مجموعه كبيرة جدا من الكتب بمختلف التخصصات الهندسيه .
صفحة 22 من 33 الأولىالأولى ... 1218 19 20 21 2223 24 25 26 32 ... الأخيرةالأخيرة
النتائج 211 إلى 220 من 329
  1. [211]
    فلسطين والنضال
    فلسطين والنضال غير متواجد حالياً
    الصورة الرمزية فلسطين والنضال
    Low-Power High-Speed ADCs for Nanometer CMOS Integration
    Low-Power High-Speed ADCs for Nanometer CMOS Integration is about the design and implementation of ADC in nanometer CMOS processes that achieve lower power consumption for a given speed and resolution than previous designs, through architectural and circuit innovations that take advantage of unique features of nanometer CMOS processes. A phase lock loop (PLL) clock multiplier has also been designed using new circuit techniques and successfully tested.
    1) A 1.2V, 52mW, 210MS/s 10-bit two-step ADC in 130nm CMOS occupying 0.38mm<SUP>2</SUP>. Using offset canceling comparators and capacitor [COLOR=#e82c2b! important][COLOR=#e82c2b! important]networks[/COLOR][/COLOR] implemented with small value interconnect capacitors to replace resistor ladder/multiplexer in conventional sub-ranging ADCs, it achieves 74dB SFDR for 10MHz and 71dB SFDR for 100MHz input.
    2) A 32mW, 1.25GS/s 6-bit ADC with 2.5GHz internal clock in 130nm CMOS. A new type of architecture that combines flash and SAR enables the lowest power consumption, 6-bit >1GS/s ADC reported to date. This design can be a drop-in replacement for existing flash ADCs since it does require any post-processing or calibration step and has the same latency as flash.
    3) A 0.4ps-rms-jitter (integrated from 3kHz to 300MHz offset for >2.5GHz) 1-3GHz tunable, phase-noise programmable clock-multiplier PLL for generating sampling clock to the SAR ADC. A new loop filter structure enables phase error preamplification to lower PLL in-band noise without increasing loop filter capacitor size.
    download
    Password default: netbks.com
    سوف نقتلهم جميعا وسوف نشرب دمائهم في كاس انتفاضتنا وليكن نخبه الموت لنا ولهم ولتحيا فلسطين
  2. [212]
    فلسطين والنضال
    Optimal Traffic Control: Urban Intersections
    Despite traffic circles, four-way stop signs, lights regulated by timers or sensors, and other methods, the management of urban intersections remains problematic. Consider that transportation systems have all the features of so-called complex systems: the great number of state and control variables, the presence of uncertainty and indeterminism, the complex interactions between subsystems, the necessity to optimize several optimization criteria, and active behavior of the controlled process, to name just a few. Therefore, a mathematical approach to these systems can resolve their complex issues more elegantly than other methods. Addressing both efficiency and traffic safety issues, Optimal Traffic Control: Urban Intersections examines the traffic control optimization problem and presents a novel solution method. Using an approach based on control theory, graph theory, and combinatorial optimization, the authors derive a full mathematical description of the traffic control problem and enumerate all combinatorial aspects. The result is a set of algorithmic solutions to various problems along with computer implementation that you can incorporate into real traffic control systems for immediate results. The book concludes by evaluating how the choice of a complete set of signal groups influences intersection performance. Although modern cities throughout the world have a unique character influenced by culture, geography, and population, most of them share one main feature: busy intersections and the issue of controlling the traffic traveling through them. The development of information technologies, especially computer and telecommunications techniques, has changed the complexity of the problem and influenced the development of new solutions. Clearly stating the issues and presenting a possible solution, this book shows you how to take full advantage of all the capabilities of microprocessor-based traffic signal controllers.
    download
  3. [213]
    فلسطين والنضال
    Mosfet Modeling for VlSI Simulation: Theory And Practice
    The book deals with the MOS Field Effect Transistor (MOSFET) models that are derived from basic [COLOR=#e82c2b! important][COLOR=#e82c2b! important]semiconductor[/COLOR][/COLOR] theory. Various models are developed, ranging from simple to more sophisticated models that take into account new physical effects observed in submicron transistors used in today’s (1993) MOS VLSI [COLOR=#e82c2b! important][COLOR=#e82c2b! important]technology[/COLOR][/COLOR]. The assumptions used to arrive at the models are emphasized so that the accuracy of the models in describing the device characteristics are clearly understood. Due to the importance of designing reliable circuits, device reliability models are also covered. Understanding these models is essential when designing circuits for state-of-the-art MOS ICs.
