افضل برنامج في الرسم الميكانيكي وخاصه الثلاثي الابعاد
مشاهدة نتائج الإستطلاع: ما هو افضل برنامج رسم ميكانيكي؟
المصوتون
694. أنت لم تصوت في هذا الإستطلاع
  • Auto Cad Mechanical
    184 26.51%
  • Catia
    86 12.39%
  • Solid Work
    260 37.46%
  • Solid Edge
    28 4.03%
  • Invintor
    79 11.38%
  • Sketch Up
    7 1.01%
  • Pro Enginner
    35 5.04%
  • Others
    15 2.16%
صفحة 12 من 15 الأولىالأولى ... 28 9 10 11 1213 14 15 الأخيرةالأخيرة
النتائج 111 إلى 120 من 141
  1. [111]
    elreedy
    elreedy غير متواجد حالياً
    catia is the best design prog in the world after i used many progs i found .....the best
  2. [112]
    ibcet
    ibcet غير متواجد حالياً
    This is my personal opinion about wich software is to be used in mechanical design, please don’t take it for granted:
    First, three points to consider:
    1- mechanical design is a huge field, in wich area you will be using this software?
    2- will that software cover your needs, or you need ad-ins or other software to complete your tasks?
    3- how much time and money you are willing to spend?
    In general, there are two catagories:
    1- low level programs, it contains programs that are “easy to learn”, they perform almost everything in general mechanical desing: creating solid bodies, assemblies and drawing, they are also support sheet metal design and calculate flat pattern, bils of materials, even generat reports that can be used in documentation the project, in addition to some assembly’s mechanizms.
    In this catagory, i put Solid Edge, SolidWorks, i-Deas, and hardly Inventor (AutoCAD Mechanical is dead)
    Inventor is developing very fast, suported by Autodesk, i would say it is between catagory one and two.
    2- high level programs, manely Pro-Engineer, Catia, and Unigraphics (called NX)
    These programs do all “CAD” functions the same as the first catagory, but they do also “CAM” and CAE” functions, which is machining and engineering.
    In most small to mid-size companies, any one of the first catagory will do the job, it is just matter of time till the designers perfect using the software.
    If you are in high-tech business, where analysis, prototyping, optemization and feasibility are first periority, or in large company where documentations, risk assessment and other management tasks are important, it is hard to go too far with program from the first catagory.
    I can say that there are third type, which includes programs that are not “parametric” like the first two, in that catagory, i can see AutoCAD and Microstation, these two programs have their own unique way in dealing with mechanical design, they are general, used for 2D design, we cannot see how much they are powerful if we did not include in the picture other software linked to them, Autodesk and Bentley are big names, each one has a large list of “family members” of programs.
    Another thing might be worth saying, once a large company entered one of these two company, there are no turning back, all their future planning and development will be based on the first choice.
    Thanks.
  3. [113]
    ibcet
    Sorry, i-deas is dead too
  4. [114]
    aboalabd
    aboalabd غير متواجد حالياً
    solidworks is the best
  5. [115]
    shwana burhan
    shwana burhan غير متواجد حالياً
    solid work احسن برنامج على الاطلاق
  6. [116]
    cappo3332003
    cappo3332003 غير متواجد حالياً
    مشكور
  7. [117]
    أصدق أحساس
    أصدق أحساس غير متواجد حالياً
    أنا صراحة أشتغلت على الأوتوكاد والسوليد وورك ولكن حسب خلفيتي أن برامج الرسم هي من مجموعة كات وهي على مستويات ويكون في المستوى الأول هو ال كاتيا ويأتي من بعده السوليدوورك وباقي البرامج
  8. [118]
    ahmed malik
    ahmed malik غير متواجد حالياً
    الصورة الرمزية ahmed malik
    انا افضل الكل حسب الاستخدام لان لكل واحد مميزاته الخاصة . والعلم عند الله تعالي
  9. [119]
    محمد 1000
    محمد 1000 غير متواجد حالياً
    أنا مبتدئ لذلك لا يوجد امامي سوى تعلم الاوتوكاد في البداية
  10. [120]
    داجر
    داجر غير متواجد حالياً
    الصورة الرمزية داجر
    سلام الله عليكم
    لكل من البرامج مميزاته، الافضلية عندي لبرنامج catia لا لشئ سوى اني اجيد التعامل معه فمن هذا المنطلق احسن البرامج يكون باجادة العمل عليه بجانب توفره و الطلب عليه
