ارجو المساعده فى استخلاص معدن الذهب من خاماته
النتائج 1 إلى 9 من 9
    الصورة الرمزية عمرو عثمان
    عمرو عثمان
    عمرو عثمان غير متواجد حالياً
    فى عجاله كنت اريد شرح مفصل لاستخدام السيانيد فى استخراج الذهب .
    من يعلم اى كتاب او موقع يفيدنى فى هذا الموضوع فله جزيل الشكر مع العلم انى غير مختص بهذا المجال.
    عمرو شاهين
    عمرو شاهين غير متواجد حالياً
    this process is called leaching
    you can search for it in www.google.com
    alshangiti
    alshangiti غير متواجد حالياً
    مشرف وإستشاري هندسة المناجم
    الصورة الرمزية alshangiti
    Received: 89
    Given: 8
    here is the first method of gold process called heap leach .
    http://www.mine-engineer.com/mining/minproc/mine10.htm
    alshangiti
    Received: 89
    Given: 8
    Tank leaching, also called vat leaching, is a hydrometallurgical method of extracting valuable material (usually metals)from ore. It involves placing ore, usually after size reduction and classification, in large tanks or vats containing a leaching solution. Often the vats are equipped with agitators to keep the solids in suspension in the vats and improve the solid to liquid contact. This is further assisted by the use of tank baffels to increase the efficiency of agitation and prevent centrifuging of slurries in circular tanks. Aside from chemical requirements two key factors influencing extraction are retention time and shear within the leach tanks. Retention time refers to the total volumetric capacity of the leach tank/s divided by the volumetric throughput of the solid/liquid slurry. Retention time is commonly measured in hours for precious metals recovery. A sequence of leach tanks is referred to as a leach "train", and retention time is measured considering the total volume of the leach train. Broadly speaking shear refers to energy transfer into the slurry from power input e.g.agitation. The degree of energy input in conjunction with the tank configuration determines kinetics affecting solid liquid contact. After vat leaching, the leached solids and pregnant solution are usually separated prior to further processing.
    The method is commonly used to extract gold and silver from ore.
    alshangiti
    Received: 89
    Given: 8
    Use of Cyanide in the Gold Industry
    Gold typically occurs at very low concentrations in ores - less than 10 g/t or 0.001% (mass basis). At these concentrations the use of aqueous chemical (hydrometallurgical) extraction processes is the only economically viable method of extracting the gold from the ore. Typical hydrometallurgical gold recovery involves a leaching step during which the gold is dissolved in an aqueous medium, followed by the separation of the gold bearing solution from the residues, or adsorption of the gold onto activated carbon. After elution from the activated carbon the gold is further concentrated by precipitation or electrodeposition.
    Gold is one of the noble metals and as such it is not soluble in water. A complexant, such as cyanide, which stabilizes the gold species in solution, and an oxidant such as oxygen are required to dissolve gold. The amount of cyanide in solution required for dissolution may be as low as 350 mg/l or 0.035% (as 100% NaCN).
    Alternative complexing agents for gold, such as chloride, bromide, thiourea, and thiosulfate form less stable complexes and thus require more aggressive conditions and oxidants to dissolve the gold. These reagents present risks to health and the environment, and are more expensive. This explains the dominance of cyanide as the primary reagent for the leaching of gold from ores since its introduction in the later part of the 19th century.
    Manufacture, Transport and Storage of Cyanide
    Approximately 1.4 million tons of hydrogen cyanide are produced annually worldwide, with approximately 13% used to produce cyanide reagents for gold processing. The remaining 87% is used in industrial applications including production of plastics, adhesives, fire retardants, cosmetics, pharmaceuticals, food processing and as an anti-caking additive for table and road salts.
    Cyanide is manufactured and distributed for use in gold mining industries in a variety of physical and chemical forms, including solid briquettes, flake cyanide and liquid cyanide. Sodium cyanide is supplied as either briquettes or liquid, while calcium cyanide is supplied in flake form and also in liquid form. The strength of bulk cyanide reagents vary from 98% for sodium cyanide briquettes, 44-50% for flake calcium cyanide, 28-33% for liquid sodium cyanide and 15-18% for liquid calcium cyanide. The product strength is quoted on a molar basis as either sodium or calcium cyanide.
