برامج رائعه لتصميم الهندسة المعمارية والصناعية مع الصور
صفحة 8 من 15 الأولىالأولى ... 4 5 6 7 89 10 11 12 ... الأخيرةالأخيرة
النتائج 71 إلى 80 من 143
  1. [71]
    فلسطين والنضال
    فلسطين والنضال غير متواجد حالياً
    الصورة الرمزية فلسطين والنضال
    وترقبوا المزيد
    سوف نقتلهم جميعا وسوف نشرب دمائهم في كاس انتفاضتنا وليكن نخبه الموت لنا ولهم ولتحيا فلسطين
  2. [72]
    فلسطين والنضال
    IronCAD Inovate 10.0.7984 | 161 MB
    Between today's viewer technology and complete CAD software packages lies Inovate - a 3D design solution that works throughout the product lifecycle. From conception to completion, Inovate allows users to explore and verify creative design opportunities at any stage of product development. Even unforeseen pre/post production modifications are easily resolved using Inovate's powerful capabilities. It is perfectly suited for situations where 3D design concepts must be verified before committing to a formal design process. Inovate allows quick exploration and communication of 3D design concepts through photo-realistic images and animations extending the collaboration process.
    Rapidshare.com Part 1
    and
    Rapidshare.com Part 2
  3. [73]
    فلسطين والنضال
    SI Xchange for Revit Structure 0.5
    Win l english | zip | 1Mb
    Structural Integrators’ has developed an interface between Autodesk Revit Structure and Bentley Systems’ STAAD.Pro. You can now avoid duplication of effort by exporting your Revit Structure model to STAAD.Pro for analysis and design.
    Features
    Export capabilities - SI Xchange sends structural Revit elements (beams, columns and braces), as well as boundary conditions, to STAAD.Pro. Both steel and concrete materials and section properties are supported.
    Model any way you want - SI Xchange automatically breaks up continuous beams and multi-story columns for analysis in STAAD.Pro.
    Name resolution - SI Xchange is preconfigured to resolve standard naming convention differences for steel section profiles, yet is flexible enough to allow for new mappings between profile names for firms that use customized or in-house naming conventions.
    Customization - SI Xchange provides configurable options that are saved between sessions.
    Reporting - SI Xchange displays a summary of exported members and provides a log file that identifies any problems on export.
    Download:
    http://www.filefactory.com/file/16b173/
  4. [74]
    فلسطين والنضال
    Cadmai 3.0 | 39,5 MB
    CADMAI is a relational 2D and 3D CAD system , which can be integrated in 3rd party applications or in a SOA environment.
    Basic Features
    * Completely parametric and relational
    * Integrated script API which serves as a modeling language
    * Can be steered by external applications
    * Can be hosted in external applications
    * Embedded formula interpreter
    * Supports a hierarchical assembly structure
    * User defined animations
    * User defined entity attributes and methods
    * API for embedding CADMAI in external solutions
    * Base geometry API for technical applications
    Non geometric entities
    * User defined dialogs
    * User defined objects
    * User defined variables
    * Attributes
    * Tables and row cursors incl. ODBC Database connections
    * Layers
    * Programming structures (loop/ifthen) which can be integrated in the model
    2D entities
    * Points (15 creation methods)
    * Lines (11 creation methods)
    * Arcs (20 creation methods)
    * Curves
    * Views and sections from solid data
    * Hatches/area fill
    * Transformations
    * Symbols
    * Text
    * Labels
    * Dimensioning
    3D entities
    * Coordinate systems
    * Solid creation (16 creation methods)
    * Solid modification (23 methods)
    * Polygon based 3D representations (Wavefront/3DS/...)
    * Components
    * FEM Meshes
    Import/Export
    * Bill of material (table format)
    * DXF, IGES, STEP, VRML, STL, XCAF, PARASOLID/ACIS/3D-DXF on request
    * OBJ, 3DS, ASC, X, OBT, IOB, DAT, LWO, C, UDO, RAW, RWX, SCE
    * BMP, PNG, JPG, TIFF
    * AVI
    * User defined export formats
    API
    * Windows API
    enables the user to embed CADMAI Windows in applications. CADMAI herby provides special Window classes which can be used similar to the Common Controls
    * Object API
    serves as an independent geometric library which can be used outside of CADMAI.
    This library includes the following objects:
    Points, Lines, Arcs, Curves, Hatches, Matrices, Coordinate systems, Views, Solids,
    Greps, Dimensions, Symbols, Texts, Tables, Cursors, Layers, Attributes, Variables, Dialogs
    * Batch API
    enables the usage of CADMAI batch processes and the control of loaded CADMAI models.
    * Connect API
    enables the connection to CADMAI batch process at the same or a remote computer and the remote control of the process.
    Rapidshare.com
  5. [75]
    فلسطين والنضال
    IronCAD 10.0.7984 | 170 Mb
    Utilizing a breakthrough approach to creative design, IronCAD is the productivity leader for moving creative ideas into 3D reality. IronCAD offers a level of design freedom that is unmatched in the industry today. It is the tool of choice for design engineers when deadlines are tight and a high degree of unanticipated change is expected. IronCAD's drag and drop 3D environment provides a fresh alternative to traditional history-based parametric systems; delivering unmatched ease of use and superior productivity.
    and
  6. [76]
    فلسطين والنضال
    TurboCAD Professional 15.1 | 195 MB
    TurboCAD® 15 Deluxe 2D/3D gives you unlimited design options with hundreds of professional drafting and design tools, incredible file support, video and interactive tutorials, photorealistic rendering and millions of symbols. TurboCAD Deluxe delivers everything you need. Create presentation-ready home plans, technical drawings, mechanical designs, artistic illustrations, crafts, school projects and more.
