هام
مشاهدة نتائج الإستطلاع: لو مدير الشركه نزل الموقع بدون الخوزه
المصوتون
861. أنت لم تصوت في هذا الإستطلاع
  • اتركه
    47 5.46%
  • انصحه بلبسها
    407 47.27%
  • امنعه من نزول الموقع
    354 41.11%
  • اخلع بتاعتى و البسه له
    53 6.16%
صفحة 173 من 219 الأولىالأولى ... 73123163169 170 171 172 173174 175 176 177 183 ... الأخيرةالأخيرة
النتائج 1,721 إلى 1,730 من 2185
  1. [1721]
    مروان البرنس
    مروان البرنس غير متواجد حالياً
    الصورة الرمزية مروان البرنس
    Post construction safety program 19
    CONFINED SPACE ENTRY
    No employee shall enter areas defined below without authorization:
    1. A space that is NOT DESIGNED FOR CONTINUOUS employee OCCUPANCY;
    and
    2. Is large enough and so configured that a person can bodily enter into and perform
    assigned work; and
    3. Has LIMITED or RESTRICTED means for ENTRY or EXIT; and
    4. May have a POSSIBLE HAZARDOUS ATMOSPHERE that may expose
    employees to the risk of death, incapacitation, impairment of ability to self rescue
    caused by:
    A. Flammable gas
    B. Airborne combustible dust
    C. Atmospheric oxygen concentration below 19.5 or above 23.5%
    D. A toxic atmosphere or substance
    E. Danger of engulfment
    UNTIL AN AUTHORIZED PERSON EVALUATES THE AREA AND AUTHORIZES ENTRY.
  2. [1722]
    مروان البرنس
    Post construction safety program 20
    GENERAL CONFINED SPACE ENTRY PROCEDURE
    1. There shall be no unauthorized entry into a confined space by any person.
    2. An authorized person shall examine, test and evaluate a potential entry space and
    determine if it is a "NON-PERMIT SPACE" and meets the following requirements:
    A. It does NOT contain any atmospheric hazards or dangers of engulfment
    capable of causing death or serious physical harm;
    B. The space has been PROVEN SAFE, has been VERIFIED, DOCUMENTED,
    and has a CERTIFIED GUARANTEE of a safe environment.
    3. If the conditions in #2 have been satisfied, the ALTERNATE ENTRY
    PROCEDURE may be followed.
    4. If conditions in #2 are not met and has any of the following, the PERMIT ENTRY
    PROCEDURE must be followed:
    THE SPACE:
    A. Contains or has a potential to contain a HAZARDOUS ATMOSPHERE.
    B. Contains a material that has a potential for ENGULFING an entrant.
    C. Has an internal configuration such that an entrant could be trapped or
    asphyxiated by inwardly converging wall or by a floor which slopes
    downward and tapers to a smaller cross section; or
    D. Contains any other recognized serious safety or health hazard.
  3. [1723]
    مروان البرنس
    Post construction safety program 21
    EMERGENCY PROCEDURES
    In case of an emergency on site the following procedures should be instituted at each site:
    1. Method of communication should be determined at each site, telephone, radio, etc.
    2. Emergency telephone numbers should be posted:
    a. Police
    b. Fire
    c. Medical Response Team
    3. Post near communication station the address of your site.
    4. Post names of first aid responders on site.
    5. Designate person to direct emergency crews to site of emergency.
    6. Instruction to each employee if known harmful plants, reptiles, animals, or insects,
    are present regarding all of the following:
    a.The potential hazards.
    b. How to avoid injury.
    c.Applicable first aid procedures to be used in the event of injury.
