Autodesk AutoCAD Mechanical 2009
النتائج 1 إلى 10 من 10
    الصورة الرمزية فلسطين والنضال
    فلسطين والنضال
    فلسطين والنضال غير متواجد حالياً
    • Acme CAD Converter v7.9
    Software
    Acme CAD Converter v7.9|3.77MB
    DWG Converter - Batch Convert DWG to PDF,DWG to WMF,DWG to EPS,DWG to SVG,DWG to CGM,DWG to BMP,DWG to JPEG,DWG to GIF
    Acme CADConverter is a format conversion software for batch and vector files. It can conveniently convert DXF,DWF and DWG files into BMP, GIF, JPEG, WMF, PCX, TIFF, PNG, TGA, DXF, DWG, SVG, SVGZ, CGM, EPS, PDF, HPGL(PLT,HGL) etc., and also enable the conversion between DXF and DWG file versions (AutoCAD R2.5-R2008). Supports replace font file. Supports Transmit command like AutoCAD,and batch recover drawing files. It can export layers information into the PDF file and it allows you export OLE entity and raster entity into PDF file, Supports 3D objects Hidden line removal.
    Supports Windows95/98/ME/NT/2000/XP/Vista ;without AutoCAD;
    Characteristics:
    * Supports to open various DXF / DWG versions ( R2.5-R2008 ) and DWF;
    * Identify literal fonts and entity color correctly;
    * Supports batched conversion of multiple files;
    * Supports to select the printout of color or monochrome raster file; set background color freely;
    * Print out raster mask file; be used as image channel (used in Photoshop etc.);
    * Replaces font files.
    * Sets the size of raster file to be printed out freely;
    * Supports full-screen mode ( press F );
    * Supports printing;
    * Supports AutoCAD pen sets file (*.ctb).
    * Supports the paper setting of each layout, can adjust the size of output pages with its layout automatically.
    * Supports 3D objects Hidden line removal when convert DWG/DXF to other formats.
    * Converts to PDF;
    * Multi-files transmit;
    * Batch recover DWG/DXF files;
    * Can export layer information and raster image in the dwg/dxf file to PDF file
    * Can export OLE entity to PDF file.
    * Can select a window area for exporting
    * Exports the arc/circle objects to true arc/circle objects of other vector file.
    * Supports true color
    * Supports pen width and destination colors settings, and can export/import these settings
    * Creates PDF bookmark automatically with layout name and file name, and you can edit them
    * SHX font, XRef and Image search path
    * What you see is what you get
    * Supports command line parameters;
    * Free viewer of dwg/dxf/dwf files
    * Register once and upgrade free permanently;
    * Supports Windows95/98/ME/NT/2000/XP/Vista,without AutoCAD;
    فلسطين والنضال
    انا اسف اخواني روابط برنامج Autodesk AutoCAD Mechanical 2009 مش شغاله فحطيت هذا بداله
    سوف نقتلهم جميعا وسوف نشرب دمائهم في كاس انتفاضتنا وليكن نخبه الموت لنا ولهم ولتحيا فلسطين
    السَّبنتى
    السَّبنتى غير متواجد حالياً
    الصورة الرمزية السَّبنتى
    جزاك الله خيرا
    mother
    mother غير متواجد حالياً
    مشكوررررررررررررررررررررررررررررررررررررررررررررر
    فااايز
    فااايز غير متواجد حالياً
    مشكووووووووووووووووووووووور
    amir mhd
    amir mhd غير متواجد حالياً
    الصورة الرمزية amir mhd
    اخي العزيز .. السلام عليكم ورحمة الله و بركاته .. كل عام و أنتم بخير ربنا يحقق الأماني إنشاء الله ربنا يحقق السلامة والأنمن للأمة العربية و الإسلامية جمعا و تحرير القدس ..........
    amir
    med123
    med123 غير متواجد حالياً
    مشكووووووووووووووووووووووووووووووووووووووووووووووو ووووور
    aissaoui58
    aissaoui58 غير متواجد حالياً
    الروابط لا تعمل ارجو التوضيح و شكرا
    aissaoui58
    هل هناك روابط جديدة؟
    aissaoui58
    اريد مساعدة في الحصول على Autodesk AutoCAD Mechanical 2009
