الذكاء الاصطناعي Artificial Intelligance
النتائج 1 إلى 4 من 4
    الصورة الرمزية معتصم ابوشعيرة
    معتصم ابوشعيرة
    معتصم ابوشعيرة غير متواجد حالياً
    Received: 18
    Given: 48
    The modern definition of artificial intelligence (or AI) is "the study and design of intelligent agents" where an intelligent agent is a system that perceives its environment and takes actions which maximizes its chances of success.
    John McCarthy, who coined the term in 1956, defines it as "the science and engineering of making intelligent machines." Other names for the field have been proposed, such as computational intelligence, synthetic intelligence or computational rationality.
    The term artificial intelligence is also used to describe a property of machines or programs: the intelligence that the system demonstrates. AI research uses tools and insights from many fields, including computer science, psychology, philosophy, neuroscience, cognitive science, linguistics, operations research, economics, control theory, probability, optimization and logic.
    AI research also overlaps with tasks such as robotics, control systems, scheduling, data mining, logistics, speech recognition, facial recognition and many others. Computational intelligence Computational intelligence involves iterative development or learning (e.g., parameter tuning in connectionist systems).
    Learning is based on empirical data and is associated with non-symbolic AI, scruffy AI and soft computing.
    Subjects in computational intelligence as defined by IEEE Computational Intelligence Society mainly include: Neural networks: trainable systems with very strong pattern recognition capabilities. Fuzzy systems: techniques for reasoning under uncertainty, have been widely used in modern industrial and consumer product control systems; capable of working with concepts such as 'hot', 'cold', 'warm' and 'boiling'. Evolutionary computation: applies biologically inspired concepts such as populations, mutation and survival of the fittest to generate increasingly better solutions to the problem.
    These methods most notably divide into evolutionary algorithms (e.g., genetic algorithms) and swarm intelligence (e.g., ant algorithms). With hybrid intelligent systems, attempts are made to combine these two groups.
    Expert inference rules can be generated through neural network or production rules from statistical learning such as in ACT-R or CLARION.
    It is thought that the human brain uses multiple techniques to both formulate and cross-check results.
    Thus, systems integration is seen as promising and perhaps necessary for true AI, especially the integration of symbolic and connectionist models.
    الموضــــــــــوع منقـــــــــــول
    http://4electron.com/
    robotic_iraq
    robotic_iraq غير متواجد حالياً
    Thanx Good Work
    علي عباس جاسم
    علي عباس جاسم غير متواجد حالياً
    Received: 10
    شكرااااااااااااا
    عواد ملهاوي
    عواد ملهاوي غير متواجد حالياً
    موضوع رائع جدا.... نتمنى المزيد من المشاركات المفيدة
