CADWorx 2008 Plant Design Suite Pack
النتائج 1 إلى 10 من 12
    الصورة الرمزية المعماري السوداني
    المعماري السوداني
    المعماري السوداني غير متواجد حالياً
    CADWorx 2008 Plant Design Suite Pack | 215 MB
    CADWorx is COADE`s integrated series of AutoCAD based tools for plant design that provides intelligent drawing/database connectivity, advanced levels of automation, easy-to-use drafting tools, and the industry`s first link between CAD and engineering analysis programs.
    Consists:
    COADE CADWorx Datasheets v2008
    COADE CADWorx Equipment V2008
    COADE CADWorx IP v2008
    COADE CADWorx Plant Pro v2008
    COADE CADWorx P And ID Pro v2008
    COADE CADWork Steel Pro v2008
    CADWorx Datasheets
    CADWorx Datasheets consists of instrument and equipment datasheet modules that can be used standalone or to leverage intelligent data by linking to CADWorx P&ID Professional project databases.
    CADWorx Steel Professional & CADWorx Steel
    CADWorx Steel is a full-featured steel modeling package that allows users to quickly insert steel members into their design or build complex steel structures with full coping and database capabilities. The CADWorx Steel module is included with CADWorx Plant. The CADWorx Steel Professional module is included with CADWorx Plant Professional.
    CADWorx Equipment
    CADWorx Equipment is a parametric equipment modeler with all the features needed to easily model 3D equipment for plant design. The package lets you accurately build units such as vessels, exchangers, tanks, pumps, etc. quickly and effortlessly. Also, vessels and exchangers can be bi-directionally linked to COADE’s PVElite package for engineering analysis.
    CADWorx Plant Professional & CADWorx Plant
    The CADWorx Plant suites supply the most complete range of tools for hassle-free plant design. Piping, equipment, steel, HVAC and cable trays and database links are all included. CADWorx Plant Professional also features CADWorx Equipment, ISOGEN, NavisWorks® Roamer and live database links.
    CADWorx IP (Internet Publisher)
    Allows the users to publish their P&ID projects in a web based format allowing users access to drawings, reports and underlying database information from browser. Distributive design and information sharing has finally come of age in the plant design world!
    CADWorx P&ID Professional & CADWorx P&ID
    CADWorx P&ID gives users the flexibility to create process diagrams with varying levels of information and with the minimum of effort. CADWorx P&ID Professional also features CADWorx Loops, CADWorx IP (Internet Publisher) and live database links.
    Download
    http://www.filefactory.com/file/ab8085/
    http://www.filefactory.com/file/6aecc2/
    http://www.filefactory.com/file/2083c9/
    مهندس تصميمات
    مهندس تصميمات غير متواجد حالياً
    الصورة الرمزية مهندس تصميمات
    جزاكم الله خيرا فهذا البرنامج الرائع انا فى حاجه اليه
    ولكن هذه الروابط لا تعمل برجاء رفعها على سيرفر ىخر ولكم جزيل الشكر
    som3a
    som3a غير متواجد حالياً
    [RAMS]http://media.islamway.com/several//GealAleezah/first.rm[/RAMS]
    المهندس الهلالي
    المهندس الهلالي غير متواجد حالياً
    thank you very much
    mohamedbadawy
    mohamedbadawy غير متواجد حالياً
    Given: 88
    متشكر جدا الروابط شغاله ميه ميه شاكرين مرة اخرى
    iram
    iram غير متواجد حالياً
    this link didn't work with me .how can i load this program
    saladin2002eg
    saladin2002eg غير متواجد حالياً
    Thank you very much i really needed it
    Thank you
    docteurmc
    docteurmc غير متواجد حالياً
    thanks
    ssahir
    ssahir غير متواجد حالياً
    الصورة الرمزية ssahir
    متشكر جدا
    اريد كتاب تعليمي tutorial
    جزاكم الله خيرا
    ssahir
    ارجوا المساعدة
    اللـهـم صلي وسلم وبارك علي سيدنا محمد وعلي اّله وصحبه وسلم إلي يوم الدين
