مجموعه كبيرة جدا من الكتب بمختلف التخصصات الهندسيه .
صفحة 27 من 33 الأولىالأولى ... 1723 24 25 26 2728 29 30 31 ... الأخيرةالأخيرة
النتائج 261 إلى 270 من 329
  1. [261]
    فلسطين والنضال
    فلسطين والنضال غير متواجد حالياً
    الصورة الرمزية فلسطين والنضال
    Methods for Monitoring & Diagnosing the Efficiency of Catalytic Converters - engineering books
    This book is divided into four parts, first, it describes methods involving the use of oxygen or airhel ratio exhaust gas sensors to determine the oxygen storage capacity of a catalytic converter, second, it describes methods involving the use of temperature sensors to determine the exothermic reaction capacity of a catalytic converter; third, it describes all other methods existing in patent literature that monitor and diagnose the efficiency of catalytic converters and it involves exhaust gas concentration measurements; fourth, it comprises a general discussion of all methods described. In the beginning of each part, a short introduction is given to explain the problem that the methods attempt to solve. Every part presented in chronological order per patent applicant to evaluate how the patent applicant has improved his methods over time. Information about the patent applicants, inventors, priorities and patent-families, an inventor index, a company index and a subject index are can be found at the end ofthe book. This book attemps to describe the evolution of methods concerned with on-board (OBD) and non-OBD monitoring and diagnosing of the efficiency of catalytic converters of internal combustion engines based mainly on patents and published patent applications. All patent and non-patent documents cited in this book originate from the systematically classified documentation of the European Patent Ofice (EPO). For the Japanese patent literature the technical abstracts published in English by the Japanese Patent Office have been used.
    Download here
    The Material Science of Thin Films - Engineering ebooks
    Another great engineering books authored by OHRING, Milton, The Materials Science of Thin Films. There are at least 200 books written on various aspects of thin film science and technology and this book is true. This is specifically intended for classroom use in universities. Most thin film courses in universities have had to use many books written for relatively experienced thin film scientists and engineers. The combination of teaching, research, and industrial involvement of this book has provided Professor Ohring with a broad perspective of thin film science and technology. This gives tremendous insight into the needs of students entering this exciting field. This is intended for Science and engineering students in advanced undergraduate or first-year graduate level courses on thin films Participants in industrial in-house courses or short courses offered by professional societies Mature scientists and engineers switching career directions who require an overview of the field. Topics discussed include nucleation, growth, crystal perfection, epitaxy, mass transport effects, and the role of stress. These are the common thin-film concerns irrespective of application.
    Download this ebook here
    Tribology in Machine Design - Engineering ebooks
    This book has increasingly important role played by tribology at the design stage in engineering. The book shows how algorithms developed from the basic principles of tribology. The book is pengineering and planned as a comprehensive reference and source book for practising designers, researchers and postgraduate students. This book deals with new findings in tribology and their application in industry. The procedures and techniques of analysis of this book has found helpful in applying the principles of tribology to the design of the machine elements. This book is designed to supplement the Engineering Science Data Unit (ESDU) series in tribology (well known to practising engineers), emphasizing the basic principles, giving the background and explaining the rationale of the practical procedures. It has detailed guidance in solving a particular problem or for an alternative method of solution. It advocates and demonstrates the use of the computer as a design tool where long, laborious solution procedures are needed. The concept of tribodesign in this book is introduced, devoted to a brief discussion of the basic principles of tribology, elements of contact mechanics, are confined to the most technically important topics. Tribology of lower kinematic pairs, sliding element bearings and higher kinematic were also discussed, discussion of rolling contact bearings with particular emphasis on contact problems, surface fatigue and lubrication techniques, concentrates on lubrication and surface failures of involute gears. The basis of this book is largely on the notes for a course of lectures on friction, wear and lubrication application to machine.
