برامج رائعه لتصميم الهندسة المعمارية والصناعية مع الصور
صفحة 13 من 15 الأولىالأولى ... 39 10 11 12 1314 15 الأخيرةالأخيرة
النتائج 121 إلى 130 من 143
  1. [121]
    فلسطين والنضال
    فلسطين والنضال غير متواجد حالياً
    الصورة الرمزية فلسطين والنضال
    VisualARQ is an application designed for the architectural sector.
    It uses the accessible and intuitive Rhino interface, providing the tools which make the architectural design process and its documentation much easier to handle.
    > Using VisualARQ, you can work in two dimensions and at the same time view the project 3D model (and vice versa).
    You can also move smoothly from one viewport/view to another, without having to exit the active command.
    > It generates documents which combine the drawing plans, three dimensional modeling as well as quantifies data (using documentation tables).
    All this information –2D plans, 3D model and tables- is linked and updates after each modification, saving vast amounts of time and significantly minimizing the margin of error.
    > Parametric architectural objects
    VisualARQ’s architectural objects are parametric; this means that you can define, vary and edit their pre-set values at any time. Automatic recalculation adjusts them to these changes.
    This makes the work process more efficient and offers endless possibilities...
    > In addition to being parametric, VisualARQ architectonic objects are also “intelligent”, as they behave like the real components they represent, thereby facilitating creating and editing processes:
    The door and window elements are associated with the walls they belong to; when any of these elements are moved, modified or removed, the wall is automatically updated adapting to the change.
    Railings and stairs work in the same way.
    VisualARQ can also automatically resolve buttresses and wall intersections.
    > Shape flexibility in wall outline:
    As in Rhino elements, VisualARQ walls are based on NURBS curves.
    This technology allows to draw walls from straight lines, arcs, or following free-form curves.
    > In order to make it easier to create and edit your architectural objects, VisualARQ offers user friendly wizards.
    These wizards include all editable parameters and a preview window to show all modifications in real time as they are made on the selected object.
    > VisualARQ has a command tool to automatically create sections and elevations on the project, as well as specific door and window elevations.
    As they are linked into the drawing, they are all updated after any changes.
    The door and window elevations also appear dimensioned and referenced using symbols on the plan drawing and its respective table.
    > Automatic area calculation option. Like other VisualARQ elements, Spaces are also linked, and they automatically adjust to changes made on their defining walls.
    > Not only are VisualARQ documentation tables linked to the drawing data, but they are also easy to edit.
    > VisualARQ has a library of architectural objects and basic profiles.
    > VisualARQ also offers optional manual or automatic dimensioning commands.
    Download: (Size: 4.3MB)
    سوف نقتلهم جميعا وسوف نشرب دمائهم في كاس انتفاضتنا وليكن نخبه الموت لنا ولهم ولتحيا فلسطين
  2. [122]
    فلسطين والنضال
    Corel Designer Technical Suite X4
    The ideal tool for creating technical illustrations and documentation, Corel DESIGNER Technical Suite X4 is a complete technical graphics application that offers precision illustration tools, bitmap-to-vector tracing, professional photo editing and industry-leading file compatibility, including 3D CAD.
    Corel DESIGNER Technical Suite X4 is the trusted choice for businesses that need to effectively communicate the strengths of their products and services through clear, informative technical illustrations or diagrams. From operation guides and parts catalogs, to schematics, wiring diagrams, assembly instructions, maintenance manuals and architectural presentations, this complete suite allows organizations of any size to create powerful technical graphics fast!
    Windows 32 & 64 Bit | 472 MB | ISO Image | 10 RAR Split with sfv | FF & RS
    Technical illustration software
    The latest version of the Windows technical illustration application provides 80 new and enhanced features.
    While best known for mass-market graphics applications such as its CorelDRAW Suite, Painter and Paint Shop Pro, Corel is also the developer of the lesser-known DESIGNER Technical Suite, geared to the creation of technical documentation, instructional manuals, maintenance references and technical diagrams. At heart a vector illustration application providing a high degree of precision, DESIGNER also includes a range of specialized drawing tools and functions, as well as the ability to handle with a broad range of technical file formats.
