بعض المشاكل وحلولها داخل ماكينة الديزل موضوع متكامل
النتائج 1 إلى 10 من 11
    bedoo54
    bedoo54 غير متواجد حالياً
    الشرح باللغة الانجليزية نقلا عن منتداي اردت ان اضيفه داخل منتدي المهندسين العرب للافادة
    Troubleshooting
    Troubleshooting can be difficult. The Troubleshooting Problem List gives a list of possible problems. To make a repair to a problem, make reference to
    the cause and correction on the pages that follow.
    This list of problems, causes, and corrections will only give an indication of where a possible problem can be, and what repairs are needed. Normally,
    more or other repair work is needed beyond the recommendations in the list.
    Remember that a problem is not normally caused only by one part, but by the relation of one part with other parts. This list is only a guide and cannot
    give all possible problems and corrections. The service personnel must find the problem and its source, then make the necessary repairs.
    1. Engine Crankshaft Will Not Turn When Start Switch Is On.
    2. Engine Will Not Start.
    3. Engine Misfires Or Runs Rough.
    4. Stall At Low RPM.
    5. Sudden Changes In Engine RPM.
    6. Not Enough Power.
    7. Too Much Vibration.
    8. Loud Combustion Noise.
    9. Valve Train Noise (Clicking).
    10. Oil In Cooling System.
    11. Mechanical Noise (Knock) In Engine.
    12. Fuel Consumption Too High.
    13. Loud Valve Train Noise.
    14. Too Much Valve Lash.
    15. Valve Rotocoil Or Spring Lock Is Free.
    16. Oil At The Exhaust.
    17. Little Or No Valve Lash.
    18. Engine Has Early Wear.
    19. Coolant In Lubrication Oil.
    20. Too Much Black Or Gray Smoke.
    21. Too Much White Or Blue Smoke.
    22. Engine Has Low Oil Pressure.
    23. Engine Uses Too Much Lubrication Oil.
    24. Engine Coolant Is Too Hot.
    25. Exhaust Temperature Is Too High.
    26. Starting Motor Does Not Turn.
    27. Alternator Gives No Charge.
    28. Alternator Charge Rate Is Low Or Not Regular.
    29. Alternator Charge Is Too High.
    30. Alternator Has Noise.
    31. Rack Solenoid Does Not Stop Engine.
    bedoo54
    Problem 1: Engine Crankshaft Will Not Turn When Start Switch Is On
    Probable Cause:
    1. Battery Has Low Output
    Make Reference to Problem 26.
    2. Wires Or Switches Have Defect
    3. Starting Motor Solenoid Has A Defect
    4. Starting Motor Has A Defect
    5. Inside Problem Prevents Engine Crankshaft From Turning
    If the crankshaft can not be turned after the driven equipment is disconnected, remove the fuel injection nozzles and check for fluid in the cylinders when the crankshaft is turned. If fluid in the cylinders is not the problem, the engine must be disassembled to check for other inside problems. Some of these inside problems are bearing seizure, piston seizure, or wrong pistons installed in the engine.
    Problem 2: Engine Will Not Start
    Probable Cause:
    1. Starting Motor Turns Too Slow
    Make reference to Problem 27.
    2. Dirty Fuel Filter
    Install new fuel filter.
    3. Dirty Or Broken Fuel Lines
    Clean or install new fuel lines as necessary.
    4. Fuel Transfer Pump
    At starting rpm, the minimum fuel pressure for fuel transfer pump must be 20 kPa (3 psi). If fuel pressure is less than 20 kPa (3 psi), change the fuel filter element. Look for air in the fuel system. If fuel pressure is still low, install a new fuel transfer pump.
    5. No Fuel To Cylinders
    Put fuel in fuel tank. "Prime" (remove the air and/or poor quality fuel) the fuel system.
    6. Poor Quality Fuel
    Remove the fuel from the fuel tank. Install a new fuel filter element. Put a good grade of clean fuel in the fuel tank. See Diesel Fuels and Your Engine, SEBD0717.
    7. Wrong Fuel Injection Timing
    Make adjustment to timing.
    8. Shutoff Solenoid Will Not Move To Extended Position
    The solenoid must get electricity to stop the engine. Operate the control for the shutoff solenoid and see if the solenoid makes a noise (clicking sound). If this sound can be heard and the engine will not start, remove the solenoid. Now see if the engine will start. If the engine starts, the shutoff solenoid either needs an adjustment or it is defective and replacement of the solenoid is necessary.
