Guidebook to ASME Section II
النتائج 1 إلى 6 من 6
    جدار النار
    جدار النار غير متواجد حالياً
    السلام عليكم أخواني الكرام
    أبحث عن الكتاب التالي
    أرجوا من يملك هذا الكتاب أن يرفعه لنا
    CASTI Guidebook to ASME Section II, B31.1 & B31.3 - Materials Index (8th edition)
    Ninth Edition:
    printed April 2005
    Author:
    Richard A. Moen
    ISBN:
    1-894038-82-7
    This newly updated Guidebook efficiently organizes the important materials data used in ASME Code design and construction of boilers and pressure vessels. In addition to coverage of ASME Section II Parts A and B materials, this Guidebook also contains a brief history and scope of the B31.1 and B31.3 piping codes, a detailed outline of the materials covered in B31.1 and B31.3 piping codes and much more. There is also information covering special limitations on B31.3 materials, precautionary service considerations for B31.3 materials, listings of ferrous and nonferrous materials specifications by boiler and pressure vessel code section use, and listings of ASTM and API specifications/grades (for those materials in the B31.1/B31.3 stress tables.)
    Recognizing that materials-support people for Code construction would benefit from additional guidance on materials issues, this Guidebook provided additional help in understanding broader aspects of the Code as well as focusing on the location of materials requirements and guidance within the various Code sections. It also goes one step further by extending the scope of the materials index to cover materials for Section IV, Section VIII – Div. 3 and B31.1/B31.3 construction. This Guidebook is written by a long-serving ASME II Code Committee member, Richard Moen. It is intended to be the ultimate primer for anyone dealing with code materials issues, and will benefit everyone from the "novice" to the "veteran."
    أتمنى لكم وقتا ممتعا
    eng_ahmed_moh
    eng_ahmed_moh غير متواجد حالياً
    الصورة الرمزية eng_ahmed_moh
    ادخ على قسم التعدين والبترول وستجد ما تريد نا شاء الله
    او ادخل على الرابط
    http://www.arab-eng.org/vb/t92968.html
    جدار النار
    أشكرك أشكرك أشكرك
    أخي الكريم
    eng_ahmed_moh
    لا شكر على واجب
    بارك الله فيك
    ستندر
    ستندر غير متواجد حالياً
    السلام عليكم .. انا عندي هذا الكتاب على شكل pdf لكني لا اعرف كيف ارفعه .
    عمرو رمزى
    عمرو رمزى غير متواجد حالياً
    مشكور وأريد casti guik to asme ix