    download
  4. [214]
    فلسطين والنضال
    Bandwidth Extension of Speech Signals
    Bandwidth Extension of Speech Signals describes the theory and methods for quality enhancement of clean speech signals and distorted speech signals such as those that have undergone a band limitation, for instance, in a telephone [COLOR=#e82c2b! important][COLOR=#e82c2b! important]network[/COLOR][/COLOR]. Problems and the respective solutions are discussed for the different approaches. The different approaches are evaluated and a real-time implementation of the most promising approach is presented. The book includes topics related to speech coding, pattern- / speech recognition, speech enhancement, statistics and digital signal processing in general.
    download
  5. [215]
    tanab
    tanab غير متواجد حالياً
    اخي العزيز الرجاء تزويدنا بكلمة السر للملف المضغوط الخاص بالكتاب HANDBOOK of CIVIL ENGINEERING CALCULATIONS وبارك الله فيك
  6. [216]
    فلسطين والنضال
    انا اسف علشان نسيت بس راح احطه انشاء الله
  7. [217]
    فلسطين والنضال
    Major Process Equipment - Maintenance & Repair
    http://rapidshare.de/files/21057535/...__2nd_ed._.rar 13.56 MB
    Improving Machinery Reliability
    http://rapidshare.de/files/21058795/...__3rd_ed._.rar 13.91 MB
    Designing Capable & Reliable Products
    http://rapidshare.de/files/21060394/...e_Products.rar 17.21 MB
    Gas Turbine Engeering
    http://rapidshare.de/files/21061023/...__2nd_ed._.rar 9.28 MB
    Helicopter Dynamics
    http://rapidshare.de/files/21061464/...__2nd_ed._.rar 4.94 MB
    Metals Reference Book
    http://rapidshare.de/files/21064552/...__7th_ed._.rar 28.86 MB
    Light Metals Handbook
    http://rapidshare.de/files/21064673/...s_Handbook.rar 1.47 MB
    Non-Ferrous Foundryman's Handbook
    http://rapidshare.de/files/21065346/..._11th_ed._.rar 7.12 MB
    http://rapidshare.de/files/21065894/...s_Handbook.rar 3.69 MB
    Plastics Materials
    http://rapidshare.de/files/21068256/...__7th_ed._.rar 45.39 MB
    Carbon Materials for Advanced Technologies
    http://rapidshare.de/files/21068665/...chnologies.rar 9.38 MB
    Guide to Ship Repair Estimates
    http://rapidshare.de/files/21068750/..._Man-Hours.rar 0.94 MB
    Physical Metallurgy
    http://rapidshare.de/files/21073121/...__3_vols._.rar 57.57 MB
    The Coming Materials Science
    http://rapidshare.de/files/21073404/...ls_Science.rar 9.82 MB
    Introduction to Space Sciences & Spacecraft Applications
    http://rapidshare.de/files/21073501/...plications.rar 3.68 MB
    Castings - The New Metallurgy of Cast Metals
    http://rapidshare.de/files/21073781/...__2nd_ed._.rar 8.74 MB
    Biaxial-Mutiaxial Fatigue & Fracture
    http://rapidshare.de/files/21074044/...d_Fracture.rar 9.15 MB
    Hazardous Chemicals Handbook
    http://rapidshare.de/files/21074118/...__2nd_ed._.rar 1.89 MB
    Mechanical Engineer's Data Handbook
    http://rapidshare.de/files/21074477/...a_Handbook.rar 10.74 MB
    Metal Machining - Theory & Applications
    http://rapidshare.de/files/21074599/...plications.rar 2.42 MB
    A Guide to Collision Avoidance Rules
    http://rapidshare.de/files/21074700/...__6th_ed._.rar 3.10 MB
    Plastics Engineering
    http://rapidshare.de/files/21075205/...__3rd_ed._.rar 16.60 MB
    Ship Stability for Masters & Mates
    http://rapidshare.de/files/21075368/...__5th_ed._.rar 5.00 MB
    Fluid Mechanics - Thermodynamics of Turbomachinery
    http://rapidshare.de/files/21075455/...__4th_ed._.rar 2.67 MB
    Fiber Fracture
    http://rapidshare.de/files/21075707/...r_Fracture.rar 7.58 MB