    Problem 3: Engine Misfires Or Runs Rough
    Probable Cause:
    1. Fuel Pressure Is Low
    Make sure there is fuel in the fuel tank. Look for leaks or bad bends in the fuel line between fuel tank and fuel transfer pump. Look for air in the fuel system. Check fuel pressure.
    If fuel pressure is lower than 170 kPa (25 psi) install a new filter element. The outlet pressure of the fuel transfer pump at full load must be 240 kPa (35 psi). If fuel pressure is still low, install a new fuel transfer pump.
    2. Air In Fuel System
    Find the air leak in the fuel system and correct it. If air is in the fuel system, it will probably get in on the suction side of fuel transfer pump.
    3. Leak Or Break In Fuel Line Between Injection Pump And Fuel Injection Nozzle
    Install a new fuel line.
    4. Wrong Valve Lash.
    Make adjustment according to the Subject, Valve Lash Setting.
    5. Defect In Fuel Injection Nozzle(s) Or Injection Pump(s)
    Run engine at rpm that misfires the most and runs the roughest. Then loosen a fuel line nut on the fuel injection nozzle for each cylinder, one at a time. Find the cylinder where a loosened fuel line nut does not change the way the engine runs. Test the injection pump and fuel injection nozzle for that cylinder. Install new parts where needed.
    6. Wrong Fuel Injection Timing
    7. Bent Or Broken Push Rod
    Replacement of push rod is necessary.
    8. Fuel Has "Cloud Point" Higher Than Atmospheric Temperature ("Cloud Point" = Temperature Which Makes Wax Form In Fuel).
    Drain the fuel tank, lines, and fuel injection pump housing. Change the fuel filter. Fill the tank with fuel which has the correct "cloud point" and remove the air from the system with the priming pump.
    Problem 4: Stall At Low RPM
    Probable Cause:
    If fuel pressure is lower than 170 kPa (25 psi) install a new fuel filter element. The outlet pressure of the fuel transfer pump at full load must be 240 kPa (35 psi). If fuel pressure is still low, install a new fuel transfer pump.
    2. Idle RPM Too Low
    Make adjustment to governor so idle rpm is the same as given in the TMI (Technical Marketing Information) or Fuel Setting And Related Information Fiche.
    3. Defect In Fuel Injection Nozzle(s)
    Install a new fuel injection nozzle.
    4. Engine Accessories
    Check engine accessories for damage and correct adjustment. If necessary, disconnect the accessories and test the engine.
    5. Defect In Fuel Injection Pump(s)
    Install new parts if needed.
    Problem 5: Sudden Changes In Engine Speed (rpm)
    Probable Cause:
    1. Failure Of Governor Or Fuel Injection Pump
    Look for damaged or broken springs, linkage or other parts. Remove the governor. Check for free travel of fuel rack. Be sure fuel injection pumps are installed correctly. Check for correct governor spring. Install new parts for those that have damage or defects.
    Problem 6: Not Enough Power
    Probable Cause:
    1. Poor Quality Fuel
    2. Fuel Pressure Is Low
    3. Leaks In Air Inlet System
    Check the pressure in the air inlet manifold. Look for restrictions in the air cleaner.
    4. Governor Linkage
    Make adjustment to get full travel of linkage. Install new parts for those that have damage or defects.
    5. Wrong Valve Lash
    6. Defect In Fuel Injection Nozzle(s) Or Fuel Injection Pumps
    Run engine at rpm that misfires the most or runs the roughest. Then loosen a fuel line nut on the injection pump for each cylinder, one at a time. Find the cylinder where a loosened fuel line nut does not change the way the engine runs. Test the injection pump and fuel injection nozzle for that cylinder. Install new parts where needed.
    8. Rack Setting Too Low
    Make reference to the TMI (Technical Marketing Information) or Fuel Setting And Related Information Fiche.
    9. Defect In Aftercooler
    Check temperature of inlet and outlet water supply. Remove any external or internal restrictions.
    10. Fuel Ratio Control
    Control either needs an adjustment or it is damaged and a new control is needed.
    11. Turbocharger Has Carbon Deposits Or Other Causes Of Friction
    Make inspection and repair of turbocharger as necessary.
    Problem 7: Too Much Vibration
    Probable Cause:
    1. Loose Bolt Or Nut For Pulley Or Damper
    Tighten bolt or nut.
    2. Pulley Or Damper Has A Defect
    Install a new pulley or damper.
    3. Engine Supports Are Loose, Worn, Or Have A Defect
    Tighten all bolts that hold engine supports. Install new components if necessary.
