مجموعه كبيرة جدا من الكتب بمختلف التخصصات الهندسيه .
صفحة 10 من 33 الأولىالأولى ... 6 7 8 9 1011 12 13 14 20 ... الأخيرةالأخيرة
النتائج 91 إلى 100 من 329
  1. [91]
    فلسطين والنضال
    فلسطين والنضال غير متواجد حالياً
    الصورة الرمزية فلسطين والنضال
    Java for Dummies 4th edition
    Java is good stuff. I’ve been using it for years. I like Java because it’s very orderly. Almost everything follows simple rules. The rules can seem intimidating at times, but this book is here to help you figure them out. So, if you want to use Java and w
    Pro JSP 2
    Welcome to the fourth edition of Professional JSP, designed to help new and experienced Java developers alike discover the power (and even the joy) of creating Java-based server-side solutions for the Web by using JavaServer Pages, or JSP for short. If yo
    Servlets and JavaServer Pages: The J2EE Technology Web Tier
    Servlets and JavaServer Pages is the first complete guide to building dynamic Java-based Web applications using the new JavaServer Pages 2.0 and Servlets 2.4. Servlets and JavaServer Pages (JSP) provide a robust solution to developing large, complex Web a
    Pro Wicket
    Welcome to Wicket, an open source, lightweight, component-based Java web framework that brings the Java Swing event-based programming model to web development. Componentbased web frameworks are being touted as the future of Java web development, and Wicke
    Beginning JSP 2: From Novice to Professional
    Developing Chemical Information System AN OBJECT-ORIENTED APPROACH USING ENTERPRISE JAVA
    Hundreds of books are in the marketplace about object-oriented analysis, design, and programming. A handful of books are about cheminformatics. But no book exists about how to apply object technology to the cheminformatics domain. This book is an attempt
    Rails for Java Developers
    Ruby on Rails is a full-stack framework for developing web applications. Rails embraces many good ideas that are familiar in the Java world: the Model-View-Controller (MVC) pattern, unit testing, agile development, the ActiveRecord pattern, and many other
    Quartz Job Scheduling Framework
    If your Java applications depend on tasks that must be performed at specific times or if your systems have recurring maintenance jobs that could be automated, then you need Quartz: the first full-featured, open source job scheduling framework.
    Java 6 Platform Revealed
    So you like living on the bleeding edge and want to learn about Java 6, aka Mustang. Welcome. What you hold in your hands is a look at the newest features of the early access version of Mustang. Working through the early access releases from Sun, I’ve pai
    Java Concurrency in Practice
    Threads are a fundamental part of the Java platform. As multicore processors become the norm, using concurrency effectively becomes essential for building high-performance applications. Java SE 5 and 6 are a huge step forward for the development of concur
    Quartz Job Schedulling Framework Building Open Source Enterprise Applications
    Foundations of Java for ABAP Programmers
    Java has been a part of developers’ vocabularies since 1995. At first it was thought of as being a nice, neat little language that could do some amazing things for the Internet. However, the language soon matured, and it still kept its simple approach. De
    Core Swing: Advanced Programming
    The book zeroes in on two aspects of Swing interfaces. First, there are over 500 pages on optimizing your usage of a variety of Swing text controls. The author provides solutions to mimicking native-style operating system support for data validation, nume
    Practical Ajax Projects with Java Technology
    If you’re a Java developer already versed in Ajax-style programming, and you want to take your knowledge to the next level, then this is the book for you. Practical Ajax Projects with Java Technology provides the ultimate learn-by-example experience, feat
    Java and XML
    Two hot topics come together in this developer’s guide from Brett McLaughlin, Java and XML. Both Java and XML are cross-platform technologies; by using Java for code and XML for transporting data, you can build truly portable applications. This title is a
    Design Patterns Java Workbook
    his title fills a valuable niche by reprising the well-known guide to patterns, Addison-Wesley’s Design Patterns: Elements of Reusable Software Design. While that earlier book relied on C++ and Smalltalk for its examples, this new volume uses Java code fo
    Mastering Enterprise JavaBeans 3 0 4th Edition Jul 2006
    Featuring myriad changes from its previous versions, EJB 3.0 boasts a very different programming and deployment model, with nearly every aspect of development affected. Even the most experienced EBJ and J2EE developers will need to relearn how to best use
    Eclipse Step by Step
    Written for novice programmers who need to learn Eclipse, the new integrated, open-source development environment, this book covers three areas that are of crucial interest—Eclipse, IBM’s Software Widget Toolkit (the SWT), and JDBC. Questions such as how
    JDBC Metadata MySQL and Oracle Recipes A Problem Solution Approach