    Carbon Nanotubes
    http://rapidshare.de/files/21075899/..._Nanotubes.rar 6.13 MB
    Ship Construction
    http://rapidshare.de/files/21076376/...__5th_ed._.rar
    The Motor Vehicle
    http://rapidshare.de/files/21076945/..._13th_ed._.rar
    Handbook of Production Management Methods
    http://rapidshare.de/files/21087968/...nt_Methods.rar
    Advance Vehicle Technology
    http://rapidshare.de/files/21088382/...__2nd_ed._.rar
    Lightweight Electric Hybrid Vehicle
    http://rapidshare.de/files/21088826/...cle_Design.rar
    Advanced Gas Turnie Cycles
    http://rapidshare.de/files/21089021/...ine_Cycles.rar 2.76 MB
    Aerodynamics for Engineerng Students
    http://rapidshare.de/files/21089629/...__5th_ed._.rar 9.21 MB
    Seamanship Techniques
    http://rapidshare.de/files/21090957/...__2nd_ed._.rar 20.40 MB
    Automotive Quality Systems Handbook
    http://rapidshare.de/files/21091201/...s_Handbook.rar 2.20 MB
    ISO 9000 Quality Systems Handbook
    http://rapidshare.de/files/21091332/...__4th_ed._.rar 2.64 MB
    ISO 9000 2000 - An A-Z Guide
    http://rapidshare.de/files/21091364/..._A-Z_Guide.rar 0.77 MB
    Engineering Rock Mechanics
    http://rapidshare.de/files/21092106/...__2_vols._.rar 16.01 MB
    Aircraft Design Projects for Engineering Students
    http://rapidshare.de/files/21092183/...g_Students.rar 1.97 MB
    Failure Analysis Case Studies
    http://rapidshare.de/files/21092632/...Studies_II.rar 8.43 MB
    Membranes for Industrial Wastewater Recovery & Re-Use
    http://rapidshare.de/files/21092904/...and_Re-Use.rar 5.58 MB
    Engineering Interfaces in Fiber Reinforced Engineering
    http://rapidshare.de/files/21093194/...Composites.rar 6.45 MB
    Introduction to Power Fluid Flow
    http://rapidshare.de/files/21093356/...Fluid_Flow.rar 3.52 MB
    Fluid Mechanics
    http://rapidshare.de/files/21094588/...__2nd_ed._.rar 20.55 MB
    Introduction to Continuum Mechanics
    http://rapidshare.de/files/21095360/...__3rd_ed._.rar 12.18 MB
    Project Planning & Control
    http://rapidshare.de/files/21095807/...__4th_ed._.rar 7.15 MB
    A Guide to MS Excel 2002 for Scientists & Engineers
    http://rapidshare.de/files/21096151/...__3rd_ed._.rar 5.43 MB
    Mechanics for Sheet Metal Forming
    http://rapidshare.de/files/21096273/...__2nd_ed._.rar 1.90 MB
    Mechanical Engineer's Handbook
    http://rapidshare.de/files/21097319/...s_Handbook.rar 15.25 MB
    Aeronautical Engineering
    http://rapidshare.de/files/21097449/..._Data_Book.rar 2.00 MB
    Beginning Autocad 2002
    http://rapidshare.de/files/21098216/...toCAD_2002.rar 10.85 MB
    Modelling with Autocad 2002
    http://rapidshare.de/files/21099053/...toCAD_2002.rar 11.71 MB
    Marine Auxilliary Machinery
    http://rapidshare.de/files/21101172/...__7th_ed._.rar 29.69 MB
    Aircraft Structures for Engineerig Students
    http://rapidshare.de/files/21102717/...__3rd_ed._.rar 19.57 MB
    Industrial Control Wiring Guide
    http://rapidshare.de/files/21102801/...__2nd_ed._.rar 1.09 MB
    Root Cause Failure Analysis
    http://rapidshare.de/files/21103576/...e_Analysis.rar 10.68 MB
    Vibration Fundamentals
    http://rapidshare.de/files/21104156/...ndamentals.rar 8.84 MB
    An Introduction to Predictive Maintenance
    http://rapidshare.de/files/21104424/...__2nd_ed._.rar 2.52 MB
    Plant Engineering Handbook
    http://rapidshare.de/files/21105785/...g_Handbook.rar 13.85 MB
    Hydroblasting & Coating Steel Structure
    http://rapidshare.de/files/21106047/...Structures.rar 3.29 MB