    The form of cyanide reagent chosen for use is typically dictated by availability, means of transport, distance from source and cost. Large operations close to manufacturing facilities typically prefer liquid cyanide, but due to the risk of transporting liquids over long distances and the associated cost, smaller and more remote operations use solid forms of cyanide.
    Where liquid cyanide is used, it is transported to the mine by tanker truck or rail car and is off-loaded into a storage tank. The truck or rail car may have a single or double walled tank, and the location and design of the discharge equipment varies by vehicle.
    Solid briquette or flake cyanide is transported to the mine in drums, plastic bags, boxes, returnable bins and ISO-containers. Depending on how the reagent is packaged, the mine will design and construct the necessary equipment to safely dissolve the solid cyanide in a high-pH solution. The pH value of cyanide solutions during dissolution must be maintained above pH 12 to avoid the volatilization of hazardous hydrogen cyanide (HCN) gas. The resulting cyanide solution is then pumped to a storage tank prior to introduction into the process.
    The cyanide solution is fed from the storage tank into the metallurgical process stream in proportion to the dry mass of solids in the process stream. The feed rate of cyanide is controlled to maintain an optimum cyanide level as demanded by the metallurgy of the ore being treated.
    A mine's inventory of bulk cyanide reagent is dictated by the requirements to maintain continuous operations, and to limit the frequency of off-loading events, which are regarded as safety critical events.
    Although the forms of cyanide vary, once introduced into the process, the technologies used for gold recovery are the same.
    Ore Preparation
    Preparation of the ore is necessary so that it can be presented to the aqueous cyanide solution in a form that will ensure the optimal economic recovery of the gold. The first step in ore preparation is crushing and grinding, which reduces the particle size of the ore and liberates the gold for recovery.
    Ore that contains free gold may not yield a sufficiently high recovery by sole use of cyanide leaching, due to a very long dissolution time for large gold particles. Such ore may first be subject to a gravity recovery process to recover the free gold before being subjected to cyanide leaching.
    Gold bearing ores that contain gold associated with sulfide or carbonaceous minerals require additional treatment, other than size reduction, prior to gold recovery. Gold recovery from sulfide ore is poor because the cyanide preferentially leaches the sulfide minerals rather than the gold, and cyanide is consumed by the formation of thiocyanate. These ores are subject to a concentration processes such as flotation, followed by a secondary process to oxidize the sulfides, thereby limiting their interaction with the cyanide during the gold leach. Carbonaceous minerals adsorb gold once solubilized; oxidizing the ore prior to leaching prevents this. To counter this affect, the leaching process may also be modified by the addition of activated carbon to preferentially adsorb the gold.
    Leaching with Aqueous Cyanide Solutions
    When gold is leached in an aqueous cyanide solution it forms a gold-cyanide complex by oxidizing with an oxidant such as dissolved oxygen and cyanide complexation. This complex is very stable and the cyanide required is only slightly in excess of the stoichiometric requirement. However, in practice the amount of cyanide used in leach solutions is dictated by the presence of other cyanide consumers, and the need to increase the rate of leaching to acceptable levels.
    Typical cyanide concentrations used in practice range from 300 to 500 mg/l (0.03 to 0.05% as NaCN) depending on the mineralogy of the ore. The gold is recovered by means of either heap leaching or agitated pulp leaching.
    In heap or dump leaching the ore or agglomerated fine ore is stacked in heaps on a pad lined with an impermeable membrane. Cyanide solution is introduced to the heap by sprinklers or a drip irrigation system. The solution percolates through the heap leaching the gold from the ore, and the resultant gold bearing solution is collected on the impermeable membrane and channeled to storage facilities for further processing. Heap leaching is attractive due to the low capital cost involved, but is a slow process and the gold extraction efficiency is a relatively low 50-75%.
    In a conventional milling and agitated leaching circuit, the ore is milled in semi-autogenous ball or rod mills until it is the consistency of powder. The milled ore (slurry) is conveyed to a series of leach tanks. The slurry is agitated in the leach tanks, either mechanically or by means of air injection, to increase the contact of cyanide and oxygen with the gold and enhance the efficiency of the leach process. The cyanide then dissolves gold from the ore and forms a stable gold-cyanide complex.