    Download here
    سوف نقتلهم جميعا وسوف نشرب دمائهم في كاس انتفاضتنا وليكن نخبه الموت لنا ولهم ولتحيا فلسطين
  2. [262]
    فلسطين والنضال
    Analog Interfacing to Embedded Microprocessors
    This book BALL, authored by Stuart R. (2001) :Analog Interfacing to Embedded Microprocessors - Real World Design, attempts to get at the problems encountered in connecting the analogue and digital world of microprocessors. The book dela about System Design, Dynamic ,Range, Calibration, Bandwidth, Processor, ThroughputAvoiding, Excess Speed, Other System Considerations ,Sample Rate and Aliasing, Digital-to-Analog, Converters Analog-to-Digital, Converters Types of ADCs, Sample and Hold Real Parts, Microprocessor Interfacing Serial Interfaces, Multichannel ADCs, Internal Microcontroller, ADCs Codecs, Interrupt Rate Dual-Function Pins on Microcontrollers, Design Checklist Sensors ,Temperature ,Sensors Optical Sensors, CCDs, Magnetic Sensors, Motion/Acceleration Sensors, Strain Gauge, Time-Based Measurements, Measuring Period versus Frequency, Mixing Voltage-to-Frequency Converters, Output Control Methods, Open-Loop Control, Negative Feedback and Control Microprocessor-Based Systems, On-Off Control Proportional Control, PID Control Motor Control Measuring and Analyzing Control, Loops Solenoids, Relays, and Other Analog Outputs, Solenoids Heaters, Coolers Fans LEDs, Motors Stepper, Motors DC, Motors Brushless, DC Motors Tradeoffs between Motors, Motor Torque, EMI Ground Loops ESD, High-Precision Applications, Input Offset, Voltage Frequency Characteristics, Temperature Effects in Resistors, Voltage References Temperature, Effects in General Noise and Grounding, Supply-Based References, Standard Interfaces Current, Loop Opamp Basics, Four Opamp Configurations, General Opamp, Design Equations, Reversing the Inputs Comparators, and Instrumentation Amplifiers. This book provides coverage of practical control applications. The book focuses control theory nor opamp theory, its coverage includes measurement and control of analog quantities in embedded systems that are required to interface with the real world. This book is about connecting analog input and output devices to microprocessors for embedded applications.
    Download here
  3. [263]
    فلسطين والنضال
    ارجوانم تنال اعجابكم
  4. [264]
    فلسطين والنضال
    <DIV class="post hentry">Free Download electronics - Electronics and electrical magazines, Other related download Electronics and electrical magazines, Introduction to Operati
    <DIV class="post-body entry-*******">
    Electronics and electrical magazines 2005
    http://rapidshare.com/files/1057010/...05-01.rar.html
    http://rapidshare.com/files/1057852/...05-02.rar.html
    http://rapidshare.com/files/1040285/...05-03.rar.html
    http://rapidshare.com/files/1037140/...05-04.rar.html
    http://rapidshare.com/files/1031970/...05-05.rar.html
    http://rapidshare.com/files/1034571/...05-06.rar.html
    http://rapidshare.com/files/1060376/Elekto...-07_08.rar.html
    http://rapidshare.com/files/1062234/...05-09.rar.html
    http://rapidshare.com/files/1041509/...05-10.rar.html
    http://rapidshare.com/files/1044291/...05-11.rar.html
    http://rapidshare.com/files/1055111/...05-12.rar.html
    Electronics and electrical magazines 2006
    http://rapidshare.com/files/1063942/01-_2006.rar.html
    http://rapidshare.com/files/1066106/02-_2006.rar.html
    http://rapidshare.com/files/1066706/03-_2006.rar.html
    http://rapidshare.com/files/1067581/04-_2006.rar.html
    http://rapidshare.com/files/1069150/05-_2006.rar.html
    http://rapidshare.com/files/1065593/..._2006.rar.html
    rar passwords are: www.elektrotekno.com
    http://rapidshare.com/files/6537272/06-_2006.rar.html - English
    http://rapidshare.com/files/3432226/09-_2006.rar.html
    http://rapidshare.com/files/3431528/10-_2006.rar.html
    http://rapidshare.com/files/3431917/11-_2006.rar.html
    http://rapidshare.com/files/6382172/12-2006.rar.html
  5. [265]
    فلسطين والنضال
    وهناك المزيد والكثير حصريا لهذا المنتدى الطيب
  6. [266]
    فلسطين والنضال
  7. [267]
    فلسطين والنضال
    ناجي العلي في سطور
    • <LI dir=rtl>
      ناجي سليم حسين العلي ، الملقب بضمير الثورة ، من مواليد قرية الشجرة عام 1936 وهي قرية تقع بين الناصرة و طبريا في الجليل الشمالي من فلسطين .
      <LI dir=rtl>
      يقال إنها أعطيت هذا الاسم ، لأن السيد المسيح عليه السلام ، استظل فيء شجرة في أرضها .
