هام
مشاهدة نتائج الإستطلاع: لو مدير الشركه نزل الموقع بدون الخوزه
المصوتون
861. أنت لم تصوت في هذا الإستطلاع
  • اتركه
    47 5.46%
  • انصحه بلبسها
    407 47.27%
  • امنعه من نزول الموقع
    354 41.11%
  • اخلع بتاعتى و البسه له
    53 6.16%
صفحة 174 من 219 الأولىالأولى ... 74124164170 171 172 173 174175 176 177 178 184 ... الأخيرةالأخيرة
النتائج 1,731 إلى 1,740 من 2185
  1. [1731]
    مروان البرنس
    مروان البرنس غير متواجد حالياً
    الصورة الرمزية مروان البرنس
    Post Personal Protective Equipment 1
    The Requirements for PPE – A Checklist
    To ensure the greatest possible protection for employees in the workplace, the cooperative efforts of both employers and employees will help in establishing and maintaining a safe and healthy work environment.
    In general, employers are responsible for:
    ___ Performing a “hazard assessment” of the workplace to identify and control hazards.
    ___ Certifying, in writing, completion of a hazard assessment.
    ___ Identifying and providing appropriate PPE for employees.
    ___ Training and retraining employees in the use and care of the PPE.
    ___ Maintaining PPE, including replacing worn or damaged PPE.
    ___ Periodically reviewing, updating and evaluating the effectiveness of the PPE program.
    In general, employees should:
    ___ Properly wear PPE,
    ___ Attend training sessions on PPE,
    ___ Care for, clean and maintain PPE, and
    ___ Inform a supervisor of the need to repair or replace PPE.
  2. [1732]
    مروان البرنس
    Post Personal Protective Equipment 2
    Hazard Assessment And Equipment Selection (3308)
    1. Conduct a workplace survey. Conduct a walk-through survey to identify sources of hazards to feet, head, eyes and face of workers. Reassess whenever a new hazard is introduced into the workplace.
    Care should be taken to recognize the possibility of multiple and simultaneous exposure to a variety of hazards. Adequate protection against the highest level of each of the hazards should be provided.
    Sources
    During the walk-through survey, observe:
    a. Sources of impact/motion; i.e., machinery or processes where any movement of tools, machine elements or particles could exist or movement of personnel that could result in collision with stationary objects;
    b. Sources of high temperatures that could result in burns, eye injury or ignition of protective equipment, etc.;
    c. Types of chemical exposures;
    d. Sources of hazardous atmospheres;
    e. Sources of hazardous radiation, i.e., welding, brazing, cutting, furnaces, heat treating, high intensity lights, etc.;
    f. Sources of falling objects or potential for dropping objects;
    g. Sources of sharp objects which might pierce the feet or cut hands;
    h. Sources of rolling or pinching objects which could crush the feet;
    i. Layout of the workplace and location of co-workers; and
    j. Any electrical hazards.
    • Organize and analyze data. When the walk-through is complete, the employer should organize and analyze the data so that it may be efficiently used in determining the proper types of PPE required at the worksite. The employer should become aware of the different types of PPE available and the levels of protection offered.
    • Select Personal Protective Equipment. Select PPE which ensures a level of protection greater than the minimum required to protect employees from the hazards. PPE that fits well and is comfortable to wear will encourage employee use.
    • Fit the device. If PPE does not fit properly, it can make the difference between being safely covered or dangerously exposed. It may not provide the level of protection desired and may discourage employee use.
    • Reassess hazards. When new equipment and/or processes introduce hazards that might require revised PPE strategies.
  3. [1733]
    مروان البرنس
    Post Personal Protective Equipment 3
    Employers are required to train each employee who must use PPE. Employees must be trained to know at least the following:
    • When PPE is necessary;
    • What PPE is necessary;
    • How to properly put on, take off, adjust and wear the PPE;
    • The limitations of the PPE;
    • Proper care, maintenance, useful life and disposal of PPE;
    • Additional requirements when sharing PPE.