  4. [1724]
    مروان البرنس
    Post construction safety program 22
    CARING FOR BITES AND STINGS
    Insect Bites
    Spider Bite /
    Scorpion Sting
    Marine Life Stings
    Snake Bites
    Animal Bites
    Signals
    Stinger may be present
    Pain
    Swelling
    Possible allergic reaction
    Bite Mark
    Swelling
    Pain
    Nausea and vomiting
    Difficulty breathing or swallowing
    Possible marks
    Pain
    Swelling
    Bite Mark
    Pain
    Bite Mark
    Bleeding
    Care
    Remove stinger – scrape it away or use tweezers
    Wash wound
    Cover
    Apply a cold pack
    Watch for signals of allergic reaction
    Wash wound
    Apply a cold pack
    Get medical care to receive antivenin
    Call local emergency number, if necessary
    Initially, soak area in salt water
    Apply cold pack or paste of baking soda or meat tenderizer
    Wash wound
    Keep bitten part still, and lower than the heart
    If bleeding is minor – wash wound
    Control bleeding
    Apply antibiotic ointment
    Cover
    Get medical attention if wound bleeds severely or if you suspect animal has rabies
    Call local emergency number or contact animal control personnel
  5. [1725]
    مروان البرنس
    Post construction safety program 23
    WRITTEN HAZARD COMMUNICATION PROGRAM
    GENERAL
    The following hazard communication program has been established for .
    This program will be available for review by all employees.
    I. HAZARD DETERMINATION
    will be relying on Material Safety Data Sheets from suppliers to meet determination requirements.
    II. LABELING
    A. The will be responsible for seeing that all
    containers coming in are properly labeled.
    B. All labels shall be checked for:
    1. Identity
    2. Hazard
    3. Name and address of responsible party
    C. Each shall be responsible for seeing that all portable containers used in their work areas are labeled with identity and hazard warning.
  6. [1726]
    مروان البرنس
    construction safety program 24
    III. MATERIAL SAFETY DATA SHEETS (MSDS)
    A. The will be responsible for compiling the
    master MSDS file. It will be kept .
    B. Copies of MSDSs for all hazardous chemicals to which employees may be
    exposed will be kept in a file at .
    C. MSDSs will be available for review to all employees during each work shift.
    Copies will be available upon request to .
    D. The will be provided with the required
    MIOSHA Right-To-Know posters and postings notifying employees of new or
    revised MSDSs within five (5) days of receipt of new or revised MSDSs.
  7. [1727]
    مروان البرنس
    construction safety program 25
    IV. EMPLOYEE INFORMATION TRAINING
    A. The shall coordinate and maintain
    records of training conducted for .
    B. Before starting work, or as soon as possible thereafter, each new employee
    will attend a safety class. In that class, each employee will be given
    information on:
    1. Chemicals and their hazards in the workplace.
    2. How to lessen or prevent exposure to these chemicals.
    3. What the company has done to lessen or prevent workers' exposure to
    these chemicals.
    4. Procedures to follow if they are exposed.
    5. How to read and interpret labels and MSDSs.
    6. Where to locate MSDSs and from whom they may obtain copies.
    C. The employee will be informed that:
    1. The employer is prohibited from discharging, or discriminating against,
    an employee who exercises the rights regarding information about
    hazardous chemicals in the workplace.
    2. As an alternative to requesting an MSDS from the employer the
    employee may obtain a copy from the Department of Public Health.
    D. Attendance will be taken at training sessions. These records will be kept by
    E. Before any new hazardous chemical is introduced into the workplace, each
    employee will be given information in the same manner as during the safety
    class.
  8. [1728]
    مروان البرنس
    Post construction safety program 26
    V. HAZARDOUS NON-ROUTINE TASKS (Delete entire section if not applicable)
    A. On occasion, employees are required to do work in hazardous areas (e.g. confined spaces). Prior to starting work in such areas, each employee will be given information about the hazards involved in these areas.
    This information will include:
    1. Specific chemical hazards.
    2. Protection/safety measures the employee is required to take to lessen
    risks.
    3. Measures the company has taken to lessen the hazards, including
    ventilation, respirators, the presence of another employee, and
    emergency procedures.
    B. It is the policy of that no employee will begin
    work in a confined space, or any non-routine task, without first receiving a
    safety briefing.
  9. [1729]
    مروان البرنس
    Post construction safety program 27
    VI. INFORMING CONTRACTORS
    A. It is the responsibility of the to provide any
    other contractors with employees exposed to our chemicals with the following
    information:
    1. Hazardous chemicals with which they may come in contact.
    2. Measures the employees should take to lessen the risks.
    3. Where to get MSDSs for all hazardous chemicals.
    B. It is the responsibility of the to obtain
    chemical information from contractors when they will expose our employees
    to hazardous chemicals which they may bring into our workplace.