    Perfect for:
    * Architects
    * Illustrators
    * Contractors
    * Builders
    * Hobbyists
    * Designers
    * Educators
    * Engineers
    * Students
    * And more!
    Rapidshare Part 1
    and
    Rapidshare Part 2
  7. [77]
    فلسطين والنضال
    AcroPlot Pro 2008.4.29 | 61,7 MB
    AcroPlot Pro is the next generation in digital CAD conversion software. With the capability to convert an extensive list of file formats and the flexibility to create both the Portable Document Format (PDF) and the Drawing Web Format (DWF), AcroPlot Pro will serve as a nexus for CAD Professionals everywhere.
    Includes a full version of the PDF Printer Driver to create PDF files from any application.
    Converts all major office, various CAD, and graphics formats.
    Create single or multi-paged PDF and DWF files.
    Merge existing DWF files into one multi-paged DWF 6 files.
    Full support for AutoCAD 14 and newer. Also supports all vertical applications including ADT, MDT, LDDT, and Map.
    Powerful built-in viewer allows users to create and convert without AutoCAD installed!
    Convert legacy PLT, TIFF, CALS, and GP4 files to either DWF or PDF.
    Automatic rotation of PLT and graphics files ensures the proper orientation every time.
    Built-in engineering paper sizes and complete customizable paper sizes insures that output can meet any standard or requirement.
    Includes the AcroPlot Jr. program also for conversion from inside of AutoCAD.
    Rapidshare
  8. [78]
    فلسطين والنضال
    ViaCAD 2D 3D v5.0.1 | 750 MB
    ViaCAD 2D/3D allows you to quickly toggle between 2D and 3D views. To help you get started, there are over 80 minutes of tutorial videos.
     LogiCursor Thinks As You Draw
    Simple interface with LogiCursor technology aids in visually anticipating your moves, partnering with you in the design process.
     2D/3D Seamless Interface (patent pending)
    Toggle between 2D and 3D with one mouse click. Start in 2D, add 3D with surface modeling tools. Then click back to 2D, making precision editing a snap.
     Effortless Cross-Platforming & Compatibility
    Share your files among Mac and PC ViaCAD users. Import and export options for popular drafting formats such as AutoCAD, .DWG, and Adobe Illustrator
    Download
    http://www.filefactory.com/file/fc0f44/
  9. [79]
    فلسطين والنضال
    SynaptiCAD AllProducts v12.20a | 78 MB
    Includes the following produkts from SynaptiCAD:
    TestBencher Pro
    VeriLogger Pro
    Waveformer Pro
    DataSheet Pro
    TimingDiagrammer Pro
    1.VHDL, Verilog, and TestBuilder Graphical Test Bench Generation
    TestBencher Pro is a graphical test bench generator that dramatically reduces the time required to create and maintain test benches. One of the most time consuming tasks for users of HDL languages is coding test benches to verify the operation of their design. In his book "Writing Testbenches," Janick Bergeron estimates that 70% of design time is spent verifying HDL code models and that the test bench makes up 80% of the total HDL code generated during product development.
    2.High-performance compiled-code Verilog 2001 simulator
    VeriLogger Extreme is a completely new, high-performance compiled-code Verilog 2001 simulator that significantly reduces simulation debug time. VeriLogger Extreme offers fast simulation of both RTL and gate-level simulations with SDF timing information. VeriLogger Extreme supports design libraries and design flows for all major ASIC and FPGA vendors, including Actel, Altera, Atmel, LSI Logic, QuickLogic, and Xilinx.
    3.WaveFormer Pro is a revolutionary new rapid-prototyping EDA tool that helps you design faster and with fewer mistakes. WaveFormer Pro enables you to automatically determine critical paths, verify timing margins, adjust for reconvergent fanout effects, and perform "what if" analysis to determine optimum clock speed. WaveFormer Pro also lets you specify and analyze system timing and perform Boolean level simulation without the need for schematics or simulation models. When your timing diagram is complete, you can then generate digital stimuli for your favorite Verilog, VHDL, SPICE or gate-level simulator. WaveFormer Pro has the ability to import and annotate simulation and logic analyzer data, for publication quality design documentation.
    4.DataSheet Pro provides the ultimate environment for documentation professionals working with multi-diagram projects. Datasheet Pro's project management features allow users to efficiently combine diagrams from multiple engineers into one project with uniform formatting. Using Object Linking and Embedding (OLE), users can embed timing diagrams into other publishing programs. These images can be edited at any time directly from the publishing program by double clicking on the image to launch DataSheet Pro with the selected timing diagram. Other features include style sheets, view support, web-ready image generation, analog waveform import and display, and support for the industry-standard Timing Diagram Markup Language (TDML) format. Documentation professionals will be able to receive timing diagrams produced by design engineers using any TDML-compatible product, such as WaveFormer Pro or Timing Diagrammer Pro, and embed them directly into publishing programs like FrameMaker and Word.
    5.Timing Diagrammer Pro has everything that you expect in a timing diagram editor: a modeless drawing and editing environment; delays, setups, and holds for performing timing analysis; time markers; seven graphical waveform states; virtual and group buses; clocks with formulas; as well as a variety of ways to document your work. A great timing analysis tool at a great price, Timing Diagrammer Pro is a must-have for any engineer.
    Download
  10. [80]
    فلسطين والنضال
    وترقبوا المزيد المزيد