    Metal Fatigue - Effects of Small Defects and Non_Metallic Inclusions
    http://rapidshare.de/files/21106567/...Inclusions.rar 6.76 MB
    The Tribology Handbook
    http://rapidshare.de/files/21108113/...__2nd_ed._.rar 16.60 MB
    Statistical Process Control
    http://rapidshare.de/files/21108247/...__5th_ed._.rar 2.20 MB
    The Material Science of Thin Films
    http://rapidshare.de/files/21109526/...Thin_Films.rar 20.35 MB
    Tyre Mechanics & Vehicle Dynamics
    http://rapidshare.de/files/21109924/...e_Dynamics.rar 6.64 MB
    Rules of Thumb for Mechanical Engineers
    http://rapidshare.de/files/21111539/..._Engineers.rar 18.11 MB
    Basic Ship Theory
    http://rapidshare.de/files/21111966/...__2_vols._.rar 7.08 MB
    The Automotive Chassis - Engineering Priciples
    http://rapidshare.de/files/21112682/...__2nd_ed._.rar 12.61 MB
    Understanding Automotive Electronics
    http://rapidshare.de/files/21113600/...__5th_ed._.rar 16.51 MB
    Safety at Work
    http://rapidshare.de/files/21114121/...__6th_ed._.rar 8.76 MB
    Plastics Engineered Product Design
    http://rapidshare.de/files/21114691/...uct_Design.rar 9.44 MB
    Robotics - Designing the Mechanisms for Automated Machinery
    http://rapidshare.de/files/21115723/...__2nd_ed._.rar 9.25 MB
    Ship Design for Efficiency and Economy
    http://rapidshare.de/files/21115827/...__2nd_ed._.rar 1.37 MB
    Methods for Monitoring & Diagnosing the Efficiency of Catalytic Converters
    http://rapidshare.de/files/21116151/...Converters.rar 5.72 MB
    Mechanical Engineer's Reference Book
    http://rapidshare.de/files/21118756/..._12th_ed._.rar 34.59 MB
    Engineering Tribology
    http://rapidshare.de/files/21134578/...__2nd_ed._.rar 9.27 MB
    Tribology in Machine Design
    http://rapidshare.de/files/21134840/...ine_Design.rar 5.63 MB
    The Science & Technology of Carbon Nanotubes
    http://rapidshare.de/files/21135045/..._Nanotubes.rar 3.36 MB
    Introduction to Marine Engineering
    http://rapidshare.de/files/21136558/...__2nd_ed._.rar 32.19 MB
    Electronic Navigation
    http://rapidshare.de/files/21137248/...__3rd_ed._.rar 15.58 MB
    3D Fibre Reinforced Polymer Composites
    http://rapidshare.de/files/21137447/...Composites.rar 4.88 MB
    Refrigeration & Airconditioning
    http://rapidshare.de/files/21137603/...__3rd_ed._.rar 3.72 MB
    Introduction to Naval Architecture
    http://rapidshare.de/files/21138239/...__3rd_ed._.rar 17.29 MB
    Mechanics & Analysis of Composite Materials
    http://rapidshare.de/files/21138457/..._Materials.rar 5.57 MB
    Practical Ship Designs
    http://rapidshare.de/files/21139123/...hip_Design.rar 20.10 MB
    TPM - A route to World Class Performance
    http://rapidshare.de/files/21139461/...erformance.rar 9.35 MB
    Marine Diesel Engines & Gas Turbines
    http://rapidshare.de/files/21139937/...__8th_ed._.rar 12.53 MB
    Practical Design of Ships & Other Floating Structures
    http://rapidshare.de/files/21140446/...s__vol._1_.rar 13.47 MB
    Carbon Alloys - Novel Concepts to Develop Carbon Science & Technology
    http://rapidshare.de/files/21140779/...Technology.rar 9.18 MB
    The Finite Element Method
    http://rapidshare.de/files/21142390/...__3_vols._.rar 15.96 MB
    The Theory & Design of AIr Cushion Craft
    http://rapidshare.de/files/21144432/...hion_Craft.rar 43.99 MB
    Linux Embedded & Real Time Applications
    http://rapidshare.de/files/21308729/...plications.rar 1.04 MB
    Power Electronic Control in Electrical Systems
    http://rapidshare.de/files/21308940/...al_Systems.rar 6.23 MB
