برامج في تصميم الدوائر الكهربائية والبورد
النتائج 1 إلى 10 من 29
    الصورة الرمزية فلسطين والنضال
    فلسطين والنضال
    فلسطين والنضال غير متواجد حالياً
    هذه مجموعة من البرامج المهمة في هذاالمجال
    Design your own Printed Circuit Boards
    Download
    B2 Spice AD v5.1.8
    Electronic Circuit Simulation Software
    http://rapidshare.com/files/63535826/BS5_reup.rar
    NI Circuit Design Suite Educational v10.0.1 ISO | 305 MB
    http://www.filefactory.com/file/be3586
    http://www.filefactory.com/file/17c1af
    http://www.filefactory.com/file/c6c351
    http://www.filefactory.com/file/c1e244
    NI Circuit Design Suite Pro v10.0.1 ISO | 295 MB
    http://www.filefactory.com/file/7f8070
    http://www.filefactory.com/file/6b7eed
    http://www.filefactory.com/file/a44a60
    http://www.filefactory.com/file/4609a7
    NI Multisim Analog Devices Edition v10.0.1 | 215 MB
    http://www.filefactory.com/file/5baacc/
    فلسطين والنضال
    Tolerance Data v2006.2 3CD | 1.5 GB
    The Tolerance Data programme is designed to provide technician-friendly functions, which ensure fast and accurate access to the latest data available in the Automotive field. Circuit Diagrams and trouble shooting for electrical systems are built up in a systematic manner, which enables the mechanic to work with accurate, time-saving methods. The integration between Tolerance Data, the spare parts catalogues and the test-equipment also takes high priority, since these functions also involve time savings.
    Tolerance A/S has for many years been the market leader in the production of technical data for vehicles. This experience guarantees the high quality of the data supplied to your workshop
     TECHNICAL DATA
     SERVICE SCHEDULES
     REPAIR TIMES
     ENGINE MANAGEMENT
     ABS - ESP
     AIRBAGS
     AIRCONDITIONING
     ELECTRICAL CIRCUIT DIAGRAMS
     TECHNICAL DATA – Trucks and vans
     SERVICE SCHEDULES - Trucks and vans
     ABS-EBS - Trucks and vans
     ENGINE MANAGEMENT - Trucks and vans
    Download
    http://www.filefactory.com/file/f0ce5a/
    سوف نقتلهم جميعا وسوف نشرب دمائهم في كاس انتفاضتنا وليكن نخبه الموت لنا ولهم ولتحيا فلسطين
    فلسطين والنضال
    AWR Design Environment v7.52.3682 | 415 MB
    Built on an advanced software architecture, the unique core technology in the AWR Design Environment is a modern object-oriented data model that is inherently open and flexible compared to legacy design tools. The AWR Design Environment elevates the product development process by allowing the entire engineering team to effortlessly integrate Analog Office circuit designs into one platform with Visual System Simulator (VSS) for system design and TestWave for simulation with test and measurement equipment, providing an accurate understanding of the impact of today's complex modulated RF signals and "real world" circuit performance. The result is a truly revolutionary design approach that enables interactive tradeoffs between system requirements and circuit implementation.
    AWR's open software architecture and industry-standard application programming interface give customers easy access into the underlying data structures, allowing seamless integration with other best-in-class tools and design environments. This protects customers' investment in models and simulators, lowers their cost of support, and enables easy customization of specific flow requirements.
    Download
    http://www.filefactory.com/file/6a3ecd/
    فلسطين والنضال
    PCB Wizard 3 is a powerful package for designing single-sided and double-sided printed circuit boards (PCBs).
    http://rapidshare.de/files/32299951/PCB_Wizard_3.50_Pro.zip
    This is a very rare PCB program , (printed circuit board) , you cant find it easily , and it is very similar to Orcad but it is much lighter on
    your PC and easier to handel and work with
    Download Link : Size : 7 MB
    http://rapidshare.com/files/67678/Eagle_v4.11e.rar
    Edit Del
    فلسطين والنضال
    يارب تنال اعجابكم
    فلسطين والنضال
    The CircuitMaker 2000 | 10 MB
    Electronic education software for circuit designing
    The CircuitMaker 2000 importer has been improved:
    * Files containing macros (reusable pieces of circuitry) are better handled.
