-eng.org/vb/t158008.html
    اللَّهُم إنّي أسأَلُك عِلماً نافِعاً ورِزقاً واسعاً وقلباً خاشِعاً وعَمَلاً صالِحاً مُتَقَبّلاً وجَسَداً عَلى البَلاءِ صابِراً
    M.I.Sh
  7. [1397]
    romio_201085
    romio_201085 غير متواجد حالياً
    الف الف الف شكر علي الموضوع الرائع ده والله يجازيكم الف خير ويجعلكم عملكم العظيم ده في ميزان حسناتكم
    انا ليه سؤال واحد وياريت تكون اجابته تفصيلية لاني بجد سمعت اجابات كتيرة اوي ومعرفتش اطبق اي حاجه منهم
    لو انا عندي دلوقتي سقف مرسوم علي الكاد ازاي انقله عليا لساب بحيث اني ادخل كمرات واعمدة والسقف طبعا
    ارجوك متبخلش عليه برد مفصل ومنظم للموضوع ده او لو جاوبت حضرتك عليه باسلوب منمق ومشروح قبل كده اديني رقم المشاركه بتاعته في الموضوع العظيم ده
    ولو حد عنده فديو للعمليه دي يكون اكثر من رااااااااااااااااااااااااااااااائع
    شكرااااااااااااااااااااااا ومستني ردك الكريم
  8. [1398]
    نورس جزار
    نورس جزار غير متواجد حالياً
    كتب حول etabs, sap, safe
    إليكم هذه الكتب حول Etabs:
    دليل المهندس الإنشائي لاستخدام ETABS
    http://www.raypub.com/catalog/book_i...roducts_id=544
    الدليل التقني والتحليلي في ETABS
    http://www.raypub.com/catalog/book_i...roducts_id=657
    SAP 2000 V.10 المرجع التقني لتحليل وتصميم المنشآت
    http://www.raypub.com/catalog/book_i...roducts_id=672
    وكتب أخرى باللغة الإنكليزية حول Etabs, Safe, Sap
    http://www.4shared.com/file/62744582...ETABSSAFE.html
    http://www.4shared.com/file/12003002...FE-SAP-SS.html
    http://www.4shared.com/file/24753951...BC_97.html?s=1
    http://www.4shared.com/file/47107334...etabs.html?s=1
    بالتوفيق
  9. [1399]
    فاطمةالمهاجرة
    Received: 164
    Given: 149
    اقتباس المشاركة الأصلية كتبت بواسطة romio_201085 مشاهدة المشاركة
    السلام عليكم انا ساحكي عن طريقة عملي انا وبيجوز انها خاطا لكن انا اعتمادي على الاوتوكاد يكون عند وجود اشكال للمبنى يصعب تمثيلها على اليتاب او الساب وليس ابدا لتمثيل الاعمدة او الكمرات التي يسهل تمثيلها على البرنامج وعليه ما يهمني هو تمثيل الشكل المنحرف او المقوس او الغريب وفي الوتوكاد تختار layer تسميه مثلا ساب او ايتاب وتختار له لون وبعدها تختار كل الشكل الذي رسمته بهذا layer وتعملو move الاحداثية 0,0 حتى اذا نقلته الى البرنامج يكون عند نفس الاحداثية وبعد ما تحفظو في ملف dxf تفتح البرنامج الذي ستستعمله يعني الايتاب او الساب ولاتنسى اختيار الوحدات ثم import الملف مثلا dxf floor plan
    تبحث عندها اين وضعت الملف وتختار الوحدات ثم عند كل عنصر تختار اسم اlayer الذي رسمته وتختار المستوى وهذا كله هدفه الحصول على الشكل الذي يصعب تمثيله واما الباقي فانا امثله مباشرت على البرنامج كالاعمدة التى هي عموما تكون عند الاتقاء خطين متقاطعين ويسهل بعدها تمثيل الاشياء الاخرى فالهدف ليس الحصول على المستوى بالاعمدة والكمرات ونقل كل شئ من الاوتوكاد بينما الهدف الرئيسي من وجهة نظري هي فقط الحصول على تمثيل الاشكال الغريبة للمباني التي يتفنن المعماريين في تمثيلها ليس الا وشكرا
  10. [1400]
    eng.amani
    eng.amani غير متواجد حالياً
    عضو فائق التميز
    الصورة الرمزية eng.amani
    Received: 122
    Given: 101
    احاول تنصيب برنامج ETABS V.9.
    لكن لا تكتمل عملية التنصيب وتظهر
    الرجاء المساعدة