      <LI dir=rtl>
      شرد من فلسطين عام 1948 ، نزح وعائلته مع أهل القرية باتجاه لبنان ( بنت جبيل) وهو من أسرة فقيرة تعمل في الزراعة والأرض ، لجأ إلى مخيم عين الحلوة شرق مدينة صيدا حيث سكن وعائلته بالقرب من بستان أبو جميل قرب الجميزة منطقة " عرب الغوير" وكان يقضي أوقاتاً طويلة في مقهى أبو مازن (محمد كريم – من بلدة صفورية ) .
      <LI dir=rtl>
      وكانت حياة ناجي العلي في المخيم عبارة عن عيش يومي في الذل. فأحدث ذلك صحوة فكرية مبكرة لديه، عرف انه وشعبه ، كانا ضحايا مؤامرة دنيئة دبرتها بريطانيا وفرنسا ، بالتحالف والتنسيق مع الحركة الصهيونية العالمية .
      <LI dir=rtl>
      درس ناجي العلي في مدرسة " اتحاد الكنائس المسيحية " حتى حصوله على شهادة " السرتفيكا" اللبنانية ، ولما تعذر عليه متابعة الدراسة ، اتجه للعمل في البساتين وعمل في قطف الأكي دنيا والحمضيات والزيتون (مع الوكيل سعيد الصالح أبو صالح ) لكن بعد مدة ، ذهب إلى طرابلس – القبة ومعه صديقة محمد نصر شقيق زوجته (لاحقاً )ليتعلم صنعة في المدرسة المهنية التابعة للرهبان البيض .
      <LI dir=rtl>
      تعلم سنتين هناك ، ثم غادر بعد ذلك إلى بيروت حيث عمل في ورش صناعية عدة ، نصب خيمة قديمة (من الخيم التي كانت توزعها وكالة الغوث ) في حرش مخيم شاتيلا ، وعاش في حياة تقشف .
      <LI dir=rtl>
      1957 سافر إلى السعودية بعدما حصل على دبلوم الميكانيكا وأقام فيها سنتين ، كان يشتغل ويرسم أثناء أوقات فراغه ، ثم عاد بعد ذلك إلى لبنان .
      <LI dir=rtl>
      1959 حاول أن ينتمي إلى حركة القوميين العرب ، لأنه وخلال سنة واحدة ، أبعد أربع مرات عن التنظيم ، بسبب عدم انضباطه في العمل الحزبي .
    • 1960 - 1961 أصدر نشرة سياسية بخط اليد مع بعض رفاقه في حركة القوميين العرب تدعى " الصرخة " .
    • <LI dir=rtl>
      1960 دخل الأكاديمية اللبنانية للرسم ( أليكسي بطرس) لمدة سنة ، إلا أنه ونتيجة ملاحقته من قبل الشرطة اللبنانية ، لم يداوم إلا شهراً أو نحو ذلك ، وما تبقى من العام الدراسي أمضاه في ضيافة سجون الثكنات اللبنانية ، حيث ( .. أصبح حنظلة زبوناً دائماً لمعظم السجون ، تارة يضعونه في سجن المخيم ، وأخرى ينقلونه إلى السجن الأثري في المدينة القريبة (سجن القلعة في صيدا – القشلة ) ، وإ.ذا ما ضخموا له التهمة ـ فإنهم كانوا ينقلونه إلى سجن العاصمة أو المناطق الأخرى - . بعد ذلك ، ذهب إلى مدينة صور ودرس الرسم في الكلية الجعفرية لمدة ثلاث سنوات .
      <LI dir=rtl>
      1963 سافر إلى الكويت وعمل في مجلة الطليعة الكويتية رساماً ومخرجاً ومحرراً صحافياً ، وكان هدفه أن يجمع المال ليدرس الفن في القاهرة أو في إيطاليا .
      <LI dir=rtl>
      ترك الكويت مرات عدة وعاد إليها .
      <LI dir=rtl>
      1968 عمل في جريدة السياسة الكويتية لغاية العام 1975 .
      <LI dir=rtl>
      مع بداية العام 1974 عمل في جريدة السفير ، وقد استمر فيها حتى العام 1983 .
      <LI dir=rtl>
      1979 انتخب رئيس رابطة الكاريكاتيرالعرب .
      <LI dir=rtl>
      عام 1982 اعتقل في صيدا من قبل العدو الإسرائيلي وأطلق سراحه حيث إنهم أخطأوا التعرف إلى شخصيته .