    The Suite aspect of the title refers to the included related applications, such as CorelPHOTO-PAINT X4, a competent photo editing tool that Corel at one time pitched as a competitor to Adobe Photoshop; Corel PowerTRACE X4 for converting bitmap images into vector format; Right Hemisphere Deep Exploration 5.5 CSE for converting 3D CAD models into 2D graphics; and Corel CAPTURE X4 for generating screen captures. Also part of the package is Microsoft Visual Basic for Applications 6.4; barcode and duplexing wizards; ANSI, DIN, ISO, engineering and architectural templates; and libraries containing over 4,000 manufacturing, electrical and architectural symbols.
    New in X4 is the ability to import 3D CAD data directly via an integrated 3D CAD import application, and import RAW camera files from more than 300 camera models. Additional new and enhanced file support includes AutoCAD DWG and DXF, PDF 1.7, PDF/A, as well as Microsoft Office Publisher and JPEG 2000. Also notable is the inclusion of new and improved diagramming tools; new technical drawing tools; the ability to draw, size, and rotate shapes and lines with precision using the Object Coordinates docker; and a new Image Adjustment Lab for creating professional-quality color and tone correction.
    What's Included:
    * Corel DESIGNER X4
    * Corel PHOTO-PAINT X4
    * Corel÷ PowerTRACE X4
    * Corel CAPTURE. X4
    * Right Hemisphere Deep Exploration. 5.5 CSE
    * Printed User Guide
    Code:
    Download From FileFactory
    http://www.filefactory.com/file/38a4a9/n/graf1032_r00
    http://www.filefactory.com/file/ad27a3/n/graf1032_r01
    http://www.filefactory.com/file/40c182/n/graf1032_r02
    http://www.filefactory.com/file/d09646/n/graf1032_r03
    http://www.filefactory.com/file/e4003e/n/graf1032_r04
    http://www.filefactory.com/file/76647c/n/graf1032_r05
    http://www.filefactory.com/file/08c87d/n/graf1032_r06
    http://www.filefactory.com/file/1c1576/n/graf1032_r07
    http://www.filefactory.com/file/239487/n/graf1032_r08
    http://www.filefactory.com/file/76f089/n/graf1032_rar
    http://www.filefactory.com/file/ef7e...af1032_sfv_rar
  3. [123]
    فلسطين والنضال
    Autodesk 3ds Max Design software introduces powerful lighting simulation and analysis technology, rendering capabilities, high levels of interoperability with Revit software, and more. Key technologies include Exposure, a toolset for simulating and analyzing sun, sky, and artificial lighting; Recognize, scene loading technology that significantly improves 3ds Max Design and Revit workflows; Reveal, iterative rendering technology for fast feedback and finished renderings; and ProMaterials technology, a library of accurate manufacturer-related materials.
    Exposure
    Exposure is a key technology, exclusive to 3ds Max Design, for simulating and analysing sun, sky and artificial lighting in a 3D scene. Ideal for sustainable architecture projects, this powerful feature set has been designed to assist architects in evaluating light intensity in their designs. This can facilitate the evaluation of indoor environmental quality – required, for example, for LEED 8.1 certification. In addition to light metering functionality with graphical output, Exposure also features the popular Autodesk® 3ds Max software sun and sky models, a quick-settings dashboard interface and an intelligent user interface for accessing the various aspects of the software used in a light simulation, such as render settings, light settings and material settings.
    Reveal Rendering
    The Reveal rendering system, gives you the precise control over your renders you need to quickly refine your work. Choose to render your entire scene minus a specific object or render one object only or a specific region of the Framebuffer. The rendered image Framebuffer contains a simplified set of tools to quickly validate changes in a render by optionally filtering out objects, regions or processes in order to balance quality, speed and completeness.
    Recognise
    With 3ds Max Design, Autodesk unveils Recognise, a powerful new technology that delivers new levels of 3ds Max Design and Revit interoperability. The FBX-based Recognise scene loading toolset lets you quickly–and very accurately–import geometry, lights, materials and cameras from your Revit scenes into 3ds Max Design, making it easier than ever to enhance your visual building information modelling (BIM) data.