    Employers should make sure that each employee demonstrates an understanding of the PPE training as well as the ability to properly wear and use PPE before they are allowed to perform work requiring the use of PPE. If an employer believes that a previously trained employee is not demonstrating the proper understanding and skill level in the use of PPE, that employee should receive retraining. Other situations that require additional or retraining of employees include changes in the workplace or in the type of required PPE that make prior training obsolete.
    The employer must document the training of each employee required to wear or use PPE by preparing a certification containing the name of each employee trained, the date of training and a clear identification of the subject of the certification.
    Note: See Appendix B1-B4 for sample assessment forms
    Sharing PPE (3313)
    An employer may choose to provide one pair of protective eyewear for each position rather than individual eyewear for each employee. If this is done, the employer must make sure that employees disinfect shared protective eyewear after each use. Protective eyewear with corrective lenses may only be used by the employee for whom the corrective prescription was issued and may not be shared.
    Training Employees In The Proper Use Of PPE (3309)
    See Appendix A for sample certification letter
  4. [1734]
    مروان البرنس
    Post Personal Protective Equipment4
    Eye And Face Protection (3312)
    Employees can be exposed to a large number of hazards that pose danger to their eyes and face. MIOSHA required employers to ensure that employees have appropriate eye or face protection if they are exposed to front and/or side impact hazards from:
    • Flying objects and particles;
    • Molten metal;
    • Liquid chemicals;
    • Acids or caustic liquids;
    • Chemical gases or vapors;
    • Potentially infected material;
    • Glare;
    • Injurious radiation;
    • Electrical flash.
    Selection
    Selecting the most suitable eye and face protection for employees should take into consideration the following elements:
    • Ability to protect against specific workplace hazards;
    • Should fit properly and be reasonably comfortable to wear;
    • Should provide unrestricted vision and movement;
    • Should be durable and cleanable;
    • Should allow unrestricted functioning of any other required PPE.
    The eye and face protection selected for employee use must clearly identify the manufacturer. Any new eye and face protective devices must comply with ANSI Z87.1-1989 or be at least as effective as this standard requires.
    Welding Operations (3312(8))
    The intense light associated with welding operations can cause serious and sometimes permanent eye damage if operators do not wear proper eye protection. The intensity of light or radiant energy produced by welding, cutting or brazing operations varies according to a number of factors including the task producing the light, the electrode size and arc current. Table 2 in Part 33. Personal Protective Equipment shows the minimum protective shades for a variety of welding, cutting and brazing operations in general industry.
  5. [1735]
    مروان البرنس
    Post Personal Protective Equipment 5
    Lenses (3353)
    Lenses intended for use in eye protectors are of 4 basic types.
    • Clear lenses which are impact-resisting and provide protection against flying objects. The use of tinted lenses for cosmetic purposes is not acceptable. Clear lenses must transmit not less than 89% of visible radiation. To wear a tinted lens that transmits less than 89%, a medical statement should be provided.
    • Absorptive lenses of shades 1.7 through 3.0 which are impact-resisting and provide protection against flying objects and glare or which are impact-resisting and provide protection against flying objects, and narrowband spectral transmittance of injurious radiation. Shaded lenses greater than 3.0 should be worn when employees are exposed to injurious radiation as defined in the employer’s hazard assessment and Table 2 of Part 33. Personal Protective Equipment.
    • Protective-corrective lenses which are impact-resisting and either clear or absorptive, as specified for persons requiring visual correction.
    • Filter lenses that are impact resisting and provide protection against flying objects and narrow-band spectral transmittance of injurious radiation.
    Note: See Appendix C for PPE Training Certification
    Note: See Appendix D for Sample Test used to demonstrate understanding
  6. [1736]
    مروان البرنس
    Post Personal Protective Equipment 6
    Head Protection (3370)
    A head injury can impair an employee for life or can be fatal. Protecting employees from potential head injuries by wearing a safety helmet or hardhat is one of the easiest ways to protect an employee’s head from injury.