    JDBC Metadata, MySQL, and Oracle Recipes is the only book that focuses on metadata or annotation-based code recipes for JDBC API for use with Oracle and MySQL. It continues where the author's other book, JDBC Recipes: A Problem-Solution Approach, leaves o
    Java 6 Platform Revealed Jul
    Be among the first to capture an early look at the libraries of Java™ SE 6, aka Mustang. While J2SE™ 5.0 is just now starting to become regularly adopted, Java™ 6 Platform Revealed takes a look at the next release of the Standard Edition platform to come
    سوف نقتلهم جميعا وسوف نشرب دمائهم في كاس انتفاضتنا وليكن نخبه الموت لنا ولهم ولتحيا فلسطين
  2. [92]
    فلسطين والنضال
    Pro JSP 2
    Pro Wicket
    Java and XML
  3. [93]
    فلسطين والنضال
    Introduction to Computing and Programming with Java A Multimedia Approach Apr 2006
    New computer science students are far more motivated when they are creating programs they care about. Reflecting that insight, this complete first course in Java introduces each new concept in the context of programs that manipulate students’own sounds, p
    The Definitive Guide to Building Java Robots
    The Definitive Guide to Building Java Robots is for educators, students, hobbyists, and startups looking for Java/hardware interaction. This book shows you how to use your PC to build robots, and how you can interface with a microcontroller to do the basi
    Beginning Java EE 5 From Novice to Professional
    The Java 2 Enterprise Edition (J2EE) is an extremely powerful platform for developing enterprise-level Java-based applications, primarily for the server. This book shows you how to harness that power, examining how the pieces of the new J2EE 5 platform fi
    Java I O 2nd Edition
    All of Java's Input/Output (I/O) facilities are based on streams, which provide simple ways to read and write data of different types. Java provides many different kinds of streams, each with its own application. The universe of streams is divided into fo
    Java Object Oriented Problem Solving 3rd Edition
    Offers a robust, accessible, and flexible problem-solving approach to Java programming by introducing objects early, to ensure that readers can benefit from a big picture perspective. Softcover. CD-ROM included.
    Pro JSP 2 4th Edition Dec 2005
    Simon Brown works in London as a technical architect and has been using Java since its early beginnings, working in roles ranging from developer and architect to mentor and trainer. In the past few years, Simon has presented at the JavaOne conference and
    Eclipse Building Commercial Quality Plug ins 2nd Edition Mar 2006
    This new edition of Eclipse: Building Commercial-Quality Plug-ins is the definitive, start-to-finish guide to building commercial-quality Eclipse plug-ins, with an emphasis on adding the sophistication and polish that paying customers demand. The book pro
    SCJD Exam with J2SE 5 2nd Edition Dec 2005
    SCJD Exam with J2SE 5, Second Edition is a valuable guide to prepare for This book has been updated for the new Java version, J2SE 5.0, and works its way through a project with requirements and structure similar to the project you'll encounter in the exam
    Enterprise JavaBeans 3 0 5th Edition May 2006
    If you're up on the latest Java technologies, then you know that Enterprise JavaBeans (EJB) 3.0 is the hottest news in Java this year. In fact, EJB 3.0 is being hailed as the new standard of server-side business logic programming. And O'Reilly's award-win
    Professional Java User Interfaces May 2006
    Focuses on building high quality industrial strength software in Java
    Ivor Hortons Beginning Java 2 JDK 5 Edition
    This book is a comprehensive introduction to the Java programming language, updated thoroughly (more than 35ew and updated) for the latest SDK 1.5 release. This book shows readers how to build real-world Java applications using the Java SDK. No previous p
    Beginning Java Server Pages
    JSP is one of the core technologies for server-side Java applications and the 2.0 release, which this book covers in detail, makes JSP an even more powerful tool
    Includes more than 30 percent revised material and five new chapters, covering the new 2.1 features such as EJB Timer Service and JMS as well as the latest open source Java solutions
    Mastering Enterprise JavaBeans 3rd Edition
    Complete Java 2 Certification Study Guide
    Here's the book you need to prepare for the Java 2 Programmer (SCJP) and Developer (SCJD) exams. This Study Guide was developed to meet the exacting requirements of today's certification candidates. In addition to the consistent and accessible instruction
    Java I O 2nd Edition May 2006
    Java Programming for the Absolute Beginner
    Java is an object-oriented language that is extremely popular with programmers and Web developers. This beginner-level book teaches readers the fundamental programming concepts they need to grasp in order to learn any computer language. The unique approac
    Java Practical Guide for Programmers
    If you're an experienced programmer, you already have a rock-solid foundation for learning Java. All you need is a resource that takes your experience into account and explains Java's key principles and techniques in an intelligent, efficient way.