    4. Engine Misfires Or Runs Rough
    Make Reference to Problem 3.
    Problem 8: Loud Combustion Noise (Sound)
    Probable Cause:
    2. Defect In Fuel Injection Nozzle(s)
    Install new fuel injection nozzle(s).
    3. Defect In Fuel Injection Pump(s)
    Install new fuel injection pump(s).
    4. Wrong Fuel Injection Timing
    كلما ادبني الدهر اراني نقص عقلي وكلما اذددت علما ذادني علما يجهلي
    http://www.ebiedyousif.net
    bedoo54
    Problem 9: Valve Train Noise (Clicking)
    Probable Cause:
    1. Damage To Valve Spring(s), Locks Or Broken Or Worn Valve Lifter
    Install new parts where necessary. Broken locks can cause the valve to get into the cylinder. This will cause much damage.
    2. Not Enough Lubrication
    Check lubrication in valve compartment. There must be a strong flow of oil at engine high rpm, but only a small flow of oil at low rpm. Oil passages must be clean, especially those that send oil to the cylinder head.
    3. Too Much Valve Lash
    4. Damage In Bridge For Valves
    Make a replacement of the bridge and make an adjustment as necessary.
    Problem 10: Oil In Cooling System
    Probable Cause:
    1. Defect In Core Of Engine Oil Cooler
    Install a new engine oil cooler.
    2. Failure Of Cylinder Head Gasket Or Water Seals
    Install a new head gasket and new water seals in spacer plate.
    Problem 11: Mechanical Noise (Knock) In Engine
    Probable Cause:
    1. Failure Of Bearing For Connecting Rod
    Inspect the bearing for the connecting rod and the bearing surface (journal) on the crankshaft. Install new parts where necessary.
    2. Damaged Timing Gears
    3. Damaged Crankshaft
    Make replacement of the crankshaft.
    4. Defect In Attachment
    Repair or install new components.
    Problem 12: Fuel Consumption Too High
    Probable Cause:
    1. Fuel System Leaks
    Tighten or make replacement of parts at points of leakage.
    2. Fuel And Combustion Noise (Knock)
    Make Reference to Problem 3 and Problem 6.
    3. Wrong Fuel Injection Timing
    Problem 13: Loud Valve Train Noise
    Probable Cause:
    Make replacement of parts with damage.
    2. Damage To Camshaft
    Make replacement of parts with damage. Clean engine thoroughly. If replacement of camshaft is made, new valve lifters are also necessary.
    3. Damage To Valve Lifter
    Clean engine thoroughly. Make replacement of the damaged valve lifters. Inspect camshaft lobes for damage. Look for valves that do not move freely. Make an adjustment to valve lash according to the Subject, Valve Lash Setting.
    Make replacement of the bridge and make an adjustment as necessary.
    Problem 14: Too Much Valve Lash
    Probable Cause:
    1. Not Enough Lubrication
    Check lubrication in valve compartment. There must be a strong flow of oil at engine high rpm, but only a small flow at low rpm. Oil passages must be clean, especially those that send oil to the cylinder head.
    2. Rocker Arm Worn At Face That Makes Contact With Bridge
    If there is too much wear, install new parts or rocker arms. Make adjustment of valve lash according to the Subject, Valve Lash Setting.
    3. End Of Valve Stem Worn
    If there is too much wear, install new valves. Make adjustment to valve lash according to the Subject, Valve Lash Setting.
    4. Bridge For Valves Worn
    Make an adjustment or replacement as necessary.
    5. Worn Push Rods
    If there is too much wear, install new push rods. Make adjustment of valve lash according to the Subject, Valve Lash Setting.
    6. Broken Or Worn Valve Lifters
    Install new valve lifters. Check camshaft for wear. Check for free movement of valves or bent valve stem. Clean engine thoroughly. Make adjustment of valve lash according to the Subject, Valve Lash Setting.
    7. Worn Cams On Camshaft
    Install a new camshaft. Install new valve lifters. Check for free movement of valves or bent valve stems. Make adjustment of valve lash according to the Subject, Valve Lash Setting.
    Problem 15: Valve Rotocoil Or Spring Lock Is Free
    Probable Cause:
    1. Broken Locks
    2. Broken Valve Spring(s)
    Install new valve spring(s).
    3. Broken Valve
    Replace valve and other damaged parts.
    Problem 16: Oil At The Exhaust
    Probable Cause:
    1. Too Much Oil In The Valve Compartment
    Look at both ends of the rocker arm shaft. Be sure a plug is in each end of the shaft.