    Application of Non_Linear Fibre Optics
    http://rapidshare.de/files/21309076/...ber_Optics.rar 3.83 MB
    Non-Linear Fibre Optics
    http://rapidshare.de/files/21309199/...__3rd_ed._.rar 2.49 MB
    Industrial Power Engineering & Applications Handbook
    http://rapidshare.de/files/21310023/...s_Handbook.rar 26.18 MB
    PC Troubleshooting Pocketbook
    http://rapidshare.de/files/21310212/...__2nd_ed._.rar 3.32 MB
    Embedded Controller Hardware Design
    http://rapidshare.de/files/21310241/...are_Design.rar 0.91 MB
    Analog Interfacing to Embedded Microprocessors
    http://rapidshare.de/files/21310314/...rld_Design.rar 2.57 MB
    Embedded Microprocessor Systems - Real Worlkd Design
    http://rapidshare.de/files/21310640/...__3rd_ed._.rar 11.11 MB
    Handbook of Medical Imaging Processing & Analysis
    http://rapidshare.de/files/21311207/...d_Analysis.rar 19.54 MB
    Erbium Dope Fibre Amplifiers - Fundamentals & Technology
    http://rapidshare.de/files/21311946/...Technology.rar 28.60 MB
    Understanding Telephone Electronics
    http://rapidshare.de/files/21312179/...__4th_ed._.rar 8.58 MB
    Electrical CIcuit Theory & Technology
    http://rapidshare.de/files/21312336/...__2nd_ed._.rar 5.22 MB
    Handbook of Image & Video Processing
    http://rapidshare.de/files/21312989/...Processing.rar 26.62 MB
    RF CIrcuit Design
    http://rapidshare.de/files/21313389/...uit_Design.rar 16.03 MB
    Guide to Digital TV
    http://rapidshare.de/files/21313540/...__2nd_ed._.rar 6.55 MB
    Radio & Elctronics Cookbook
    http://rapidshare.de/files/21313647/...s_Cookbook.rar 4.54 MB
    Power Supply Cookbook
    http://rapidshare.de/files/21308695/...__2nd_ed._.rar 2.53 MB
    Practical Switching Power Supply Design
    http://rapidshare.de/files/21313856/...ply_Design.rar 8.37 MB
    Telecommunications Demystified
    http://rapidshare.de/files/21314189/...emystified.rar 2.51 MB
    Computer Busses - Design & Apllication
    http://rapidshare.de/files/21314369/...pplication.rar 4.07 MB
    Antenna Toolkit
    http://rapidshare.de/files/21314481/...__2nd_ed._.rar 4.16 MB
    RF Components & Circuits
    http://rapidshare.de/files/21314530/...d_Circuits.rar 1.89 MB
    Embedded FreeBSD Cookbook
    http://rapidshare.de/files/21314549/...D_Cookbook.rar 0.70 MB
    Neural & Fuzzy Logic Control of Drives & Power Systems
    http://rapidshare.de/files/21314625/...er_Systems.rar 1.90 MB
    CMOS IC Layout - Concepts, Methodologies & Tools
    http://rapidshare.de/files/21314818/..._and_Tools.rar 7.79 MB
    Introduction to Fibre Optics
    http://rapidshare.de/files/21314881/...__2nd_ed._.rar 2.04 MB
    Battery Reference Book
    http://rapidshare.de/files/21315528/...__3rd_ed._.rar 27.50 MB
    High Frequenmcy & Microwave Engineering
    http://rapidshare.de/files/21315870/...ngineering.rar 14.32 MB
    Fibre Optic Data Communications - Technological Trends & Advances
    http://rapidshare.de/files/21316157/...d_Advances.rar 9.03 MB
    Handbook of Fibre Optic SData Communication
    http://rapidshare.de/files/21316849/...__2nd_ed._.rar 30.65 MB
    Electric Vehicle Battery Systems
    http://rapidshare.de/files/21316871/...ry_Systems.rar 0.95 MB
    The Digital Consumer Technology Handbook
    http://rapidshare.de/files/21317233/...y_Handbook.rar 17.21 MB
    Tunable Lasers Handbook
    http://rapidshare.de/files/21317396/...s_Handbook.rar 7.76 MB
    WDM Technologies - Active Optical Components
    http://rapidshare.de/files/21321156/...Components.rar 12.20 MB