      <LI dir=rtl>
      1983 بعد أن ضاق به أهل البيت ذرعاً ، ترك بيروت متوجهاً إلى الكويت ، حيث عمل في جريدة القبس الكويتية وبقي فيها حتى أكتوبر 1985 .
      <LI dir=rtl>
      1985 بعد أن ضاق به أهل البيت ذرعاً ، ترك الكويت وتوجه إلى لندن حيث عمل في" القبس" الدولية
      <LI dir=rtl>
      شاركت رسوم ناجي العلي في عشرات المعارض العربية والدولية .
      <LI dir=rtl>
      أصدر ثلاثة كتب في الأعوام (1976 ، 1983 ، 1985) ضمت مجموعة من رسوماته المختارة .
      <LI dir=rtl>
      كان يتهيأ لإصدار كتاب رابع لكن الرصاص الغادر حال دون ذلك .
      <LI dir=rtl>
      حصلت أعماله على الجوائز الأولى في معرضي الكاريكاتير للفنانين العرب أقيما في دمشق في سنتي 1979 1980 م .
      <LI dir=rtl>
      عضو الأمانة العامة لاتحاد الكتاب والصحافيين الفلسطينيين .
      <LI dir=rtl>
      نشر ا:ثر من 40 ألف لوحة كاريكاتورية طيلة حياته الفنية ، عدا عن المحظورات التي مازالت حبيسة الأدراج ، ماكان يسبب له تعباً حقيقياً .
      <LI dir=rtl>
      اختارته صحيفة "اساهي " اليابانية كواحد من بين أشهر عشرة رسامي كاريكاتير في العالم .
    • متزوج من السيدة وداد صالح نصر من بلدة صفورية – فلسطين وله أربعة أبناء:
    خالد ، أسامه ، ليال وجودي.
    • <LI dir=rtl>
      اغتيل في لندن يوم 22 / 7 / 1987 وتوفي 29/ 8/ 1987 م .
      <LI dir=rtl>
      وبعد وفاته ، أقيم مركز ثقافي في بيروت أطلق عليه اسم " مركز ناجي العلي الثقافي" تخليداً لذكراه ، كما حملت اسم الفنان مسابقة الرسم الكاريكاتوري أجرتها جريدة " السفير" .
      <LI dir=rtl>
      8/ 2/ 1988 وصف الاتحاد الدولي لناشري الصحف في باريس ناجي العلي ، بأنه واحد من أعظم رسامي الكاريكاتير منذ نهاية القرن الثامن عشر ، ومنحه جائزة " قلم الحرية الذهبي" وسلمت الجائزة في إيطاليا إلى زوجته وابنه خالد ، علماً بأن ناجي العلي هو أول صحافي ورسام عربي ينال هذه الجائزة .
      <LI dir=rtl>
    من كتاب
    ناجي العلي
    كامل التراب الوطني الفلسطيني
    "من أجل هذا قتلوني"
    بقلم: محمود عبدالله كلّم
  8. [268]
    ammi
    ammi غير متواجد حالياً
    ما اروعك
    بارك الله فيك
  9. [269]
    فلسطين والنضال
    شكرا جزيلا لك
  10. [270]
    فلسطين والنضال
    Publisher Auerbach Publishing
    Author(s) Dan Minoli
    ISBN 0849385164
    Release Date 06 December 2007
    In 2005, the U.S. Government Accountability Office recommended that all agencies begin planning a coherent transition to IPv6. IPv6 will solve the problem of limited IP addresses and improve internetworking capabilities. This promising protocol is gaining momentum and it is only a matter of time before the transition will have to occur globally. The problem is that during the three-to-six year transition period, IPv6 and its predecessor, IPv4, will have to successfully coexist in order to ensure service continuity.
    Not only federal agencies, but corporations and institutions must start planning the transition to IPv6 now to maintain the operation, security, and interoperability of their networks.
    The implementation of IPv6 is essential to the continued growth of the internet and the development of new applications. The Handbook of IPv4 to IPv6 Transition Methodologies provides a wealth of best practices and procedures that will help corporations plan and implement a smooth transition to IPv6.
    Download Your eBook Now
    Download eBook
    Publisher Wiley
    Author(s) Ramu Ramamurthy
    ISBN 0470015659
    Release Date 04 December 2007
    Transport networks evolved from DCS (Digital Cross-connect Systems)-based mesh architectures, to SONET/SDH (Synchronous Optical Networking/Synchronous Digital Hierarchy) ring architectures in the 1990’s. In the past few years, technological advancements in optical transport switches have allowed service providers to support the same fast recovery in mesh networks previously available in ring networks while achieving better capacity efficiency and resulting in lower capital cost.
