مجموعه من البرامج مع الصور ادخل وحمل
صفحة 3 من 7 الأولىالأولى 1 2 34 5 6 7 الأخيرةالأخيرة
النتائج 21 إلى 30 من 70
  1. [21]
    فلسطين والنضال
    فلسطين والنضال غير متواجد حالياً
    الصورة الرمزية فلسطين والنضال
    Kaizen Vehicle Manager Fleet Network 2008 v2.0.1020.0 Enterprise Edition | 6.62MB
    EASY-SHARE.COM
    DEPOSITFILES.COM
    سوف نقتلهم جميعا وسوف نشرب دمائهم في كاس انتفاضتنا وليكن نخبه الموت لنا ولهم ولتحيا فلسطين
  2. [22]
    فلسطين والنضال
    Flowmaster 7.5.0.29018
    Windows | ~380MB
    Flowmaster is the leading 1D thermo fluid flow software package, designed for the engineers desktop PC. It helps engineers to design complex fluid systems and understand how mechanical events, such as valves shutting quickly and pump trip, affect the fluid dynamics of the whole system. Engineers using Flowmaster, can determine the pressure, flow rate and temperature at any point around their fluid system and for any type of system architecture open loop, closed loop, branched. Large complex fluid systems can be analysed in a matter of seconds, enabling multiple 'what if scenarios' to be investigated quickly and efficiently. Flowmaster is an industry leading fluid flow solution. Its advanced virtual modelling system enables you to carry out complex simulations throughout your development process, enhancing your design decisions and ensuring sustainable return on investment.
    Simulation and Validation
    Steady state and transient simulations to calculate pressure, flow rate temperature and heat flow at any point around your liquid or gas system and for any type of system architecture; open loop, closed loop, branched etc.
    Large complex fluid systems can be analysed in a matter of minutes, enabling multiple ‘what if scenarios’ to be investigated quickly and efficiently.
    Component models underpinned by empirical data from extensive research into fluid flow characteristics by DS Miller.
    Build in your own logic and rules
    Data Management
    A data management facility built on an industrial strength, multi-user relational database, giving you amazing flexibility in how you represent your models, data and results and the potential to integrate them into your whole design process in the future if desired.
    An audit trail facility directly relating results to input data, enabling you to keep track of changes in networks and data items, thereby ensuring quality.
    Customisation and Collaboration Tools
    Customisable catalogues of components and data with which you can organise your models and data to suit the way your company works, gain directly applicable design ******* from your suppliers and enable your design teams to perform ‘what-if’ simulations safely.
    Composite components which enable you to hide a complex group of components beneath a single ‘composite’ with its own symbol and datasheet, making it easy for others to utilise your models.
    Variable parameters providing a convenient way to relate different component data items such that a single data change can update multiple components.
    Access to our own development tools enabling you to create your own specialised component models that are fully integrated inside Flowmaster.
    Integration
    With our network of strategic CAE industry partnerships, you will benefit from the ability to communicate simulation data between Flowmaster and your existing CFD tools, allowing you to test the suitability of your designs at concept stage leading to more informed use of prototyping.
    Flowmaster provides the flexibility for you to integrate with your existing design and manufacturing systems, enabling multiple departments to work efficiently together at the early stages of a project, minimising the impact of design changes and reducing lead times.
    Advanced installation options will give you the potential to integrate with enterprise PLM databases, enabling the continuous flow of information through your entire product development lifecycle.
    Graphical User Interface
    Flowmaster’s intuitive left to right workflow GUI enables you to increase your productivity with easy to use approaches to building models and inputting data.
    Circuits, Sub-systems and Layers are graphical tools that give you methods of manipulating and controlling large or complex systems with great efficiency.
    The ability to add background images to your models enabling you to convey the meaning of your models with greater clarity.
    Continuity
    Minimise the disruption of your simulation projects and make full use of your legacy data when you upgrade to new versions of Flowmaster through a 100% upwardly compatible system.
    By allowing you to take full control of the component data and design parameters available to the team members on a project, you can ensure a continual level of quality across the development process and your organisation.
    With Flowmaster as your Strategic Partner, you have invested in the industry leading technology and can rely on our continual support and development to meet your future expectations.
    http://rapidshare.com/files/10600754..._RUZ.part1.rar
    http://rapidshare.com/files/10601378..._RUZ.part2.rar
    http://rapidshare.com/files/10601961..._RUZ.part3.rar
    http://rapidshare.com/files/10602425..._RUZ.part4.rar
    OR
    http://www.megaupload.com/?d=ND3B2KK5
    http://www.megaupload.com/?d=CW1M6G4E
    http://www.megaupload.com/?d=NJI195OT
    http://www.megaupload.com/?d=AXV7WYMZ
  3. [23]
    فلسطين والنضال
    CAESAR II | 327Mb
    CAESAR II is a comprehensive program for pipe stress analysis. CAESAR II has become the standard for pipe stress analysis, preferred by major corporations and engineering firms worldwide. It is the program by which all others are measured.