    Radio Frequency Transistors - Principles & Practical Applications
    http://rapidshare.de/files/21321305/...__2nd_ed._.rar 6.77 MB
    Designing Ebedded Internet Devices
    http://rapidshare.de/files/21321394/...et_Devices.rar 3.44 MB
    Fibre Optic Cabling
    http://rapidshare.de/files/21321449/...__2nd_ed._.rar 2.72 MB
    Handbook Digital Signal Processing
    http://rapidshare.de/files/21322178/...plications.rar 28.92 MB
    Observers in Control Systems
    http://rapidshare.de/files/21322294/...ical_Guide.rar 4.01 MB
    Adaptive Control Systems
    http://rapidshare.de/files/21322348/...ol_Systems.rar 2.06 MB
    Newnes Interfacing Companion
    http://rapidshare.de/files/21322414/..._Companion.rar 3.30 MB
    Introduction to Statstical Pattern Recognition
    http://rapidshare.de/files/21322588/...__2nd_ed._.rar 6.27 MB
    The Art of Designing Embedded Systems
    http://rapidshare.de/files/21322840/...ed_Systems.rar 10.13 MB
    Miltimedia Communications - Directions & Innovations
    http://rapidshare.de/files/21323711/...nnovations.rar 34.20 MB
    Modern Dictionary of Electronics
    http://rapidshare.de/files/21324476/...__7th_ed._.rar 29.56 MB
    Essential JAva for Scientist & Engineers
    http://rapidshare.de/files/21324525/..._Engineers.rar 1.58 MB
    The JP Transformer Book
    http://rapidshare.de/files/21324671/..._12th_ed._.rar 5.16 MB
    Analog Circuits Cookbook
    http://rapidshare.de/files/21324741/...__2nd_ed._.rar 1.76 MB
    Practical Radio Frequency Handbook
    http://rapidshare.de/files/21324800/...__3rd_ed._.rar 1.89 MB
    Video Demystified - A Handbook for the Digital Engineer
    http://rapidshare.de/files/21324964/...__3rd_ed._.rar 5.07 MB
    Dictionary of Video & Television Technology
    http://rapidshare.de/files/21325022/...Technology.rar 1.45 MB
    Introduction to Medical Electronics Applications
    http://rapidshare.de/files/21325215/...plications.rar 7.18 MB
    Optical Fibre Telecommnication III
    http://rapidshare.de/files/21326185/...__2_vols._.rar 28.97 MB
    http://rapidshare.de/files/21327356/...__2_vols._.rar 33.46 MB
    Fibre Bragg Gratings
    http://rapidshare.de/files/21328363/...g_Gratings.rar 29.25 MB
    Mixed Signal & DSP Design Techniques
    http://rapidshare.de/files/21328512/...Techniques.rar 3.93 MB
    RF & Microwave Radiation Safety Handbook
    http://rapidshare.de/files/21328672/...__2nd_ed._.rar 4.24 MB
    Radar Systems Peak Detection & Tracking
    http://rapidshare.de/files/21328734/...d_Tracking.rar 1.98 MB
    High Voltage Engineering - Fundamentals
    http://rapidshare.de/files/21328875/...__2nd_ed._.rar 4.14 MB
    Electrical Engineering Reference Book
    http://rapidshare.de/files/21329879/..._16th_ed._.rar 28.39 MB
    Telecommunications Circuits & Technology
    http://rapidshare.de/files/21330385/...Technology.rar 2.20 MB
    A Wavelet Tour of Signal Processing
    http://rapidshare.de/files/21333361/...__2nd_ed._.rar 18.94 MB
    Op Amps for Everyone
    http://rapidshare.de/files/21333448/...r_Everyone.rar 2.09 MB
    Third Generation CDMA Systems for Enhanced data Services
    http://rapidshare.de/files/21333754/...a_Services.rar 7.72 MB
    Practical Handbook of Photovoltaics - Fundamentals & Applications
    http://rapidshare.de/files/21334373/...plications.rar 16.39 MB
    Bebop to the Boolean Boogie
    http://rapidshare.de/files/21335174/...__2nd_ed._.rar 21.88 MB
    Power Electronics Handbook
    http://rapidshare.de/files/21335693/...__3rd_ed._.rar 12.19 MB
    Electrical Installations in Hazardous Area