    JUnit Recipes Practical Methods for Programmer Testing
    When testing becomes a developer's habit good things tend to happen--good productivity, good code, and good job satisfaction. If you want some of that, there's no better way to start your testing habit, nor to continue feeding it, than with JUnit Recipes.
    Art of Java Web Development
    A guide to the skills required for state-of-the-art web development, this book covers a variety of web development frameworks. The uses of the standard web API to create applications with increasingly sophisticated architectures are highlighted, and a dis
  4. [94]
    فلسطين والنضال
    Beginning JavaServer Pages
    Java All-In-One Desk Reference For Dummies
    Nine minibooks filling more than 800 pages provide the world's five million-plus Java developers with a basic all-in-one programming reference. Covers the recent release of the Java 2 Platform Standard Edition 5.0 and the new J2SE Development Kit 5.0
    Eclipse for Dummies
    In his friendly, easy-to-understand style, the bestselling author of Java 2. For Dummies shows developers how to get up to speed fast on this popular Java IDE. Eclipse, an open source product originally developed by IBM, has an estimated 500,000 users-a
    Beginning Java Programming for Dummies 2nd Edition
    Covering everything from basic Java development concepts to the latest tools and techniques used in Java, this book will put would-be programmers on their way to Java mastery
    JBoss 4 0 The Official Guide
    If you need to understand how JBoss works, why not learn it from the people who created it? JBoss 4.0 ¡ª The Official Guide is the authoritative resource recognized as the official print documentation for JBoss 4.0. The only book for advanced JBoss users,
    Rapid J2EE Development An Adaptive Foundation for Enterprise Applications
    Rapid J2EE Development Preface Three months, or you re dead! These were the opening words of the keynote speaker at a conference I attended over what now seems a long time ago. Three months, the speaker s argument went, was the time available to turn an i
    Java Application Development on Linux
    JAVA AND LINUX Why another book on Java? Why a book on Java and Linux? Isn't Java a platform-independent system? Aren't there enough books on Java? Can't I learn everything I need to know from the Web? No doubt, there are a host of Java books on the marke
    Core Java 2 Volume II Advanced Features 7th Edition
    To the Reader The book you have in your hands is the second volume of the seventh edition of Core Java 2. The first volume covers the essential features of the language; this volume covers the advanced topics that a programmer will need to know for profes
    Apache Jakarta Commons Reusable Java Components Read NFO
    Preface Preface I originally noticed the Jakarta Commons libraries while working with Apache Jakarta Tomcat. At some point, Tomcat started to include a suite of small libraries with commons in the name. They started to show up everywhere, in all sorts of
    SWT A Developers Notebook
    The Eclipse platform continues to gain tremendous popularity as both a Java IDE and a Java platform for application programming. One of the core underpinnings of Eclipse is SWT, the Standard Widget Toolkit. This set of components can be used to develop gr
    QuickTime for Java A Developers Notebook
    QuickTime Java (QJT) is a terrific multimedia toolkit, but it's also terrifying to the uninitiated. Java developers who need to add audio, video, or interactive media creation and playback to their applications find that QTJ is powerful, but not easy to g
    Jakarta Commons Cookbook
    As a Java developer, you're always looking for tools to help in your web and application development. Maybe you've heard of the Jakarta Commons open source Java tools. The Jakarta Commons is an open source Jakarta subproject where developers create and ma
    AspectJ Cookbook
    When Object Oriented programming (OO) first appeared, it was a revelation. OO gave developers the ability to create software that was more flexible and robust, but as time went on and applications became more sophisticated, too, certain areas of "traditio
    Ant The Definitive Guide 2nd Edition
    Ant is the premiere build management tool for use in Java environments. Unlike traditional build management tools such as GNU Make, Ant is itself written in Java, is platform independent, and interfaces well with the utilities in Sun's Java software devel
    Concurrent and Real Time Programming in Java
    Real-time functionality is essential for developing many consumer, industrial, and systems devices. While the C/C++ programming language is most often used in the creation of real-time software, the Java language, with its simple and familiar object-orien
    Test Driven Development A J2EE Example
    Test-driven development was first introduced as part of the extreme programming (XP) paradigm. While not everyone agrees with all aspects of XP, most developers believe in the benefits of test-driven development. Although the basic techniques of test-driv
    Hibernate A J2EE Developers Guide
    Hibernate makes it far easier to build robust, high-performance database applications with Java. Now there's a practical, hands-on guide to using Hibernate's flexible, fast object/relational persistence and query services. Will Iverson covers every facet
    Eclipse Distilled
    Eclipse Distilled Eclipse Distilled Preface This is the book I wanted to read when I started using Eclipse three years ago. The book didn t exist until now. It s different from other books that assume you know nothing, but it does not leave you hanging if
    Developing Scalable Series 40 Applications A Guide for Java Developers
    There is still plenty of opportunity to get in on the "ground floor" of this industry and then ride the wave... to the top. Ever since we first developed the DoCoMo Java architecture that started it all, people have been asking me "what is the killer appl
    The Art Of Java
    There is something for every programmer in this book, which presents a number of practical, high-powered applications of Java. Included are pure code subsystems such as the expression parser, which readers will adapt for use in their own programs, financi
  5. [95]
    kashif99048
    kashif99048 غير متواجد حالياً
    Exclamation
    فلسطين والنضال your collection is great and i appreciate your efforts......
