برامج في تصميم الدوائر الكهربائية والبورد
النتائج 11 إلى 20 من 29
    فلسطين والنضال
    فلسطين والنضال غير متواجد حالياً
    الصورة الرمزية فلسطين والنضال
    Electrical Analysis
    Volts Standard Edition (1-3 licenses)
    Volts comprises a collection of electrical analysis modules and calculators into one unique, easy to use tool. With it, you have the
    number crunching power to effectively deal with electrical devices, current and ground conductors, circuit breakers,
    transformers, generators, motors, branch circuits, conduits, junction boxes, cable trays and more, with the assurance of knowing
    the calculations are as specified and required by the 2002 NFPA National Electrical Code®. The Circuit Load Analysis module is a
    true multi-circuit analysis tool utilizing all 34 NEC® ampacity tables with gauges displayed in either AWG, mm ² or kcmils. You are
    always informed with constantly updated accumulated voltage drop, real power, and ampacity values as the circuit is developed.
    Information derived form Volts' accurate calculations can not only be printed with preset reports, schedules and customizable
    report writers, but also exported in a csv file format where it can be utilized by any other database or spreadsheet Windows®
    applications as well as saved to disk in Volts' proprietary .elc file format. With over 110 supported NEC® tables, specifications and
    requirements, Volts’ calculations will enable you to get the job done right the first time, in a few minutes.
    Download
    Digital Simulators
    MacroSim Digital Simulator - Personal Edition
    MacroSim Digital Simulator is a software tool that integrates the process of designing and simulating the operation of digital
    electronic circuitry. It consists of the Graphic-oriented intuitive Editor which supports the schematic symbols of both standards:
    American and European, the Automatic Router which allows you not to think how to connect two or more component entries, the
    extremely fast and powerful Simulation Engine which allows you to simulate such complex components like microcontrollers and
    their peripherals with a minimal precision as one femtosecond, the Diagram Generator which represents the data generated by
    the simulation engine in a graphical format, and the large Library of digital parts with over 400 models.
    Download
    Flowcharts and Circuit Diagram Software
    RFFlow License
    RFFlow is everything you need to start communicating your ideas with professional-quality charts and diagrams. For
    presentations, printed documents, your Intranet, or the Web, great looking diagrams for business, education, and industry have
    never been so easy to accomplish.
    Download
    RFFlow Package
    Download
    Electrical Calculations for Designers and Electricians
    ElectricalPAK
    Turn your calculating minutes into seconds with these practical electrical calculation programs.
    Download
    سوف نقتلهم جميعا وسوف نشرب دمائهم في كاس انتفاضتنا وليكن نخبه الموت لنا ولهم ولتحيا فلسطين
    msadek80
    msadek80 غير متواجد حالياً
    الصورة الرمزية msadek80
    do you have protel 99
    باشمهندس برلوم
    باشمهندس برلوم غير متواجد حالياً
    الف شكر لك على مجموعة البرامج الجميلة
    tarekdia
    tarekdia غير متواجد حالياً
    الصورة الرمزية tarekdia
    حاولت تنزيل برنامج DolphineVolt V4.01
    ولكن لم تكن الرابطة سليمة
    ولكن وجدت رابطة اخرى وهى
    http://rs2.rapidshare.com/files/8184...sVolts4.01.rar
    وجزاك الله خيرا على هذه المجموعة الرائعة من البرامج
    نزار عبدالولى
    نزار عبدالولى غير متواجد حالياً
    مشكور بس واجهتني مشكلة في التحميل أرجو التوضيح والموقع شبه محظور عزا.....
    مهندسة سومة
    مهندسة سومة غير متواجد حالياً
    الصورة الرمزية مهندسة سومة
    جزاك الله خيرااااااااااااااااااااااااا
    meshkah
    meshkah غير متواجد حالياً
    mashkoooooooorrrrrrrrrrrrrrrrrrrrrrrr
    تقى عمر محمود
    تقى عمر محمود غير متواجد حالياً
    مشكور اخى الكريم
    المهندس412
    المهندس412 غير متواجد حالياً
    مشكووووووووووووووووووووووووووووووريييييييييييييييي ييييييييييييييييييننننننننننننننننننننننننن يا ابطال العرب
    سيوان 70
    سيوان 70 غير متواجد حالياً
    الله يعطيك العافية وشكررررررررررررررررررررررررررا
