هام
مشاهدة نتائج الإستطلاع: لو مدير الشركه نزل الموقع بدون الخوزه
المصوتون
861. أنت لم تصوت في هذا الإستطلاع
  • اتركه
    47 5.46%
  • انصحه بلبسها
    407 47.27%
  • امنعه من نزول الموقع
    354 41.11%
  • اخلع بتاعتى و البسه له
    53 6.16%
صفحة 175 من 219 الأولىالأولى ... 75125165171 172 173 174 175176 177 178 179 185 ... الأخيرةالأخيرة
النتائج 1,741 إلى 1,750 من 2185
  1. [1741]
    مروان البرنس
    مروان البرنس غير متواجد حالياً
    الصورة الرمزية مروان البرنس
    Post Personal Protective Equipment 11
    PERSONAL PROTECTIVE EQUIPMENT
    HAZARD ASSESSMENT
    Company Name: ____________________________________________Date of Assessment: _____________________
    Company Address: __________________________________________________ _______________________________
    Workplace Evaluated: __________________________________________________ ____________________________
    Name of Person Completing Assessment: __________________________________________________ ______________________
    Job Classification
    WORKSTATION
    HAZARD
    SOURCE/TYPE
    BODY PART
    AFFECTED
    PPE REQUIRED
    YES/NO
    TYPE of PPE REQUIRED
  2. [1742]
    مروان البرنس
    Post Personal Protective Equipment 12
    Sample PPE Assessment and Certification Worksheet
    (Note) This worksheet, or any other worksheet used to assess the worksite for PPE is not mandatory. However, certification that a PPE assessment has been completed is required by the PPE standard.)
    Assessment conducted by:________________________________________ Date:___________________________
    Task______________________________________________ ___________ Department______________________
    Instructions
    1. Conduct a Job Safety Analysis of the above task.
    2. List below the hazards found in the JSA.
    3. If engineering or management practices cannot eliminate the hazards or are not feasible, determine the appropriate PPE for each hazard.
    Note: If you are not sure about appropriate PPE, consult your OR-OSHA consultant or insurer for assistance.
    Summary of Task Hazards and PPE Required
    Impact by:_____materials_____equipment_____objects_____co-worker_____other (describe)_____________________________________
    PPE required: (head, eye, foot, etc.)_____________________________________________ ________________________________
    Contact with: _____ Stationary object _____moving object_____sharp object_____other (describe)_________________________________
    PPE required: (foot, head, etc.)_____________________________________________ ____________________________________
    Fall: _____ from elevation _____ to surface _____slipping _____ tripping _____ other (describe)__________________________________
    PPE required: (fall, restraint systems)__________________________________________ ______________
    Caught in, under, between: _____ running or meshing objects _____ moving object _____ stationary object _____ rolling vehicle_________ collapsing materials/cave-in _____ other (describe) __________________________________________________ _____________________
    PPE Required: (hand, foot, etc.) __________________________________________________ _____________________________
    Overexposure: ____ noise ____ heat ____ cold____ temperature variation ____ radiation. List dBA ___________Temp ______________F.
    PPE required: (hearing, respiratory, clothing, eye, etc.) __________________________________________
    Inhalation of: ____hot ____cold ____dust ____mists ____vapors ____smoke ____gasses ____fibers ____biohazards____ _other (describe)
    PPE required: (respiratory, face, etc.)_____________________________________________ ____________
    Ingestion of: _____hot _____cold _____acids _____bases _____caustics _____poisons _____dust _____mists______ vapors ______smoke _____gases _____radiation _____fibers _____other (describe) __________________________________________________ ____________
    PPE Required: (respiratory, face, etc.) __________________________________________________ ________________________
    Absorption of: ___acids ___bases ___ caustics ____poisons ___hazardous chemicals ___other (describe) ____________________________
    PPE required: (hand, face, eye, clothing, etc.) __________________________________________________ ___________________
    Skin contact with: ___ hot liquid ___molten metal ___sparks ___acids ___bases ___caustics ___poison ___other (describe) _____________
    PPE required: (hand, foot, face, eye, clothing, etc.) __________________________________________________ _______________
    4. Reference the associated MSDS for each hazardous chemical used and list the recommended PPE for that chemical.
    Chemical:
    MSDS PPE:
    Certification _________________________________________ _________________________________
    Signature
  3. [1743]
    مروان البرنس
    Post Personal Protective Equipment 13
    Sample PPE Walk Through Survey and Certification
    Department _____________________ Task _________________________________________Date _________
    Assess each task for hazards using the following criteria: (1) Type of injury or illness possible: (2) Probability
    unlikely, likely, highly likely; and (3) Severity – death, serious injury/illness, not serious injury/illness.