    dear i have been looking for a solution manual of satellite communication 4th/3rd edition by dennis roddy
    i have tried my self a lot but couldnt find any where ...
    if you could help me ..i will be thankful to you
  6. [96]
    عبد الله المسلم
    عبد الله المسلم غير متواجد حالياً
    الله يرضى عليك
    حقا إنك قد تعبت جمع هذا
    فجزاك الله خيرا
  7. [97]
    kashif99048
    any one who could help me with the above mentioned book please
    i don't know arabic .......
  8. [98]
    المهندس يوسف حافظ
    المهندس يوسف حافظ غير متواجد حالياً
    الصورة الرمزية المهندس يوسف حافظ
  9. [99]
    فلسطين والنضال
    Richard von Mises, Kurt O. Friedrichs “Fluid Dynamics”
    Springer | 1981-10-12 | ISBN: 0387900284 | 353 pages | Djvu | 2,4 MB
    Like the animal it’s named for, Mac OS X Panther is beautiful, sleek, superbly efficient, dangerously alluring, and all muscle under the surface. Beneath its appealing interface, it’s a hard-working machine. Those coming to Mac OS X from previous incarnations of the operating system recognize much of the friendly face of the Macintosh they’re used to, but they’re also plunged into a whole new world.
    Unix converts to Mac OS X find a familiar FreeBSD-like operating system at the core and many of the command-line applications that they’re familiar with: it’s like an open invitation to roll up their sleeves and hack. Mac OS X Panther Hacks brings together the perfect combination of tips, tricks, and tools to help serious Mac users–regardless of their background–get the most from their machines. This revised collection reflects the real-world know how of those well-steeped in Unix history and expertise, sharing their no-nonsense, sometimes quick-and-dirty solutions to administering and taking full advantage of everything a Unix desktop has to offer: Web, Mail, and FTP serving, security services, SSH, Perl and shell scripting, compiling, configuring, scheduling, networking, and hacking. Add to that the experience of die-hard
    depositfiles.com
    easy-share
    filefactory
  10. [100]
    فلسطين والنضال
    CCENT Exam Cram (Exam 640-822) (c) by Que
    The type of the release is: eBook
    In the PDF format with ISBN: 0789737159 and Pub Date: January 05, 2008
    The size of the release is: 04 disks x 1.44mb
    And released on: 01/20/2008
    In this book, you learn how to:
    - Develop perfect fluency in subnetting
    - Understand the OSI model and the Cisco three-layer hierarchical
    model
    - Connect Cisco equipment, make initial configurations, and connect to
    other devices to build a network
    - Configure Cisco routers and back up and restore your Cisco IOS
    Software configurations
    - Implement, verify, and troubleshoot a small, switched network
    - Configure and verify a basic WAN serial connection
    - Understand and apply wireless LAN (WLAN) concepts
    - Mitigate network security threats and secure network devices
    - Configure static routes and RIPv2
    - Connect a small office to the Internet
    WRITTEN BY CCNA/CCENT Experts!
    Michael Valentine has been in the IT field for 12 years, focusing on
    network design and implementation. He is currently a Cisco trainer with
    Skyline Advanced Technology Services and specializes in Cisco Unified
    Communications instruction as well as CCNA and CCNP courses.
    Andrew Whitaker is the director of enterprise InfoSec and networking and
    senior training instructor for Training Camp. He has achieved several
    Cisco certifications and has written on several Cisco topics.
    http://www.amazon.com/exec/obidos/tg.../-/0789737159/
    DownloadDownload This Torrent Announcehttp://tpb.tracker.thepiratebay.org:80/announceHash5050c2b6031b8ed355a1597f2bc44b3fd11618 daTotal Size5.06 MBsSeeds160Peers10File Listbbl.nfo3.03 KBsebookshare.net.url189 Bytesfile_id.diz368 BytesQue.CCENT.Exam.Cram.Exam.640-822.Jan.2008.pdf5.05 MBs