    2. Worn Valve Guides
    Reconditioning of the cylinder head is needed.
    3. Worn Piston Rings
    Inspect and install new parts as needed.
    Problem 17: Little Or No Valve Lash
    Probable Cause:
    1. Worn Valve Seat Or Face Of Valve
    Reconditioning of cylinder head is needed. Make adjustment of valve lash according to the Subject, Valve Lash Setting.
    Problem 18: Engine Has Early Wear
    Probable Cause:
    1. Dirt In Lubrication Oil
    Remove dirty lubrication oil. Install a new oil filter element. Put clean oil in the engine.
    2. Air Inlet Leaks
    Inspect all gaskets and connections. Make repairs if leaks are found.
    3. Fuel Leakage Into Lubrication Oil
    This will cause high fuel consumption and low engine oil pressure. Make repairs if leaks are found. Install new parts where needed
    bedoo54
    Problem 19: Coolant In Lubrication Oil
    Probable Cause:
    1. Failure Of Engine Oil Cooler Core
    Install a new engine oil cooler. Drain crankcase and refill with clean lubricant. Install new oil filter element.
    Install a new cylinder head gasket and new water seals in the spacer plate. Tighten the bolts that hold the cylinder head according to the Specifications.
    3. Crack Or Defect In Cylinder Head
    Install a new cylinder head.
    4. Crack Or Defect In Cylinder Block
    Install a new cylinder block.
    5. Damaged Seals For Cylinder Liners
    Make replacement of the seals.
    Problem 20: Too Much Black Or Gray Smoke
    Probable Cause:
    1. Not Enough Air For Combustion
    Check air cleaner for restrictions.
    2. Defect in Fuel Injection Nozzle(s)
    Make adjustment of timing.
    4. Defect In Fuel Ratio Control
    Make adjustment to or install new control.
    Problem 21: Too Much White Or Blue Smoke
    Probable Cause:
    1. Too Much Lubrication Oil In Engine
    Remove extra oil. Find where extra oil comes from. Put correct amount of oil in engine.
    2. Engine Misfires Or Runs Rough
    Make reference to Problem 3.
    4. Worn Valve Guides
    5. Worn Piston Rings
    Install new parts as necessary.
    6. Failure Of Turbocharger Oil Seal
    Check inlet manifold for oil and make repair to turbocharger if necessary.
    Problem 22: Engine Has Low Oil Pressure
    Probable Cause:
    1. Dirty Oil Filter Or Oil Cooler
    Install new oil filter. Clean or install new engine oil cooler. Remove dirty oil from engine. Put clean oil in engine.
    2. Diesel Fuel In Lubrication Oil
    Find the place where diesel fuel gets into the lubrication oil. Make repairs as needed. Remove the lubrication oil that has diesel fuel in it. Install a new oil filter element. Put clean oil in the engine.
    3. Too Much Clearance Between Rocker Arm Shaft And Rocker Arms
    Check lubrication in valve compartment. Install new parts as necessary.
    4. Oil Pump Suction Pipe Has A Defect
    Replacement of pipe is needed.
    5. Pressure Regulating Valve Does Not Close
    Clean valve and housing. Install new parts as necessary.
    6. Oil Pump Is Worn Or Has A Defect
    Repair or make replacement of necessary parts.
    7. Too Much Clearance Between Crankshaft And Crankshaft Bearings
    Check the oil filter for correct operation. Install new parts as necessary.
    8. Defect In Oil Pressure Indicator
    Install new indicator.
    9. Too Much Bearing Clearance For Idler Gear
    Inspect bearings and make replacement as necessary.
    Problem 23: Engine Uses Too Much Lubrication Oil
    Probable Cause:
    2. Oil Leaks
    Find all oil leaks. Make repairs as needed.
    3. Oil Temperature Is Too High
    Check operation of engine oil cooler. Install new parts if necessary. Clean the core of the engine oil cooler.
    4. Too Much Oil In The Valve Compartment
    5. Worn Valve Guides
    6. Worn Piston Rings And Cylinder Liners
    Inspect and install new parts as needed. Reconditioning of the cylinder block can be necessary.
    7. Failure Of Seal Rings In Turbocharger
    Problem 24: Engine Coolant Is Too Hot
    Probable Cause:
    1. Restriction To Flow of Coolant Through Radiator Core Tubes Or Heat Exchanger
    Clean and flush radiator or heat exchanger.
    2. Restriction To Air Flow Through Radiator
    Remove all restrictions of air flow.
    3. Low Fan Speed
    Check for worn or loose fan belt.