    Optical transport networks today not only provide trunking capacity to higher-layer networks, such as inter-router connectivity in an IP-centric infrastructure, but also support efficient routing and fast failure recovery of high-bandwidth services. This is possible due to the emergence of optical network elements that have the intelligence required to efficiently control the network. Optical mesh networks will enable a variety of dynamic services such as bandwidth-on-demand, Just-In-Time bandwidth, bandwidth scheduling, bandwidth brokering, and optical virtual private networks that open up new opportunities for service providers and their customers alike.
    Path Routing in Mesh Optical Networks combines both theoretical as well as practical aspects of routing and dimensioning for mesh optical networks. All authors have worked as technical leaders for the equipment vendor Tellium who implemented such capabilities in its product, and whose product was deployed in service provider networks.
    * Presents an in-depth treatment of a specific class of optical networks, i.e. path-oriented mesh optical networks.
    * Focuses on routing and recovery, dimensioning, performance analysis and availability in mesh optical networks.
    * Explains and analyses routing specifically associated with Dedicated Backup Path Protection (DBPP) and Shared Backup Path Protection (SBPP) recovery architectures.
    As most of the core backbone networks evolve to mesh topologies utilizing intelligent network elements for provisioning and recovery of services, Path Routing in Mesh Optical Networks &#194; will be an invaluable tool for both researchers and engineers in the industry who are responsible for designing, developing, deploying and maintaining mesh optical networks. It will also be a useful reference book for graduate students and university professors who are interested in optical networks or telecommunications networking.
    Download eBook
    Publisher Webster’s New World
    Author(s) Ray Horak
    ISBN 047177457X
    Release Date 29 October 2007
    Webster’s New World Telecom Dictionary, by Ray Horak, is a comprehensive telecommunications dictionary of more than 7,500 terms critical to understanding voice, data, video, and multimedia communications system and network technologies, applications, and regulation. Given the convergence of computing and communications, the book also effectively is a computer dictionary with a telecom focus. It is thoroughly researched, highly objective, absolutely accurate, and includes just about every essential term, abbreviation, acronym, contraction, initialism, and portmanteau you might encounter in the telecom and datacom domains. Although the book is a technical dictionary, Horak’s plain-English, commonsense style yields definitions that are as thoroughly understandable to the business professional or student as they are to the electrical engineer. In fact, many entries are encyclopedic in nature, discussing applications and issues. Horak also injects a bit of his wry sense of humor, sprinkling occasional telecom trivia and marginally related definitions that will have you smiling and chuckling to yourself, but not to the point that they detract from what is an important book on a serious subject. An instant classic, Webster’s New World Telecom Dictionary is the one and only telecom dictionary you will need. It also makes a perfect companion to Horak’s Telecommunications and Data Communications Handbook, published by Wiley-Interscience in October 2007.
    Download eBook
    Download from rapidshare.com
    Download eBook
    Download from easy-share.com
    Publisher John Wiley and Sons
    Author(s) Miguel-Angel Garc&#195;­a-Mart&#195;­n
    ISBN 0470018186
    Release Date 10 February 2006
    The IMS (IP Multimedia Subsystem) is the exciting new technology that will merge the Internet with the cellular world. It will make Internet technologies such as the web, email, instant messaging, presence, and videoconferencing available nearly everywhere.
    The 3G IP Multimedia Subsystem (IMS) provides a thorough overview of the IMS and its technologies. Throughout, the authors first describe how each technology works on the Internet and then explain how the same technology is adapted to work in the IMS, enabling readers to take advantage of any current and future Internet service.
    * Presents an introduction to the IMS - its goals, history, vision, the organizations involved in its standardization and architecture
    * Discusses the signalling plane of the IMS including protocols, such as SIP and Diameter, used between the IMS architectural entities. Also describes how the IETF developed these protocols and how they are used in the IMS architecture
    * Describes the media plane of the IMS and discusses Internet protocols that are not currently used in the IMS but may be in the future
    * Provides SIP-based service examples such as presence, instant messaging and Push-to-Talk
    Engineers, programmers, business managers, marketing representatives, and technically aware users will all find this book invaluable as it will help them to understand how the IMS works and the business model behind it. ”
    Download eBook
    Download eBook
