matlab r2008 بتجميعة خاصة على ملف شخصى
النتائج 1 إلى 2 من 2
    java2007
    java2007 غير متواجد حالياً
    MATLAB is a high-level technical computing language and interactive environment for algorithm development, data visualization, data analysis, and numeric computation. Using MATLAB, you can solve technical computing problems faster than with traditional programming languages, such as C, C++, and Fortran.
    You can use MATLAB in a wide range of applications, including signal and image processing, communications, control design, test and measurement, financial modeling and analysis, and computational biology. Add-on toolboxes (collections of special-purpose MATLAB functions, available separately) extend the MATLAB environment to solve particular classes of problems in these application areas.
    MATLAB provides a number of features for documenting and sharing your work. You can integrate your MATLAB code with other languages and applications, and distribute your MATLAB algorithms and applications.
    حمل الاجزاء من التجميعة التالية:
    http://rapidshare.com/users/LTDGMP
    vista25.com
    تحياتى
    فاتح روما
    فاتح روما غير متواجد حالياً
    الصورة الرمزية فاتح روما
    مشككككككككككككككككككككككوووووووووووورررررررررررررر ررررر
    اللهم أرنا الحق حقا وارزقنا اتباعه