    Employers must ensure that their employees wear head protection if they are exposed to any of the following:
    • Falling or flying objects;
    • Other harmful contacts or exposures;
    • Risk of injury from electrical shock;
    • Chemicals;
    • Temperature extremes;
    • Hair entanglement.
    Types of Hard Hats:
    • Class A hard hats provide impact and penetration resistance along with limited voltage protection (up to 2,200 volts).
    • Class B hard hats provide the highest level of protection against electrical hazards, with high-voltage shock and burn protection (up to 20,000 volts). They also provide protection from impact and penetration hazards by flying/falling objects.
    • Class D protective hats provide limited voltage protection (fire fighters service helmets with full brim.)
    In Michigan a Class C helmet or any metallic head device shall not be furnished by an employer or used by an employee for head protection, except where chemicals would deteriorate other types of protective or safety hats or caps.
    Hair Enclosures (3378)
    Where there is a danger of hair entanglement in moving machinery or equipment, or where there is exposure to means of ignition, a hat, cap or net shall be used. Hair enclosures shall be reasonably comfortable, completely enclose all loose hair, and be adjustable to accommodate all head sizes. Materials shall be fast dyed and non-irritating to the skin.
    Cleaning and Inspection of Head Protection
    • Inspect daily – shell, suspension headgear, accessories for holes, cracks, tears, anything that compromises the protective value of the hat
    • Consult manufacturer for proper cleaning procedures
    • Store away from direct sunlight
    • Never drill holes, paint, or apply labels, may reduce integrity of protection.
    • Remove and replace if visible perforations, cracking or deformity of brim or shell. Loss of surface gloss, chalking or flaking.
    • Remove if it sustains an impact, even if damage is not noticeable.
  7. [1737]
    مروان البرنس
    Post Personal Protective Equipment 7
    Foot and Leg Protection (3383)
    Employees who face possible foot or leg injuries from falling or rolling objects or from crushing or penetrating materials should wear protective footwear. Also, employees whose work involves exposure to hot substances, corrosive, or poisonous materials must have protective gear to cover exposed body parts, including legs and feet. If an employee’s feet may be exposed to electrical hazards, non-conductive footwear should be worn. On the other hand, workplace exposure to static electricity may necessitate the use of conductive footwear.
    Examples of situations in which an employee should wear foot and/or leg protection include:
    • When heavy objects such as barrels or tools might roll onto or fall on the employee’s feet;
    • Working with sharp objects such as nails or spikes that could pierce the soles or uppers of ordinary shoes;
    • Exposure to molten metal that might splash on feet or legs (see Parts 42-Forging, 44-Foundries, and 45-Die Casting for specific requirements);
    • Working on or around hot, wet or slippery surfaces; and
    • Working when electrical hazards are present.
    Foot and leg protection choices include the following:
    • Safety shoes have impact-resistant toes and heat-resistant soles that protect the feet against hot work surfaces common in roofing, paving and hot metal industries. The metal insoles of some safety shoes protect against puncture sounds. Safety shoes may also be designed to be electrically conductive to prevent buildup of static electricity or non conductive to protect workers from workplace electrical hazards.
    • Leggings protect the lower legs and feet from heat hazards such as molten metal or welding sparks.
    • Metatarsal guards protect the instep from impact and compression.
    • Toe guards fit over the toes of regular shoes to protect the toes from impact and compression hazards.
  8. [1738]
    مروان البرنس
    Post Personal Protective Equipment 8
    Hand And Arm Protection (3392)
    Where potential injury to hands and arms cannot be eliminated through engineering and work practice controls, employers must ensure that employees wear appropriate protection. Potential hazards include:
    • Skin absorption of harmful substances (look for ‘skin’ warning on MSDS);
    • Chemical or thermal burns;
    • Electrical dangers; and
    • Bruises, abrasions, cuts, punctures.
