برامج رائعه لتصميم الهندسة المعمارية والصناعية مع الصور
صفحة 5 من 15 الأولىالأولى 1 2 3 4 56 7 8 9 ... الأخيرةالأخيرة
النتائج 41 إلى 50 من 143
  1. [41]
    فلسطين والنضال
    فلسطين والنضال غير متواجد حالياً
    الصورة الرمزية فلسطين والنضال
    DataCAD 11
    Posted: 2007-03-27 0136 UTC-07:00
    DataCAD is a professional-level AEC CADD program for architectural design, photo-realistic rendering, animation, and construction document creation. Developed by architects and software engineers for architecture, DataCAD includes tools that make design and drafting easier, such as automatic door and window insertion, associative dimensioning and hatching, automated 3D framing and OpenDWG-based DXF/DWG translators. DataCAD is listed as the second most-widely used software by registered architects according to the most recent American Institute of Architects (AIA) firm survey.
    FOR THE ARCHITECT . . .
    DataCAD allows you to draft, edit, and prepare precision construction documents. More than just a drafting tool, DataCAD includes automated 3D modeling, and photorealistic rendering tools that put you ahead of the competition. You control the lighting, cast shadows, and apply texture maps to create compelling, 24-bit colour images of your latest design. Visualizing a project in advance allows you and your client to save time and money by agreeing on changes earlier in the design process.
    FOR THE CONTRACTOR . . .
    Load DataCAD on your laptop and take it right to your building site. It has special features for builders and contractors to help you increase productivity and improve quality. For example, DataCAD’s built-in framing utility automates 3D framing for floors, walls and roofs. You actually see the software 'walk around' building walls, and locate stair, door, window, and skylight openings.
    LINK1
    LINK2
    سوف نقتلهم جميعا وسوف نشرب دمائهم في كاس انتفاضتنا وليكن نخبه الموت لنا ولهم ولتحيا فلسطين
  2. [42]
    فلسطين والنضال
    Surfer 8
    Posted: 2007-03-26 23:46:17 UTC-05:00
    Surfer is a contouring and 3D surface mapping program that runs under Microsoft Windows. It quickly and easily converts your data into outstanding contour, surface, wireframe, vector, image, shaded relief, and post maps.It quickly and easily converts your data into outstanding contour, surface, wireframe, vector, image, shaded relief, and post maps. Virtually all aspects of your maps can be customized to produce exactly the presentation you want.Virtually all aspects of your maps can be customized to produce exactly the presentation you want. Producing publication quality maps has never been quicker or easierProducing publication quality maps has never been quicker or easier .
    LINK1
    LINK2
  3. [43]
    فلسطين والنضال
    CSI ETABS NL 9.0.7
    The integrated model can include Moment Resisting Frames, Braced Frames, Staggered Truss Systems, Frames with Reduced Beam Sections or Side Plates, Rigid and Flexible Floors, Sloped Roofs, Ramps and Parking Structures, Mezzanine Floors, Multiple Tower Buildings and Stepped Diaphragm Systems with Complex Concrete, Composite or Steel Joist Floor Framing Systems. Solutions to complex problems such as Panel Zone Deformations, Diaphragm Shear Stresses, and Construction Sequence Loading are now at your fingertips.
    LINK
    PASSWORD: www.devilived.com
  4. [44]
    فلسطين والنضال
    The HousePartner application is designed for architects, building contractors and producers/marketers of prefabricated houses. One module (House Building) assists with outlines, design criteria, general and detailed planning as well as automatic quantity billing. The other module (Timber Frame) addresses construction and structural details. It generates all relevant production drawings in 2D and 3D, including cutting bills and complete bill of quantities. Data is transferred directly to production lines for cutting and assembly.
    LINK1
    LINK2
  5. [45]
    فلسطين والنضال
    CS EARTHWORK 2
    This is a Digitizer Based Earthwork Computation Program. Utilizes Average End Method for cross sections determined at an interval you specify. You digitize in all fault lines and other line data. Create Existing Ground Surface and Multiple Proposed ground surfaces for comparison.
    LINK
  6. [46]
    فلسطين والنضال
    • CAST Strut-Tie
      It is a very good software for Computer Aided Strut and Tie Design.
      download
      LINK
    • Robot Millennium 18.0
      A Finite Element Analysis and Design Package designed primarily for the Structural Engineering and Civil Engineering professions. Robot Mechanical also provides a package for Mechanical Engineers, offering cost effective FEA with very high standards of capability, for example ACIS Solid Modelling etc.
      LINK
  7. [47]
    فلسطين والنضال
    AcadCalcStair - Stair and Rail Auto drafting program + Calculator for AutoCAD. Main features: · STAIRS & RAILS. Parametrical Modeling and Auto Drafting. On the base of parameters the program creates the drawing: Stair Plan and Elevation with all main dimensions. Available options: apply different scale; Visible or Hidden (behind the wall) representation of Stair Elevation · CALCULATIONS. Mathematical operations; Slope, Triangle and Stair calculations. All formats of numbers are acceptable: architectural, fractional, decimal and AutoCAD format · MODIFY AutoCAD objects. AcadCalcStair can directly perform AutoCAD commands using the results of calculations: move, copy, scale and array. Get distances from AutoCAD and use them in calculations - one of the options of program · PROTOCOL: results of calculations are automatically placed in Protocol, where the user can add comments. The protocol *******s can be copied and transferred through clipboard in any text editor.
    Download
  8. [48]
    فلسطين والنضال
    VariCAD 2007 v1.05
    VariCAD is 3D/2D CAD system primarily intended for engineering design. In addition to powerful tools for 3D modeling and 2D drafting and dimensioning, the CAD system provides libraries of standard mechanical parts (ANSI, DIN), calculations of standard mechanical components, and tools for working with bills of materials (BOM) and blocks. The comprehensive CAD software enables designers to quickly create, evaluate, and modify their models. VariCAD's high performance, powerful features, and simple and quick user interface make VariCAD the best value in the CAD market.
    LINK
  9. [49]
    فلسطين والنضال
    Point Cloud for AutoCAD 1.0
    This plug-in gives AutoCAD to ability to . You can import a point cloud into AutoCAD as it is or fit a surface that passes through the points to recreate the original object.
    This is ideal for reverse engineering and GIS applications. There are different ways of fitting a surface depending on the nature of the point cloud.
    Point Cloud for AutoCAD has the ability to compensate for probe diameter as well. There is an inherent error with probe based scanners since they digitize points at the center of the probe. Point Cloud for AutoCAD takes care of this very efficiently.
    oint Cloud for AutoCAD is very easy to use. It adds a new command to AutoCAD called "POINTCLOUD". Simply type "POINTCLOUD" at the AutoCAD command prompt and follow the simple instructions.
    LINK
  10. [50]
    abdo292001
    abdo292001 غير متواجد حالياً
    solidcam 2006 أو Solidcam2004