    1. Sources of motion – machinery, processes, tools, materials, people, etc. ______________________________
    __________________________________________________ __________________________________________
    Required PPE: __________________________________________________ _____________________________
    2. Sources of high temperatures – that could cause burns, ignition, injury to eyes, etc. ____________________
    3. Sources of chemical exposure – splash, vapor, spray, immersion, etc.________________________________
    4. Sources of harmful atmospheres – dust, fumes, gasses, mists, vapors, fibers, etc._______________________
    5. Sources of light radiation – welding, brazing, cutting, furnaces, heat treating, high intensity lights, etc._____
    6. Sources of falling objects – materials, equipment, tools, etc.________________________________________
    7. Sources of sharp objects – which could pierce the skin – feet, hands, face, etc. _________________________
    8. Sources of rolling or pinching that could crush – hands, feet. _____________________________________
    9. Layout of workplace and location of co-workers – adequate space for task. ___________________________
    10. Sources of contact with electricity – wires, grounding. ____________________________________________
    I certify that I have conducted a workplace survey on the above task to assess the need for personal protective
    equipment. The personal protective equipment noted above will be required while performing this task.
    ____________________________________________ ____________________________________ Signature
  4. [1744]
    مروان البرنس
    Post Personal Protective Equipment 14
    Sample Personal Protective Equipment (PPE) Test
    (Supervisors should give this test after training the employee on the proper use and care of PPE. The supervisor should review the test and discuss any areas requiring additional training. When the supervisor is confident that the employee has an adequate knowledge and ability to properly use PPE associated with the job, the supervisor should certify training.)
    1. List the type(s) of PPE required for your task.
    2. What are the hazards you are being protected against for each type of PPE used in your job?
    3. Describe procedures for the use and care of the PPE you are using.
    4. What should you look for to determine if the PPE you are using is in good working order?
    5. What actions do you take when your PPE becomes defective?
    Certification
    I have personally trained ________________________________ and answered all questions pertaining to the proper use and care
    Of PPE. I certify that he/she has adequate knowledge and ability to proper use and care for the PPE associated with his/her job.
    Supervisor’s Signature Date
    I have been adequately trained on the use and care of PPE to be used by me. My supervisor has answered all questions to my satisfaction and I understand he/she will be available for follow-up training if needed.
    Employee’s Signature Date
  5. [1745]
    مروان البرنس
    Post Personal Protective Equipment 15
    ASSIGNMENT, TRAINING AND FIT-TEST FORM
    All affected employees receive PPE training that includes when PPE is necessary; what PPE is necessary and why; how to wear PPE properly; PPE limitations and capabilities; and PPE care and maintenance. Each affected employee is fitted properly with the assigned PPE.
    The following individual has been assigned PPE, has been fit-tested, and has received training.
    Employee: ____________________Training Date ______________________________________
    Name of Trainer___________________________________________ ______________________
    The following is a list of PPE assigned to this employee including the manufacturer, model and any identification numbers:
    I acknowledge that I have been assigned the above named equipment, have had the opportunity to be properly fitted, and have received training. I also acknowledge that I understand the training that was provided:
    (Employee’s Signature)
  6. [1746]
    مروان البرنس
    Post Personal Protective Equipment 16
    PERSONAL PROTECTIVE EQUIPMENT POLICY
    FOR
    ­­­­­­__________________________________
    (Name of Company)
    PURPOSE
    The purpose of this program is to protect the employees of _______________________ (Insert name of Company) from the occupational hazards within the workplace by providing the proper personal protective equipment (PPE). It is the goal of the company to use engineering controls as the primary method for protecting employees. However, when additional protection is necessary, appropriate PPE will be worn. The scope of this program includes PPE for eye; face, head, foot, and hand protection. If respirators and/or hearing protection is necessary, their use will be covered by the Company’s Respiratory Protection Program and the Hearing Conservation Program, respectively.