    Types of Protective Gloves
    There are many types of gloves available today to protect against a wide variety of hazards. Following are examples of some factors that may influence the selection of protective gloves for a workplace:
    • Types of chemicals handled;
    • Nature of contact (total immersion, splash, etc.);
    • Duration of contact;
    • Area requiring protection (hand only, forearm, arm);
    • Grip requirements (dry, wet, oily);
    • Thermal protection;
    • Size and comfort;
    • Abrasion/resistance requirements.
    Gloves made from a wide variety of materials are designed for many types of workplace hazards. In general, gloves fall into four groups:
    • Gloves made of leather, canvas, or metal mesh;
    • Fabric and coated fabric gloves;
    • Chemical--and liquid--resistant gloves;
    • Insulating rubber gloves (see 3385).
    Care of Protective Gloves
    • Inspect before each use (tears, punctures, anything making gloves ineffective, discoloration, stiffness);
    • Discard if protective ability is impaired.
  9. [1739]
    مروان البرنس
    Post Personal Protective Equipment 9
    Safety Belts, Harnesses, Lifelines, And Lanyards (3390)
    Unless protected by a perimeter guardrail or working on a portable ladder, the employee must be safe guarded by a safety harness secured to a lifeline or structure capable of sustaining the imposed load. However, there are conditions where the use of a harness and lanyard would be required along with a guardrail, such as in aerial lift or scaffold.
    • If subjected to in-service loading, remove from service and don’t use again;
    • Safety belt and lanyard - 4,000 pounds of tensile load;
    • Lifeline secured above the employee’s workplace to an anchorage or structural member – withstand dead weight of 5,400 pounds;
    • A lifeline at least ¾-inch manila rope or equivalent with not less than 5,400 foot-pounds breaking strength;
    • A lanyard at least ½ inch nylon rope or equivalent;
    • Free fall – less than 6 feet or no contact with lower surface;
    • Store equipment in clean, dry area and away from excessive heat and freezing.
    Note: See Appendix E for PPE Assignment, Training and Fit List Form
    See Appendix F for PPE Policy
    Appendix A-1
    Certification of
    Safety-Related
    Hazard Assessment
    Employer: _________________________________________________
    Location*: _________________________________________________
    *Or type of work for employees not assigned to a fixed location
    Workplace _________________________________________________
    Assessed/
    Evaluated: _________________________________________________
    Date(s): _________________________________________________
    Name of Person _________________________________________________
    Assessing/
    This document certifies that the hazard assessment has been performed as required by MIOSHA General Industry Safety Standards, Part 33, Personal Protective Equipment.
    Signature of
    Person Certifying: __________________________________________________
  10. [1740]
    مروان البرنس
    Post Personal Protective Equipment 10
    Personal Protective Equipment Types
    Face and Eye Protection
    Welding Helmets
    Head Protection
    Spectacles w/
    No side shield
    Half side shield
    Full side shield
    Detachable side shield
    Non-removable lens
    Lift front
    Headband temple
    Cover goggles w/
    No ventilation
    Indirect ventilation
    Direct ventilation
    Cut goggles w/
    Direct ventilation
    Face Shield
    (See MIOSHA, General Industry Safety Standard Part 33, Personal Protective Equipment, Table 1)
    Burning Goggles
    Welding Helmets w/
    Stationary window
    Lift front window
    Hand held
    (See MIOSHA, General Industry Safety Standard, Part 33, Personal Protective Equipment, Table 2)
    Helmets by Type:
    Type 1: Full brim 1.25” side
    Type 2: No brim, forward peak
    Helmets by Class:
    Class A – General service w/limited voltage protection
    Class B – Utility service w/high voltage protection
    Class C – Special service
    No voltage protection
    Class D – Fire fighters full brim w/ear flaps and chin strap
    Hair enclosures
    Foot and Leg
    Electrical Protection*
    Fall Protection
    Safety shoes/boots w/
    Impact resistant toe
    Metal insoles
    Metatarsal guards
    Chemical Resistant
    Electrical protection
    Wet slippery surfaces
    Cold weather protection
    Leggings
    Molten metal and welding
    Insulating Blankets
    Matting
    Covers
    Line Hose
    Gloves
    Sleeves
    Hot Stick
    *Must be capable of withstanding imposed voltage
    Safety Belts*
    Safety harnesses
    Lifelines
    Lanyards
    *No safety belts for fall protection after 1-1-98.