    ProMaterials
    A new library of easy-to-use, physically-based materials for mental ray® software, based on manufacturing-related data and professional images, has been added to 3ds Max Design. These give you fast access to such commonly used building and design materials as professional wall paint–with glossy or matte finishes–solid glass and concrete.
    Review Enhancements
    Use Review to display multiple maps simultaneously in the Viewport, for more accurate previewing. Review now also offers full photometric light support (including IES files) for instant feedback on how real luminaries will affect the environment. Plus support is provided for real-time shadowing of objects that use architecture and design materials.
    ViewCube and SteeringWheels
    The ViewCube™ and SteeringWheels™ technology are on-screen, interactive UI features that give you a fast and intuitive means of navigating 3D scenes. Both tools are available in several Autodesk 3D products–ensuring a consistent navigation experience between software packages.
    Streamlined UV Texture Editing
    3ds Max and 3ds Max Design provide intelligent, easy-to-use mapping tools. Spline mapping features can be used to map tubular and spline-like objects. Additionally, Relax and Pelt workflows streamline UVW unwrapping, enabling you to achieve your desired results in fewer steps.
    Photometric Lighting Enhancements
    3ds Max Design delivers support for new types of area lights (circular, cylindrical), photometric web previews in the Browse dialog and Light user interface and near-field photometry quality and spot distribution. Plus, distribution types support any emitting shape and light shapes can be made to appear as objects in the rendered image.
    Code:
    http://rapidshare.com/files/12681751...gn2009_sp1.zip
  4. [124]
    فلسطين والنضال
    This image has been resized. Click this bar to view the full image. The original image is sized 700x700 and weights 72KB.
    CorelDRAW Graphics Suite X4 lets you tackle creative graphics and design projects with confidence. Precision tools, market-leading file compatibility and high-quality ******* help you turn your creative ideas into professional results: from distinctive logos and signs, to striking marketing materials and eye-catching web graphics.
    Include::
    CorelDRAW X4: An intuitive graphic design and page layout application.
    Corel PowerTRACE X4: The most accurate bitmap-to-vector tracing on the market.
    Corel PHOTO-PAINT X4: An image-editing application developed specifically for a graphic design workflow.
    Corel CAPTURE™ X4: A one-click screen capture utility.
    New and Enhanced Features
    - Modernized user interface
    - CorelDRAW ConceptShare™
    - Corel PowerTRACE™ X4
    - EWindows Color System
    - Adobe Color Management Module
    - Enhanced Windows Vista® integration
    - Interactive tables
    - Independent page layers
    - Integration with WhatTheFont™
    - CorelDRAW Handbook - Insights from the Experts
    - Support for RAW camera files
    - And much more.......
    Download
    Intallation
    Code:
    http://www.corel.com/akdlm/6763/down...staller_EN.exe
    Keymaker
    Code:
    http://rapidshare.com/files/12887681...4_Keymaker.rar
  5. [125]
    فلسطين والنضال
    وترقبوا المزيد باذن الله
  6. [126]
    وائل حفظى
    وائل حفظى غير متواجد حالياً
    لو سمحتو ابحث عن اوتوكاد 2007 ضروري
  7. [127]
    خابور
    خابور غير متواجد حالياً
    الصورة الرمزية خابور
    ماشاء الله ماشاء الله
    برامج روعة حقيقي روعة
    مشكور على هذا المجهود الكبير , الله يحفظك وينصر الفلسطين والمسلمين على الصهاينة المعتدين
    ان شاء الله النصر قريب بأذن الله تعالى.
  8. [128]
    فلسطين والنضال
    اقتباس المشاركة الأصلية كتبت بواسطة خابور مشاهدة المشاركة
    شكرا الك اخي الكريم انشاء الله نصرا لنا جميعن والله يوفقك
  9. [129]
    مهندس لوردبا
    مهندس لوردبا غير متواجد حالياً
    بيض الله وجهك برامج جميلة والف الف شكر
  10. [130]
    خالد البابلي
    خالد البابلي غير متواجد حالياً
    شكرا لك على هذه المعلومات القيمة