    RESPONSIBILITY
    The person responsible for coordinating this program is ______________________, (insert name or job title of responsible person). This person will ensure that hazard assessments are conducted, appropriate PPE is assigned, and affected employees receive training. The responsible person will also be in charge of maintaining the documentation for this program.
    Department supervisors should advise the responsible person of changes in PPE requirements (e.g., new procedures/processes requiring different PPE; omission of a job/task). Additionally, supervisors should consult with the responsible person before purchasing any new PPE.
    Hazard Assessments
    Each job/task performed will be assessed to determine foot, head, eye, face, and hand hazards present and the proper PPE that should be worn. The assessments will include observation of the following sources of hazards:
    1. Impact: Flying chips, objects, dirt, particles, collision, and motion hazards.
    2. Penetration: Falling/dropping objects, sharp objects that cut or pierce.
    3. Compression: Rollover or pinching.
    4. Chemical: Splashing, burns, fumes.
    5. Temperature Extremes: Sparks, splashes from molten materials, burns from high/low temperatures.
    6. Harmful Dust: Dirt, particles, asbestos, lead.
    7. Light Radiation: Welding, cutting brazing, lasers, furnaces, lights.
    The attached Hazard Assessment Form will be completed for each job/task and will serve as certification that a hazard assessment has been performed.
    The person conducting the hazard assessment will also survey jobs that are non-routine or periodic. In some cases these assessments may not be completed until the jobs are scheduled.
    Hazard assessments will be updated/evaluated whenever conditions or procedures change.
  7. [1747]
    مروان البرنس
    Lockout/tagout
    TABLE OF *******S
    Page #
    1 Introduction 1
    2 Employer Responsibility.................................... ................................... 1
    3 Scope and Application of Lockout/Tagout Requirements........................ 2
    4 Vertical Standards Disallow Tagout System.......................................... 3
    5 Tasks Covered by the Standard.......................................... .................. 5
    6 Employers Not Covered by the Standard.......................................... ..... 5
    7 Exceptions to Part 85................................................ ........................... 6
    - Total Exceptions........................................ .................................... 6
    - Partial Exceptions........................................ .................................. 6
    - Capability of Accepting Lockout........................................... ........... 7
    8 Lockout/Tagout Program........................................... ........................... 7
    - Specific Machine/Equipment Procedure......................................... . 7
    - Employee Training.......................................... ............................. 11
    - Periodic Inspection and Review............................................ ......... 12
    9 Protective Materials and Hardware.......................................... ............ 13
    10 Machine Startup........................................... ...................................... 13
    11 Recordkeeping..................................... .............................................. 15
    12 Minor Adjustments and Servicing......................................... ............... 15
    13 Electrical Work.............................................. ..................................... 16
    14 Special Conditions........................................ ...................................... 17
    - Testing or Positioning of Equipment/Machines............................... 17
    - Exchange of Information with Outside Contractors.......................... 18
    - Group Lockout or Tagout............................................ ................... 18
    - Shift or Personnel Changes........................................... ................ 19
  8. [1748]
    مروان البرنس
    Post Lockout/tagout 2
    APPENDIX
    Page #
    A Control of Hazardous Energy (Lockout/Tagout)
    Sample Program........................................... .............................. 21
    B Lockout/Tagout Written Program Evaluation................................... 33
    C Lockout/Tagout Compliance Guide:
    An Approach to Establishing Written Lockout Procedures................ 35
    D Energy Source Evaluation and Energy Control Procedure................ 37
    D-1 Sample Guideline of Energy Source Evaluation and Energy
    Control Procedure......................................... ................................. 39
    E Partial Exception Worksheet......................................... ................. 41
    F Control of Hazardous Energy Sources (Lockout/Tagout):
    Employee Training Certification..................................... ................. 43
    G Control of Hazardous Energy Sources (Lockout/Tagout):
    List of Authorized Lockout Individuals....................................... ...... 45
    H Control of Hazardous Energy Sources (Lockout/Tagout):
    Periodic Inspection Certification..................................... ................ 47
    I Group Lockout Scenarios......................................... ...................... 49
    J Part 40 General Industry Safety Standard:
    Electrical Safety-Related Work Practices..................................... 55
    K Part 85 General Industry Safety Standard:
    The Control of Hazardous Energy Sources.................................. 63
  9. [1749]
    مروان البرنس
    Post Lockout/tagout 3
    1. Introduction
    Locking out machinery and equipment prior to servicing or maintenance is an essential element of protecting employees from the unexpected energization or motion, start up of the machine or equipment, or release of stored energy. To address this issue and to comply with the Michigan Occupational Safety and Health Act’s (MIOSH Act), General Industry Safety Standard Part 85: The Control of Hazardous Energy Sources Standard, the CET Division has developed the Lockout/ Tagout Compliance Guide. The Control of Hazardous Energy Sources standard will be referred to throughout this guide as Part 85.
