Troubleshooting Centifugal Pumps &their systems
النتائج 1 إلى 3 من 3
    الصورة الرمزية دلاور
    دلاور
    دلاور غير متواجد حالياً
    Ron Palgrave«Troubleshooting Centrifugal Pumps and Their Systems»
    1st Edition - 2002 | PDF | ISBN: 1856173917 | 384 pages | 53.29 MB
    Modern centrifugal pumps are not complex machines. Usually they consist of a few castings, mouldings, or pressings that are pierced by a few wrought or turned components. Evidently, they are one of the ubiquitous machines, being comparable in numbers to the electric motor and the internal combustion engine.
    Despite their simplicity, Centrifugal pumps are still capable of posing complex puzzles during operation. This complexity usually arises from a permutation of circumstances that combine to require complex diagnosis. This means that many apparently simple pump operational problems need analysis so complex that it belies the machines simplicity.
    Stated simply, pumps are fine until they malfunction or break down. When that happens, the first priority is to get the pump functioning again and to keep 'down time' to a minimum. Many problems can be diagnosed and rectified using a combination of knowledge and experience, the latter coming over time. This book, written by a very experienced engineer, guides the reader through diagnostic pathways leading to logical explanations for the malfunctions and their correction.
    Deposit Files Link:
    Download
    Easyshare Files Link
    Download
    نتيجة رقم
    نتيجة رقم غير متواجد حالياً
    لم استطع التحميل لسوء موقع التنزل
    علي محمد المهندس
    علي محمد المهندس غير متواجد حالياً
    مشكور جاري التحميل ،اللهم انصره واجعله من عبادك العلماء