    VII. PIPE AND PIPING SYSTEMS
    A. Information on the hazardous *******s of pipe and piping shall be readily
    available
    __________________________________________________ __________________
    VIII. LIST OF HAZARDOUS CHEMICALS
    This is a list of the chemicals used by _________________________________.
    MATERIAL (Name on label and MSDS) Page of ______
  10. [1730]
    مروان البرنس
    Personal Protective Equipment
    Safety-Related Personal Protective Equipment
    General Industry
    Introduction
    Hazards exist in every workplace in many different forms: sharp edges, falling objects, flying sparks, chemicals, noise and a myriad of other potentially dangerous situations.
    Controlling a hazard at its source is the best way to protect employees. When engineering, work practice and administrative controls can’t protect employees, employers must provide personal protective equipment (PPE) to their employees and ensure its use. PPE is equipment worn to minimize exposure to a variety of hazards.
    This guide will help both employers and employees do the following:
    • Understand the types of PPE.
    • Know the basics of conducting a “hazard assessment” of the workplace.
    • Select appropriate PPE for a variety of circumstances.
    • Understand what kind of training is needed in the proper use and care of PPE.
    The information in this guide is general in nature and does not address all workplace hazards or PPE requirements. The information, methods and procedures are based on the MIOSHA requirements for PPE as set forth in Part 33. Personal Protective Equipment and Part 380. Noise Exposure.
2005, 2007, للأمن, للأخ, للمحترفى, للأخوة, للمشاركة, للمعدات, للمناقشه, للمنفعة, لماذا, للافادة, ممتاز, للتدريب, للجميع, لمحة, للخبراء, للخدمة, للحجاج, للحريق, للحوادث, للدكتور, للرجل, للزملاء, للسلالم, للسادة, للسائقين, لمشاكل, للشركات, ملصقات, للعمل, للعاملين, للغياب, ملف, ملفات, لله, لأهل, للإجابة, لمن, لمؤتمر, لمنتدى, للنيبوش, للوقاية, ممكن, مال, accident, مادة, لايحدث, لاخوانى, ماهي, ماهر, ماهو, مائية, لذوي, مبادئ, آثار, أبحث, متخصصي, متخصصه, مبروك, لبناء, متواضعة, أحمد, لجميع, مجمع, مجموعة, مجموعه, أيام, محاضرات, محاضرة, مخاطر, محتاج, أختبار, ميدان, لدية, محددة, لدينا, مخخط, أجرا, لحرارة, أخرى, محصلة, ميزانية, محسن, آيه, أجهزة, لخطوط, amounia, أرامكو, مراجع, مراجعة, مراقبة, مرحبا, أريد, أرجو, مروري, مشاركة, مساعدة, مساعدةعن, مساعده, مساويء, مستعجلة, مستقبل, مصر, مشروع, أسفل, لصناعة, أسناني؟؟, aramco, arrest, assessment, لعمل, أعمال, أغلب, معلومات, معلوماته, أغرب, معرض, أعضاء, مفیده, أفلام, أفادكم, أفيدوني, أهم, أهمية, مهمه, مهام, مهامها, لإيجاد, لإظهار, مهنية, مهندس, مهندسي, مهندسين, مواصفة, مناعة, مواضيع, مواقع, منتدى, منير, منَ, منزلك, أنشاء, أنزور, لنغير, منظومات, أنواع, موضوع, موضوعين, موقع, منكم, أطلب, لطلبة, مطلوب, مطلوبه, مطب, لطيف, مقال, مقتل, أقتراح, مقدمه, لكم, مكافحة, مكان, لكتاب, لكن, bloodborne, boox, box, building, الیکم, الأ, الملتقى, المميزة, المميزين, الأمراض, الأمن, المايكروويف, المذكور, المجالات, المياه, المخاطر, الأحبةاحتاج, الأجهزة, الأخوات, المدنية؟