    http://rapidshare.de/files/21336850/...dous_Areas.rar 28.37 MB
    Feature Extraction & Image Processing
    http://rapidshare.de/files/21339068/...Processing.rar 3.11 MB
    Programmable COntrollers - An Engineer's Guide
    http://rapidshare.de/files/21339917/...__3rd_ed._.rar 17.90 MB
    Troubleshooting Analog Circuits
    http://rapidshare.de/files/21340525/...h_Circuits.rar 11.48 MB
    http://rapidshare.de/files/21341543/...s_Handbook.rar 20.68 MB
    Fuzzy Controllers
    http://rapidshare.de/files/21341673/...ontrollers.rar 3.00 MB
    Building A Successful Board Test Strategy
    http://rapidshare.de/files/21342729/...__2nd_ed._.rar 20.61 MB
    Photoreactive Organic Thin Films
    http://rapidshare.de/files/21345010/...Thin_Films.rar 31.76 MB
    Audio Power AMplifier Design Handbook
    http://rapidshare.de/files/21345202/...__3rd_ed._.rar 3.83 MB
    Audio & Hi-Fi Handbook
    http://rapidshare.de/files/21345360/...__3rd_ed._.rar 3.74 MB
    Sensors & Transducers
    http://rapidshare.de/files/21345426/...__3rd_ed._.rar 1.32 MB
    http://rapidshare.de/files/21346724/...Scientists.rar 16.65 MB
    SMT Soldering Handbook - Surface Mount Technology
    http://rapidshare.de/files/21346823/...__2nd_ed._.rar 2.10 MB
    Intellignt Communication Systems
    http://rapidshare.de/files/21347627/...on_Systems.rar 14.69 MB
    OpAmps - Design, Application, & Troubleshooting
    http://rapidshare.de/files/21348883/...__2nd_ed._.rar 23.04 MB
    Pattern Recognition
    http://rapidshare.de/files/21349366/...__2nd_ed._.rar 10.14 MB
    Engineering Digital Design
    http://rapidshare.de/files/21351504/...__2nd_ed._.rar 39.70 MB
    Newnes Data Communications Pocket Book
    http://rapidshare.de/files/21351545/...__4th_ed._.rar 0.86 MB
    CE Conformity MArking & New APproach Directive
    http://rapidshare.de/files/21351629/...Directives.rar 1.64 MB
    Newnes Guide to Television & Video Technology
    http://rapidshare.de/files/21352113/...__3rd_ed._.rar 8.62 MB
    Programming Microcontrollers
    http://rapidshare.de/files/21352479/...__2nd_ed._.rar 6.60 MB
    Fabricating Printed Circuit Boards
    http://rapidshare.de/files/21352549/...uit_Boards.rar 1.39 MB
    DSP Integrated Circuits
    http://rapidshare.de/files/21353541/...d_Circuits.rar 19.44 MB
    Newnes Electrical Engineer's Handbook
    http://rapidshare.de/files/21354374/...s_Handbook.rar 15.47 MB
    Analog Circuit Design - Art Science & Personalities
    http://rapidshare.de/files/21355358/...sonalities.rar 18.82 MB
    The Art & Science of Analog Circuit Design
    http://rapidshare.de/files/21357527/...uit_Design.rar 23.07 MB
    EMC for Product Designers
    http://rapidshare.de/files/21357692/...__3rd_ed._.rar 3.25 MB
    Analog & Digital Filter Design
    http://rapidshare.de/files/21357993/...__2nd_ed._.rar 5.43 MB
    Newnes Radio & RF Engineering Pocket Book
    http://rapidshare.de/files/21358088/...__3rd_ed._.rar 1.61 MB
    Introduction to Information Optics
    http://rapidshare.de/files/21359596/...ion_Optics.rar 30.12 MB
  8. [218]
    فلسطين والنضال
    Engineering Mathematics
    http://rapidshare.de/files/21051025/...__4th_ed._.rar 3.79 MB
    Computational Fluid Dynamics
    http://rapidshare.de/files/21052513/...plications.rar 7.31 MB
    Machinery Component Maintenance & Repair
    http://rapidshare.de/files/21055043/...__2nd_ed._.rar 9.65 MB
  9. [219]
    عومةعبدو
    عومةعبدو غير متواجد حالياً
    merciiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiii
  10. [220]
    محمد حسام راضي
    محمد حسام راضي غير متواجد حالياً
    بارك الله فيك