    * Situations where the libraries (DEVICE & USER) are not loaded before the CKT files are now managed more appropriately. Now an adequate error will be added to the CM2000 log file & the loading process will be stopped.
    * When the the current locale decimal separator is different from '.' (period), CircuitMaker2000 files are still imported correctly.
    * Loading of corrupted CKT files has been improved. In these cases, an error will be added to the importer's log file and the loading process will stop.
    * The Setup dialog has been improved and streamlined.
    * If no path is specified in the Setup dialog (when no values are found in LoadCM2000.INI file), default directories are displayed in Libraries Path & Models Path edit boxes. These default directories are: %DXPInstallationDirectory%SystemCircuitMaker2000Li braries & %DXPInstallationDirectory%SystemCircuitMaker2000Mo del. If these directories don't contain the required SchLib libraries or models then an error will be added to the log file when the importer tries to find the components in the loaded libraries.
    http://rapidshare.com/files/898068/circuit_maker2000.rar.html
    http://rapidshare.com/users/SL9H51
    Edit Del
    فلسطين والنضال
    فلسطين والنضال
    Gerbview v6.11
    Win App | 2.1mb | RS.COM
    DOWNLOAD
    فلسطين والنضال
    BluePrint-PCB 1.1.2
    OS: Windows | ~158 Mb
    http://rapidshare.de/files/33435801/...part1.rar.html
    http://rapidshare.de/files/33437465/...part2.rar.html
    http://rapidshare.de/files/33439159/...part3.rar.html
    http://rapidshare.de/files/33439755/...art4.rar.html”Edit Del
    CADSOFT Eagle ver. 4.16 Professional Edition Retail | 5,61 Mb
    Program Features (Professional Edition)
    General
    * online Forward- and Back-Annotation
    * context sensitive help function
    * no hardware copy protection!
    * multiple windows for board, schematic and library
    * powerful User Language
    * integrated text editor
    * available for Windows, Linux and Mac
    Layout Editor
    * maximum drawing area 1.6 x 1.6m (64 x 64 inch)
    * resolution 1/10,000mm (0.1 micron)
    * up to 16 signal layers
    * conventional and SMT parts
    * comes with a full set of part libraries
    * easily create your own parts with the fully integrated library editor
    * undo/redo function for ANY editing command, to any depth
    * script files for batch command execution
    * copper pouring
    * cut and paste function for copying entire sections of a drawing
    * design rule check
    Schematic Editor
    * up to 99 sheets in one schematic
    * electrical rule check
    * gate and pinswap
    * create a board from a schematic with a single command
    Autorouter
    * ripup&retry router
    * routing strategy driven by user definable cost factors
    CAM Processor
    * Postscript
    * pen plotters
    * Gerber plotters
    * Excellon and Sieb&Meyer drill files
    * configurable through ASCII file for easy definition of your own output devices
    System Requirements
    General
    * mouse
    * at least 32MB RAM
    * harddisk with at least 40MB free space
    Windows
    * PC 586 (or higher)
    * Windows 95/98/Me/NT4/2000/XP
    Linux
    * Linux (i386) kernel 2.x (or higher)
    * X11 in at least 8bpp mode with 1024x768 min. resolution
    Mac
    * Apple Macintosh G3 (or higher)
    * Mac OS X 10.3
    Drawing the schematic
    Checking the schematic
    Creating the board
    Placing the parts
    Routing the signals
    Editing the board
    Autorouter
    Checking the board
    Fine tuning the project
    Copper pouring
    Producing CAM data
    User Language
    h**p://rapidshare.de/files/37522537/500.rar
    فلسطين والنضال
    Artwork GBRComp v1.15a | Win32 |Size: 5.2 MB
    Download Here:
    Rapidshare
    Or
    Depositfiles