    Arm and Hand Protection
    Body Protection
    Types
    Gloves
    Hand Pads
    Sleeves
    Wristlets
    Types
    Vests
    Jackets
    Aprons
    Coveralls
    Full Body Suits
2005, 2007, للأمن, للأخ, للمحترفى, للأخوة, للمشاركة, للمعدات, للمناقشه, للمنفعة, لماذا, للافادة, ممتاز, للتدريب, للجميع, لمحة, للخبراء, للخدمة, للحجاج, للحريق, للحوادث, للدكتور, للرجل, للزملاء, للسلالم, للسادة, للسائقين, لمشاكل, للشركات, ملصقات, للعمل, للعاملين, للغياب, ملف, ملفات, لله, لأهل, للإجابة, لمن, لمؤتمر, لمنتدى, للنيبوش, للوقاية, ممكن, مال, accident, مادة, لايحدث, لاخوانى, ماهي, ماهر, ماهو, مائية, لذوي, مبادئ, آثار, أبحث, متخصصي, متخصصه, مبروك, لبناء, متواضعة, أحمد, لجميع, مجمع, مجموعة, مجموعه, أيام, محاضرات, محاضرة, مخاطر, محتاج, أختبار, ميدان, لدية, محددة, لدينا, مخخط, أجرا, لحرارة, أخرى, محصلة, ميزانية, محسن, آيه, أجهزة, لخطوط, amounia, أرامكو, مراجع, مراجعة, مراقبة, مرحبا, أريد, أرجو, مروري, مشاركة, مساعدة, مساعدةعن, مساعده, مساويء, مستعجلة, مستقبل, مصر, مشروع, أسفل, لصناعة, أسناني؟؟, aramco, arrest, assessment, لعمل, أعمال, أغلب, معلومات, معلوماته, أغرب, معرض, أعضاء, مفیده, أفلام, أفادكم, أفيدوني, أهم, أهمية, مهمه, مهام, مهامها, لإيجاد, لإظهار, مهنية, مهندس, مهندسي, مهندسين, مواصفة, مناعة, مواضيع, مواقع, منتدى, منير, منَ, منزلك, أنشاء, أنزور, لنغير, منظومات, أنواع, موضوع, موضوعين, موقع, منكم, أطلب, لطلبة, مطلوب, مطلوبه, مطب, لطيف, مقال, مقتل, أقتراح, مقدمه, لكم, مكافحة, مكان, لكتاب, لكن, bloodborne, boox, box, building, الیکم, الأ, الملتقى, المميزة, المميزين, الأمراض, الأمن, المايكروويف, المذكور, المجالات, المياه, المخاطر, الأحبةاحتاج, الأجهزة, الأخوات, المدنية؟, الميكانيكية, المراكز, المساحية, المشاركات, المشاركة, الأساسية, المساعدة, المساهمه, المستخدمة, المستشفيات, المستودعات, المصرى, الأسنان, المعادن, المعدنية, الله, المهنیه, المهنية, المهندس, المهنيه, الآن, الأولى, المواد, المواضيع, الموبايل, المنتج, المنتدى, المنشأ, المنشآت, الأوشا, الأنظمة, الموعد, الأنفاق, اللون, الموضوع, الموقع, المطارات, الأطباء, المقاولات, المكاتب, الامريكية, الامن, الامن والسلامة, الالوان, الامنة, الالكترونيه, الاباء, الاتصالات, الاخ, الاحمال, الاحتياجات, الاحتراز, الاخرى, الايزو, الاخوة, الاخوه, الارتفاعات, الاستاذ, الاستاتيكيه, الاستخدام, الاستشاريه, الاسعافات, الاسنان, الاعزاء, الاولية, الانابيب, الاوسط, الانضمام, الاضافات, الاطفال, البلاتينية, البلاستيكية, البلدان, التميز, التأريض, البترول, البترولية, التي, البخارية, البديل, التدخين, التحيه, البيئة, البيئه, التدقيق, البرق, التشييد, البصرية, التصوير, التعرض, البناء, التواصل, التكييف, الى, الحل, الحماية, الحمايه, الجميع, الجامعة, الخاصه, الحرائق, الحريق, الحروق؟