    4. Not Enough Coolant In System
    Add coolant to cooling system.
    5. Pressure Cap Has A Defect
    Check operation of pressure cap. Install a new pressure cap if necessary.
    6. Combustion Gases In Coolant
    Find out where gases get into the cooling system. Make repairs as needed.
    7. Water Temperature Regulator (Thermostat) Or Temperature Indicator Has A Defect
    Check water temperature regulator for correct operation. Check temperature indicator operation. Install new parts as necessary.
    8. Water Pump Has A Defect
    Make repairs or replacement of the water pump as necessary. Put correct tension on drive belt for water pump.
    9. Too Much Load On The System
    Make a reduction to the load.
    10. Wrong Fuel Injection Timing
    Problem 25: Exhaust Temperature Is Too High
    Probable Cause:
    1. Air Inlet Or Exhaust System Has A Restriction
    Remove restriction.
    2. Wrong Fuel Injection Timing
    Make an adjustment to the timing.
    Problem 26: Starting Motor Does Not Turn
    Probable Cause:
    Check condition of battery. Charge battery or make replacement as necessary.
    2. Wires or Switch Has Defect
    Make repairs or replacement as necessary.
    Install a new solenoid.
    Make repair or replacement of starting motor.
    Problem 27: Alternator Gives No Charge
    Probable Cause:
    1. Loose Drive Belt For Alternator
    Make an adjustment to put the correct tension on the drive belt.
    2. Charging Or Ground Return Circuit Or Battery Connections Have A Defect
    Inspect all cables and connections. Clean and tighten all connections. Make replacement of parts with defect.
    3. Brushes Have A Defect
    Install new brushes.
    4. Rotor (Field Coil) Has A Defect
    Install a new rotor.
    Problem 28: Alternator Charge Rate Is Low Or Not Regular
    Probable Cause:
    Inspect all cables and connections. Clean and tighten all connections. Make replacement of parts with defects.
    3. Alternator Regulator Has A Defect
    Install a new alternator regulator.
    4. Alternator Brushes Have A Defect
    5. Rectifier Diodes Have A Defect
    Make replacement of rectifier diode that has a defect.
    6. Rotor (Field Coil) Has A Defect
    Problem 29: Alternator Charge Is Too High
    Probable Cause:
    1. Alternator Or Alternator Regulator Has Loose Connections
    Tighten all connections to alternator or alternator regulator.
    2. Alternator Regulator Has A Defect
    Problem 30: Alternator Has Noise
    Probable Cause:
    1. Drive Belt For Alternator Is Worn Or Has A Defect
    Install a new drive belt for the alternator.
    2. Loose Alternator Drive Pulley
    Check groove in pulley for key that holds pulley in place. If groove is worn, install a new pulley. Tighten pulley nut according to Specifications.
    3. Drive Belt And Drive Pulley For Alternator Are Not In Alignment
    Make an adjustment to put drive belt and drive pulley in correct alignment.
    4. Worn Alternator Bearings
    Install new bearings in the alternator.
    5. Rotor Shaft Is Bent
    Make replacement of the rotor shaft.
    6. Rectifiers In The Alternator Are Shorted
    Make replacement of the diode assembly.
    Problem 31: Rack Solenoid Does Not Stop Engine
    Probable Cause:
    1. Electrical Connections Are Not Correct
    Correct electrical connections and wiring.
    2. Adjustment For Plunger Shaft Is Not Correct
    Make an adjustment to the plunger shaft.
    3. Wrong Plunger In Solenoid
    Install the correct plunger in the solenoid.
    4. Not Enough Plunger Travel
    Make an adjustment to the plunger shaft or make replacement of the solenoid if necessary.
    5. Defect In Solenoid Wiring
    Make replacement of the solenoid.
    bedoo54
    يوجد الكثير ولكن اعذروني لضيق وقتي لانشغالي بموقعي واي طلب انا في الخدمة
    rekill_me
    rekill_me غير متواجد حالياً
    جزاك الله كل خير ... بس لو كان في pdf او word يبقى تمام ...
    sabro
    sabro غير متواجد حالياً
    ايضا لو كان بالعربي احسن ' على العموم مشكور
    bedoo54
    اخي العزيز في هذا الرابط
    الميكانيك
    الميكانيك غير متواجد حالياً
    السلام ممكن تعطينا فايل مضغوط
    للسهولة الحفظ
    ومشكور.
    ahmed abisalama
    ahmed abisalama غير متواجد حالياً
    جزاك الله خيرا
    يا هندسه