    The use of oxygen or peroxygen compounds instead of air as an oxidant increases the leach rate and decreases cyanide consumption, due to the inactivation of some of the cyanide consuming species present in the slurry.
    The pH of the slurry is raised to pH 10-11 using lime, at the head of the leach circuit to ensure that when cyanide is added, toxic hydrogen cyanide gas is not generated and the cyanide is kept in solution to dissolve the gold. The slurry may also be subject to other preconditioning such as pre-oxidation at the head of the circuit before cyanide is added.
    Highly activated carbon is used in the dissolved gold recovery process, either by introducing it directly into the CIL (carbon-in-leach) tanks or into separate CIP (carbon-in-pulp) tanks after leaching. The activated carbon adsorbs the dissolved gold from the leach slurry thereby concentrating it onto a smaller mass of solids. The carbon is then separated from the slurry by screening and subjected to further treatment to recover the adsorbed gold.
    When carbon is not used to adsorb the dissolved gold in the above-mentioned leach slurry, the gold bearing solution must be separated from the solids components utilizing filtration or thickening units. The resultant solution, referred to as pregnant solution, is subjected to further treatment (other than by carbon absorption) to recover the dissolved gold.
    The waste from which the gold was removed by any means is referred to as residue or tailings material. The residue is either dewatered to recover the solution, treated to neutralize or recover cyanide, or is sent directly to the tailing storage facility.
    Recovery of Dissolved Gold
    Gold is recovered from the solution first using either cementation on zinc powder or concentrating the gold using adsorption on activated carbon, followed by elution and concluding with either cementation with zinc or electrowinning. For efficient cementation, a clear solution prepared by filtration or counter current decantation is required.
    The most cost-effective process is to create adsorption of the dissolved gold onto activated carbon, resulting in an easier solid-solid separation based on size. To achieve this the ore particles must typically be smaller than 100 mm while the carbon particles must be larger than 500 mm. Adsorption is achieved by contacting the activated carbon with the agitated pulp. This can be done while the gold is still being leached with the CIL-process, or following leaching with the CIP-process. The CIL-process offers the advantage of countering the adsorption of gold on carbonaceous or shale ore particles, but is more expensive due to less efficient adsorption, increased gold inventory and increased fouling and abrasion of the carbon.
    Activated carbon in contact with a pulp containing gold can typically recover more than 99.5% of the gold in the solution in 8 to 24 hours, depending on the reactivity of the carbon, the amount of carbon used and the mixer's efficiency. The loaded carbon is then separated from the pulp by screens that are air or hydrodynamically swept, thus preventing blinding by the near sized carbon particles. The pulp residue is then either thickened to separate the cyanide containing solution for recovery/destruction of the cyanide, or sent directly to the tailings storage facility from which the cyanide containing solution is recycled to the leach plant.
    The gold adsorbed on the activated carbon is recovered from the carbon by elution, typically with a hot caustic aqueous cyanide solution. The carbon is then regenerated and returned to the adsorption circuit while the gold is recovered from the eluate using either zinc cementation or electrowinning. If it contains significant amounts of base metals, the gold concentrate is then either calcined or directly smelted and refined to gold bullion that typically contains about 70 - 90% gold. The bullion is then further refined to either 99.99% or 99.999% fineness using chlorination, smelting and electro-refining. High purity gold is taken directly from activated carbon eluates, using recently developed processes that utilize solvent extraction to produce intensive leaching of gravity concentrates.
    عمرو عثمان
    الف شكر على الاجابه
    abdo91
    abdo91 غير متواجد حالياً
    بارك الله لك وزادك من علمه وما اوتيتم من العلم الا قليلا صدق الله العظيم
    abdo91
    من فضلكم اريد معرفة ابسط وانجح الطرق لاسترجاع الذهب من محاليل الطلاء الكهربى السيانيديه
    مع خالص الشكر
    الطائر الجريح2020
    الطائر الجريح2020 غير متواجد حالياً
    لوسمحتم ارجو ان تساعدوني طريقه الماء الملكي