نصيحة, الجزائر, الجزائرية, الجزير, الحصول, الدعوة, الحفاظ, الحفر, اليه, الدولية, الجوااااااال, الحوادث, الجوجل, الجويه, الدورة, الخطره, الnasp, الري, الرجل, الرعد, السیطره, السلالم, السلامة, السلامةو, السلامه, الشمس, السمعية, السالب, السابقة, الصاج, السبت, السياره, الصداقة, الصحة, الصحي, السيجارة, الزيركون, الشخصية, الشده, السرعات, السرعه, الصرف, الشرق, الشرقية, الosha, الصعود, السعودية, السفن, الصناعي, الصناعية, الصواعق, السويس, السطحية, الزقازيق, السقوط, الشكر, carbon, الrisk, العلم, العليا, العالم, العالمين, العامة, العالي, العامه, الغازات, الغرب, العربي, العربية, الظهر, العواصف, العضلات, الغضب, الفتلة, الـتأهيلية, الفياغرا, الفرق, الفنية, الهيدروجين, الإخوة, الهواء, الهندي, الهندسة, الهندسية, الإطارات, الناس, النيبوش, الوصول, الوظفيه, الوطنية, الوقاية, الوقائي, الضغظ, الضغط, الکتاب, الطائره, الطبيعية, الطيور, الطريق, الطرق, القلب, القاهرة, القيادة, القوانين, القوى, القطع, الكيميائية, الكرام, الكهرمغناطيسية, الكهرباء, الكهربائة, الكوارث, certified, اثناء, احمد, ادارة, اجازه, اختبر, ادخل, اجهزة, اخوات, اخواني, اريد, ارجو, ارجوكم, ارشادات, اسمله, اصابات, ازاى, استجابة, استخدام, استعمال, استعمالها, استفاده, استفسار, اسبوع, color, construction, consultant, crane, اعمال, اعادة, اعتذار, اعتقد, اعدادى, اعرف, افلام, افتتاح, افيضو, اهمال, اولا, اولى, انا, انترسيك, انجليزي, انشا, انقذوا, اطفالنا, اقتراح, اقتراحي, اكثر, data, databaseprogram, ذلك, design, dioxide, dtm, تأثير, تلوث, تموج, بمنطقة, بالمملكة, بالمتندي, بالأشعة, بالمواد, بالسلامة, بالسيارات, بالسعودية, بالصور, بالعيد, تتخلص, تبين, بترول, بدأ, تخلى, تحليل, بجميع, بجمهورية, بجامعة, تجاهل, بيانات, تحذير, بدت, بحثيه, تحبني, تحية, تحديد, بخير, بخصوص, بيسط, تجهيزات, بين, بحوث, بدون, engineering, ترددات, environmental, برنامج, تسمحو, بشأن, تساؤل, بسبب, تزيد, تشخيص, بسيط, تسرب, بشرح, تشريعات, بسررررعة, equipment, تعمل, تعليمات, تعال, تعبئة, بعد, تعيل, بعنوان, تعقدها, exam, excavation, تهبط, تهنئه, توجيهية, توضيحية, تنكات, تطبيقي, ثقافة, تقديم, تقرير, بقواعد, تقنية, تكساس2008, تكنب, facilities, fall, finding, fire, flash, food, free, gas, green, h2s, hazards, hazwoper, health, hose, hscode, hse, hsems, حماية, دمج, جميل, حمدى, جمعيات, حلو, يالله, خالد, يامهندسين, يالقاهرة, داخل, ياجماعه, حاجة, حادثة, خاصة, خاصه, خاطر, جدا, جداً, يجب, يجيبني, خيرا, يحوز, يحقق, ilo, impact, important, imroving, incident, دراسه, indicators, حريق, injury, inspector, investigation, جسم, حساب, يساعد, يستر, يشرح, items, دعابه, دعوة, يعود, دعوه, يعقل, حفر, حول, حولتطبيقات, حولنا, حوادث, يؤثر, يوجد, دور, دورات, دوران or استخلاص, دورة, دورتي, دوره, يضم, خطة, خطير, خطر, خطط, حكايتكم, layout, lifiting, lockout or tagout, lockouttagout, lpg, lti, managmen, msds, msha, mus, رأيكم, nasp, راجعون, nebosh, newly, ربنا, nffss, nfpa12, nfssi, رجاء, noise, سلام, سلامة, سمحتم, سمحتم؟, سمعك, شاملة, سارة, ساعات, ساعدوني, سبل, سببها, ستفقدة, صيام, سيارتك, صيانة, سيد, سيجارة, زراعة, شرعية, شركات, شركة, osha, oshas, صغير, شهادات, سوال, سؤالى, صناعي, شوب, صور, سوف, سطح, شكر, performance, personal, planet, point, pollution, powerpoint, presentation, presentations, procedures, process, professional, program, protection, protective, register, related, required, risk, rso, safe, safely, safety, safty, sample, sayed00, scaffold, scaffolding, smart, software, step, suppression, systems, talk, technologies, tool, towers, training, علی, عمل, علمكم, علاج, على, عام, عامة, عامه, عاجل, عاجله, عايز, غاز, عيد, عيدكم, عيوب, عيون, عربي, عربية, غريبة, غرفه, عرض, غسالة, عشان, updated, urgently, عواقبها, ظني, عندي, عنوان, عطرة, عقد, welding, wmsd, working, workplace, workrelated, written, فی, فايل, فيديو, فحص, فريضة, فصل, فصل؟؟, فوق, إمكانية, هام, هامة, هذا, هذه, إختبارات, إجراء, إرجاعها, إستخدام, إستفسار, إعادة, إعصار, هنا, هندسيه, إنفجار, إقتراح, ولا, ومساعدة, ومساوىء, وأهميتة, ولو, ومنع, وأكسب, والأمن, والمتطلبات, والمخاطر, والمركبات, والمهندس, والمناجم, والمكتسبات, والا, والاعضاء, والحماية, والخطرة, والزملاء, والسلامة, والسلامه, والصحة, والصحه, والغاز, والوقاية, والقدر, والقضاء, نايميين, واجب, واحد, واحصائيات, واخواتي, وارشادات, وانتم, وبتر, وتجديدها, وبديهتك, ندمج, وجزيتم, ودعوة, وخفيف, وجه, ودورها, ورقة, وسلامة, وصلة, وصلني, وسائل, نصيحة, وزوار, وعلامات, وعاجل, وظائف, وظيفة, نعنوع, نفعة, وإذاكان, وهي, وإصابات, نهني, ونبارك, ونص, نوعية, وضمور, وقصتها, وقوانين, وكل, ضربت, ضعيفه, ضغط, ؟؟؟, طلب, طازج, طبيب, طفايات, قادم, قاعدة, قبل, قيم, قراّن, قسم, قفزة, قواعد, قوانين, قوى, قنينة, قطاع, كلية, كامل, كامله, كتاب, كتب, كثير, كبريتيد, كيابل, كيف, كيفية, كُتب, كهرباثي, كوارث, كود