    This guide reviews all required areas of a comprehensive lockout/tagout program. It includes examples and suggestions to consider in developing a program. This manual is presented in general terms in an effort to assist with compliance and complement relative regulations and equipment manufacturers’ requirements.
    2.Employer Responsibility
    In addition to the provisions of Part 85, MIOSHA also enforces separate rules for working on or near exposed energized or de-energized parts. These rules, which include provisions for lockout of electrical systems, are contained in MIOSHA. General Industry Safety Standard Part 40, Electrical Safety-Related Work Practices.
  10. [1750]
    مروان البرنس
    Post Lockout/tagout 4
    An employer is responsible for ensuring the safety of its employees and for complying with all related requirements of Part 85: The Control of Hazardous Energy Sources. It is important that levels of management promote positive attitudes regarding safety, incorporate safety into their work practices, and cooperate fully in the implementation of safety-related programs.
    MIOSHA requires the employer to plan for the control of energy during servicing and/or maintenance of machines and equipment by doing the following:
    § Establish an energy control program:
    § Develop, document and utilize lockout/tagout procedures;
    § Provide employees appropriate training;
    § Provide, at no cost to employees, equipment required by the lockout/tagout procedures.
    § Continuing competency through training.
    Part 85 provides control of hazardous energy when the hazard to the employee is mechanical. Part 40 addresses safe work-practices, including lockout, where the hazard to the employee is electrical. Lockout/tagout procedures can be included in one document.
2005, 2007, للأمن, للأخ, للمحترفى, للأخوة, للمشاركة, للمعدات, للمناقشه, للمنفعة, لماذا, للافادة, ممتاز, للتدريب, للجميع, لمحة, للخبراء, للخدمة, للحجاج, للحريق, للحوادث, للدكتور, للرجل, للزملاء, للسلالم, للسادة, للسائقين, لمشاكل, للشركات, ملصقات, للعمل, للعاملين, للغياب, ملف, ملفات, لله, لأهل, للإجابة, لمن, لمؤتمر, لمنتدى, للنيبوش, للوقاية, ممكن, مال, accident, مادة, لايحدث, لاخوانى, ماهي, ماهر, ماهو, مائية, لذوي, مبادئ, آثار, أبحث, متخصصي, متخصصه, مبروك, لبناء, متواضعة, أحمد, لجميع, مجمع, مجموعة, مجموعه, أيام, محاضرات, محاضرة, مخاطر, محتاج, أختبار, ميدان, لدية, محددة, لدينا, مخخط, أجرا, لحرارة, أخرى, محصلة, ميزانية, محسن, آيه, أجهزة, لخطوط, amounia, أرامكو, مراجع, مراجعة, مراقبة, مرحبا, أريد, أرجو, مروري, مشاركة, مساعدة, مساعدةعن, مساعده, مساويء, مستعجلة, مستقبل, مصر, مشروع, أسفل, لصناعة, أسناني؟؟, aramco, arrest, assessment, لعمل, أعمال, أغلب, معلومات, معلوماته, أغرب, معرض, أعضاء, مفیده, أفلام, أفادكم, أفيدوني, أهم, أهمية, مهمه, مهام, مهامها, لإيجاد, لإظهار, مهنية, مهندس, مهندسي, مهندسين, مواصفة, مناعة, مواضيع, مواقع, منتدى, منير, منَ, منزلك, أنشاء, أنزور, لنغير, منظومات, أنواع, موضوع, موضوعين, موقع, منكم, أطلب, لطلبة, مطلوب, مطلوبه, مطب, لطيف, مقال, مقتل, أقتراح, مقدمه, لكم, مكافحة, مكان, لكتاب, لكن, bloodborne, boox, box, building, الیکم, الأ, الملتقى, المميزة, المميزين, الأمراض, الأمن, المايكروويف, المذكور, المجالات, المياه, المخاطر, الأحبةاحتاج, الأجهزة, الأخوات, المدنية؟, الميكانيكية, المراكز, المساحية, المشاركات, المشاركة, الأساسية, المساعدة, المساهمه, المستخدمة, المستشفيات, المستودعات, المصرى, الأسنان, المعادن, المعدنية, الله, المهنیه, المهنية, المهندس, المهنيه, الآن, الأولى, المواد, المواضيع, الموبايل, المنتج, المنتدى, المنشأ, المنشآت, الأوشا, الأنظمة, الموعد, الأنفاق, اللون, الموضوع, الموقع, المطارات, الأطباء, المقاولات, المكاتب, الامريكية, الامن, الامن والسلامة, الالوان, الامنة, الالكترونيه, الاباء, الاتصالات, الاخ, الاحمال, الاحتياجات, الاحتراز, الاخرى, الايزو, الاخوة, الاخوه, الارتفاعات, الاستاذ, الاستاتيكيه, الاستخدام, الاستشاريه, الاسعافات, الاسنان, الاعزاء, الاولية, الانابيب, الاوسط, الانضمام, الاضافات, الاطفال, البلاتينية, البلاستيكية, البلدان, التميز, التأريض, البترول, البترولية, التي, البخارية, البديل, التدخين, التحيه, البيئة, البيئه, التدقيق, البرق, التشييد, البصرية, التصوير, التعرض, البناء, التواصل, التكييف, الى, الحل, الحماية, الحمايه, الجميع, الجامعة, الخاصه, الحرائق, الحريق, الحروق؟نصيحة, الجزائر, الجزائرية, الجزير, الحصول, الدعوة, الحفاظ, الحفر, اليه, الدولية, الجوااااااال, الحوادث, الجوجل, الجويه, الدورة, الخطره, الnasp, الري, الرجل, الرعد, السیطره, السلالم, السلامة, السلامةو, السلامه, الشمس, السمعية, السالب, السابقة, الصاج, السبت, السياره, الصداقة, الصحة, الصحي, السيجارة, الزيركون, الشخصية, الشده, السرعات, السرعه, الصرف, الشرق, الشرقية, الosha, الصعود, السعودية, السفن, الصناعي, الصناعية, الصواعق, السويس, السطحية, الزقازيق, السقوط, الشكر, carbon, الrisk, العلم, العليا, العالم, العالمين, العامة, العالي, العامه, الغازات, الغرب, العربي, العربية, الظهر, العواصف, العضلات, الغضب, الفتلة, الـتأهيلية, الفياغرا, الفرق, الفنية, الهيدروجين, الإخوة, الهواء, الهندي, الهندسة, الهندسية, الإطارات, الناس, النيبوش, الوصول, الوظفيه, الوطنية, الوقاية, الوقائي, الضغظ, الضغط, الکتاب, الطائره, الطبيعية, الطيور, الطريق, الطرق, القلب, القاهرة, القيادة, القوانين, القوى, القطع, الكيميائية, الكرام, الكهرمغناطيسية, الكهرباء, الكهربائة, الكوارث, certified, اثناء, احمد, ادارة, اجازه, اختبر, ادخل, اجهزة, اخوات, اخواني, اريد, ارجو, ارجوكم, ارشادات, اسمله, اصابات, ازاى, استجابة, استخدام, استعمال, استعمالها, استفاده, استفسار, اسبوع, color, construction, consultant, crane, اعمال, اعادة, اعتذار, اعتقد, اعدادى, اعرف, افلام, افتتاح, افيضو, اهمال, اولا, اولى, انا, انترسيك, انجليزي, انشا, انقذوا, اطفالنا, اقتراح, اقتراحي, اكثر, data, databaseprogram, ذلك, design, dioxide, dtm, تأثير, تلوث, تموج, بمنطقة, بالمملكة, بالمتندي, بالأشعة, بالمواد, بالسلامة, بالسيارات, بالسعودية, بالصور, بالعيد, تتخلص, تبين, بترول, بدأ, تخلى, تحليل, بجميع, بجمهورية, بجامعة, تجاهل, بيانات, تحذير, بدت, بحثيه, تحبني, تحية, تحديد, بخير, بخصوص, بيسط, تجهيزات, بين, بحوث, بدون, engineering, ترددات, environmental, برنامج, تسمحو, بشأن, تساؤل, بسبب, تزيد, تشخيص, بسيط, تسرب, بشرح, تشريعات, بسررررعة, equipment, تعمل, تعليمات, تعال, تعبئة, بعد, تعيل, بعنوان, تعقدها, exam, excavation, تهبط, تهنئه, توجيهية, توضيحية, تنكات, تطبيقي, ثقافة, تقديم, تقرير, بقواعد, تقنية, تكساس2008, تكنب, facilities, fall, finding, fire, flash, food, free, gas, green, h2s, hazards, hazwoper, health, hose, hscode, hse, hsems, حماية, دمج, جميل, حمدى, جمعيات, حلو, يالله, خالد, يامهندسين, يالقاهرة, داخل, ياجماعه, حاجة, حادثة, خاصة, خاصه, خاطر, جدا, جداً, يجب, يجيبني, خيرا, يحوز, يحقق, ilo, impact, important, imroving, incident, دراسه, indicators, حريق, injury, inspector, investigation, جسم, حساب, يساعد, يستر, يشرح, items, دعابه, دعوة, يعود, دعوه, يعقل, حفر, حول, حولتطبيقات, حولنا, حوادث, يؤثر, يوجد, دور, دورات, دوران or استخلاص, دورة, دورتي, دوره, يضم, خطة, خطير, خطر, خطط, حكايتكم, layout, lifiting, lockout or tagout, lockouttagout, lpg, lti, managmen, msds, msha, mus, رأيكم, nasp, راجعون, nebosh, newly, ربنا, nffss, nfpa12, nfssi, رجاء, noise, سلام, سلامة, سمحتم, سمحتم؟, سمعك, شاملة, سارة, ساعات, ساعدوني, سبل, سببها, ستفقدة, صيام, سيارتك, صيانة, سيد, سيجارة, زراعة, شرعية, شركات, شركة, osha, oshas, صغير, شهادات, سوال, سؤالى, صناعي, شوب, صور, سوف, سطح, شكر, performance, personal, planet, point, pollution, powerpoint, presentation, presentations, procedures, process, professional, program, protection, protective, register, related, required, risk, rso, safe, safely, safety, safty, sample, sayed00, scaffold, scaffolding, smart, software, step, suppression, systems, talk, technologies, tool, towers, training, علی, عمل, علمكم, علاج, على, عام, عامة, عامه, عاجل, عاجله, عايز, غاز, عيد, عيدكم, عيوب, عيون, عربي, عربية, غريبة, غرفه, عرض, غسالة, عشان, updated, urgently, عواقبها, ظني, عندي, عنوان, عطرة, عقد, welding, wmsd, working, workplace, workrelated, written, فی, فايل, فيديو, فحص, فريضة, فصل, فصل؟؟, فوق, إمكانية, هام, هامة, هذا, هذه, إختبارات, إجراء, إرجاعها, إستخدام, إستفسار, إعادة, إعصار, هنا, هندسيه, إنفجار, إقتراح, ولا, ومساعدة, ومساوىء, وأهميتة, ولو, ومنع, وأكسب, والأمن, والمتطلبات, والمخاطر, والمركبات, والمهندس, والمناجم, والمكتسبات, والا, والاعضاء, والحماية, والخطرة, والزملاء, والسلامة, والسلامه, والصحة, والصحه, والغاز, والوقاية, والقدر, والقضاء, نايميين, واجب, واحد, واحصائيات, واخواتي, وارشادات, وانتم, وبتر, وتجديدها, وبديهتك, ندمج, وجزيتم, ودعوة, وخفيف, وجه, ودورها, ورقة, وسلامة, وصلة, وصلني, وسائل, نصيحة, وزوار, وعلامات, وعاجل, وظائف, وظيفة, نعنوع, نفعة, وإذاكان, وهي, وإصابات, نهني, ونبارك, ونص, نوعية, وضمور, وقصتها, وقوانين, وكل, ضربت, ضعيفه, ضغط, ؟؟؟, طلب, طازج, طبيب, طفايات, قادم, قاعدة, قبل, قيم, قراّن, قسم, قفزة, قواعد, قوانين, قوى, قنينة, قطاع, كلية, كامل, كامله, كتاب, كتب, كثير, كبريتيد, كيابل, كيف, كيفية, كُتب, كهرباثي, كوارث, كود