, الميكانيكية, المراكز, المساحية, المشاركات, المشاركة, الأساسية, المساعدة, المساهمه, المستخدمة, المستشفيات, المستودعات, المصرى, الأسنان, المعادن, المعدنية, الله, المهنیه, المهنية, المهندس, المهنيه, الآن, الأولى, المواد, المواضيع, الموبايل, المنتج, المنتدى, المنشأ, المنشآت, الأوشا, الأنظمة, الموعد, الأنفاق, اللون, الموضوع, الموقع, المطارات, الأطباء, المقاولات, المكاتب, الامريكية, الامن, الامن والسلامة, الالوان, الامنة, الالكترونيه, الاباء, الاتصالات, الاخ, الاحمال, الاحتياجات, الاحتراز, الاخرى, الايزو, الاخوة, الاخوه, الارتفاعات, الاستاذ, الاستاتيكيه, الاستخدام, الاستشاريه, الاسعافات, الاسنان, الاعزاء, الاولية, الانابيب, الاوسط, الانضمام, الاضافات, الاطفال, البلاتينية, البلاستيكية, البلدان, التميز, التأريض, البترول, البترولية, التي, البخارية, البديل, التدخين, التحيه, البيئة, البيئه, التدقيق, البرق, التشييد, البصرية, التصوير, التعرض, البناء, التواصل, التكييف, الى, الحل, الحماية, الحمايه, الجميع, الجامعة, الخاصه, الحرائق, الحريق, الحروق؟نصيحة, الجزائر, الجزائرية, الجزير, الحصول, الدعوة, الحفاظ, الحفر, اليه, الدولية, الجوااااااال, الحوادث, الجوجل, الجويه, الدورة, الخطره, الnasp, الري, الرجل, الرعد, السیطره, السلالم, السلامة, السلامةو, السلامه, الشمس, السمعية, السالب, السابقة, الصاج, السبت, السياره, الصداقة, الصحة, الصحي, السيجارة, الزيركون, الشخصية, الشده, السرعات, السرعه, الصرف, الشرق, الشرقية, الosha, الصعود, السعودية, السفن, الصناعي, الصناعية, الصواعق, السويس, السطحية, الزقازيق, السقوط, الشكر, carbon, الrisk, العلم, العليا, العالم, العالمين, العامة, العالي, العامه, الغازات, الغرب, العربي, العربية, الظهر, العواصف, العضلات, الغضب, الفتلة, الـتأهيلية, الفياغرا, الفرق, الفنية, الهيدروجين, الإخوة, الهواء, الهندي, الهندسة, الهندسية, الإطارات, الناس, النيبوش, الوصول, الوظفيه, الوطنية, الوقاية, الوقائي, الضغظ, الضغط, الکتاب, الطائره, الطبيعية, الطيور, الطريق, الطرق, القلب, القاهرة, القيادة, القوانين, القوى, القطع, الكيميائية, الكرام, الكهرمغناطيسية, الكهرباء, الكهربائة, الكوارث, certified, اثناء, احمد, ادارة, اجازه, اختبر, ادخل, اجهزة, اخوات, اخواني, اريد, ارجو, ارجوكم, ارشادات, اسمله, اصابات, ازاى, استجابة, استخدام, استعمال, استعمالها, استفاده, استفسار, اسبوع, color, construction, consultant, crane, اعمال, اعادة, اعتذار, اعتقد, اعدادى, اعرف, افلام, افتتاح, افيضو, اهمال, اولا, اولى, انا, انترسيك, انجليزي, انشا, انقذوا, اطفالنا, اقتراح, اقتراحي, اكثر, data, databaseprogram, ذلك, design, dioxide, dtm, تأثير, تلوث, تموج, بمنطقة, بالمملكة, بالمتندي, بالأشعة, بالمواد, بالسلامة, بالسيارات, بالسعودية, بالصور, بالعيد, تتخلص, تبين, بترول, بدأ, تخلى, تحليل, بجميع, بجمهورية, بجامعة, تجاهل, بيانات, تحذير, بدت, بحثيه, تحبني, تحية, تحديد, بخير, بخصوص, بيسط, تجهيزات, بين, بحوث, بدون, engineering, ترددات, environmental, برنامج, تسمحو, بشأن, تساؤل, بسبب, تزيد, تشخيص, بسيط, تسرب, بشرح, تشريعات, بسررررعة, equipment, تعمل, تعليمات, تعال, تعبئة, بعد, تعيل, بعنوان, تعقدها, exam, excavation, تهبط, تهنئه, توجيهية, توضيحية, تنكات, تطبيقي, ثقافة, تقديم, تقرير, بقواعد, تقنية, تكساس2008, تكنب, facilities, fall, finding, fire, flash, food, free, gas, green, h2s, hazards, hazwoper, health, hose, hscode, hse, hsems, حماية, دمج, جميل, حمدى, جمعيات, حلو, يالله, خالد, يامهندسين, يالقاهرة, داخل, ياجماعه, حاجة, حادثة, خاصة, خاصه, خاطر, جدا, جداً, يجب, يجيبني, خيرا, يحوز, يحقق, ilo, impact, important, imroving, incident, دراسه, indicators, حريق, injury, inspector, investigation, جسم, حساب, يساعد, يستر, يشرح, items, دعابه, دعوة, يعود, دعوه, يعقل, حفر, حول, حولتطبيقات, حولنا, حوادث, يؤثر, يوجد, دور, دورات, دوران or استخلاص, دورة, دورتي, دوره, يضم, خطة, خطير, خطر, خطط, حكايتكم, layout, lifiting, lockout or tagout, lockouttagout, lpg, lti, managmen, msds, msha, mus, رأيكم, nasp, راجعون, nebosh, newly, ربنا, nffss, nfpa12, nfssi, رجاء, noise, سلام, سلامة, سمحتم, سمحتم؟, سمعك, شاملة, سارة, ساعات, ساعدوني, سبل, سببها, ستفقدة, صيام, سيارتك, صيانة, سيد, سيجارة, زراعة, شرعية, شركات, شركة, osha, oshas, صغير, شهادات, سوال, سؤالى, صناعي, شوب, صور, سوف, سطح, شكر, performance, personal, planet, point, pollution, powerpoint, presentation, presentations, procedures, process, professional, program, protection, protective, register, related, required, risk, rso, safe, safely, safety, safty, sample, sayed00, scaffold, scaffolding, smart, software, step, suppression, systems, talk, technologies, tool, towers, training, علی, عمل, علمكم, علاج, على, عام, عامة, عامه, عاجل, عاجله, عايز, غاز, عيد, عيدكم, عيوب, عيون, عربي, عربية, غريبة, غرفه, عرض, غسالة, عشان, updated, urgently, عواقبها, ظني, عندي, عنوان, عطرة, عقد, welding, wmsd, working, workplace, workrelated, written, فی, فايل, فيديو, فحص, فريضة, فصل, فصل؟؟, فوق, إمكانية, هام, هامة, هذا, هذه, إختبارات, إجراء, إرجاعها, إستخدام, إستفسار, إعادة, إعصار, هنا, هندسيه, إنفجار, إقتراح, ولا, ومساعدة, ومساوىء, وأهميتة, ولو, ومنع, وأكسب, والأمن, والمتطلبات, والمخاطر, والمركبات, والمهندس, والمناجم, والمكتسبات, والا, والاعضاء, والحماية, والخطرة, والزملاء, والسلامة, والسلامه, والصحة, والصحه, والغاز, والوقاية, والقدر, والقضاء, نايميين, واجب, واحد, واحصائيات, واخواتي, وارشادات, وانتم, وبتر, وتجديدها, وبديهتك, ندمج, وجزيتم, ودعوة, وخفيف, وجه, ودورها, ورقة, وسلامة, وصلة, وصلني, وسائل, نصيحة, وزوار, وعلامات, وعاجل, وظائف, وظيفة, نعنوع, نفعة, وإذاكان, وهي, وإصابات, نهني, ونبارك, ونص, نوعية, وضمور, وقصتها, وقوانين, وكل, ضربت, ضعيفه, ضغط, ؟؟؟, طلب, طازج, طبيب, طفايات, قادم, قاعدة, قبل, قيم, قراّن, قسم, قفزة, قواعد, قوانين, قوى, قنينة, قطاع, كلية, كامل, كامله, كتاب, كتب, كثير, كبريتيد, كيابل, كيف, كيفية, كُتب, كهرباثي, كوارث, كود