    6 * 50mb + 15mb
    http://rapidshare.com/files/10813928...RII_500.7z.001
    http://rapidshare.com/files/10814035...RII_500.7z.002
    http://rapidshare.com/files/10866765...RII_500.7z.003
    http://rapidshare.com/files/10867195...RII_500.7z.004
    http://rapidshare.com/files/10866914...RII_500.7z.005
    http://rapidshare.com/files/10867204...RII_500.7z.006
    http://rapidshare.com/files/10866956...RII_500.7z.007
    password :
    pc7
  4. [24]
    فلسطين والنضال
    شو رائيكم في البرامج من الاخر صح
  5. [25]
    فلسطين والنضال
    Aibase 2.04 | 5,14 MB
    Aibase is optimized for structuring thoughts and ideas in an efficient information space, leading to many positive effects on learning, creative work, task solving and project management. An efficient information space relieves the human memory in many ways. Computer memory is typically used as long-term memory. But optimized information spaces like Aibase also adapt to the specialties of the human short-term memory: They cluster related information visibly, and by links and notes. They emphasize information by colors. Fast navigation, automatic document-creation and single-key operations give you more time to focus on your information. You can quickly break down complex information into trees for better understanding.
    Aibase allows you to solve tasks with largest complexity. Such a task can grow up to thousands of linked documents (by help of automatic document-creation). The more complex a task, the higher the demands on the human memory. And the reverse: If the human memory is relieved, then the solvable complexity, quality and security increases. Users who spend much time with Aibase will even find that they never reach limits to understand new complex information.
    Aibase already optimizes well-known information structures: trees (collapsible), tables, shapes, equations, animations, hyperlinks, notes. These structures represent a solid platform for going into information spaces with more complexity. Future versions of Aibase will optimize further and will add many scientific structures, so we can interactively explore science in many dimensions (2D, 3D, and time). Aibase's main goal is to build a multilevel platform for knowledge-exploration. Higher levels (science) build on lower levels (visualization, simple math). Understanding a problem depends on the visualization of carefully chosen perspectives. The goal is to explore knowledge multiple times more efficient than with traditional methods. Experienced users are fascinated by the gained ability to understand complex or unknown knowledge worlds; computer-empowered methods are the indispensable basis for this new level.
    Rapidshare
  6. [26]
    فلسطين والنضال
  7. [27]
    فلسطين والنضال
    Primavera Project Planner 6
    Windows | ~594MB
    Primavera P6 is the most powerful, robust, and easy to use solution for globally prioritizing, planning, managing and executing projects, programs and portfolios. P6 is an integrated project portfolio management (PPM) solution comprising role-specific functionality to satisfy each team member’s needs, responsibilities and skills. It provides a single solution for managing projects of any size, adapts to various levels of complexities within a project, and intelligently scales to meet the needs of various roles, functions, or skill levels in your organization.
    P6 provides executives with a real-time view of their organization’s project, program and portfolio performance. It equips managers with the right blend of usability, power and flexibility to effectively and efficiently execute on projects, and enables individuals across all levels of an organization to analyze, record, and communicate reliable information and make timely, informed decisions. P6 makes it easy to:
    - select the right strategic mix of projects
    - assure project, IT and corporate governance
    - enhance processes and methods
    - improve project team collaboration
    - measure progress toward objectives
    - complete more projects successfully and with the intended payback.
    P6 Portfolio Management helps organizations align their portfolios of projects and programs with strategic objectives by taking advantage of advanced what-if scenario modeling, capacity analysis, tabular scorecards, rich graphics, and optimization functionality. It enables organizations to better manage incoming demand, seek the right balance of projects, ensure that resources are not overstretched, and easily communicate the performance of projects and programs to stakeholders.
    Get it (NO MIRRORS):
    http://rapidshare.com/files/103543569/pri_RUZ.part1.rar
    http://rapidshare.com/files/103558315/pri_RUZ.part2.rar
    http://rapidshare.com/files/103554212/pri_RUZ.part3.rar
    http://rapidshare.com/files/103560629/pri_RUZ.part4.rar
    http://rapidshare.com/files/103569667/pri_RUZ.part5.rar
    http://rapidshare.com/files/103578642/pri_RUZ.part6.rar
    http://rapidshare.com/files/103584468/pri_RUZ.part7.rar
    OR
    http://www.megaupload.com/?d=FDH9DO38
    http://www.megaupload.com/?d=1YFK9J7Z
    http://www.megaupload.com/?d=2FP689GV
    http://www.megaupload.com/?d=MY5T41ZZ
    http://www.megaupload.com/?d=72ITG4EX
    http://www.megaupload.com/?d=6PVFKDGH
    http://www.megaupload.com/?d=HCXWUJB3
  8. [28]
    فلسطين والنضال
    AWR Design Environment v7.52.3682 | 415 MB
    http://www.filefactory.com/file/6a3ecd/
  9. [29]
    فلسطين والنضال
    وهناك المزيد باذن الله
  10. [30]
    يعرب اصيل
    يعرب اصيل غير متواجد حالياً
    اخي الفاضل ياريت رابط ال hyperwork 8 مرة اخرى لان الرابط الذي وضعته لايعمل او الفايل غير موجود.
    يعطيك العافية وجزاك الله خيرا
