ups
النتائج 11 إلى 20 من 24
    محمدعبدالرحمن علام
    محمدعبدالرحمن علام غير متواجد حالياً
    Received: 15
    الأخت العزيزه ألاء
    اذا كان الغرض تغذية مبنى عند انقطاع التغذيه الكهربيه فالأفضل إستخدام مولد كهربـاء احتياطى. أما ال Ups فيستخدم فقط لتغذية أجهزه معينـه فـى الفتره من لحظة انقطاع التغذيه حـتى دوران المولد ونقل الحمل عليــه.
    hosamo
    hosamo غير متواجد حالياً
    There are more than one method to connect the UPS…
    • Off-line Method
    • Line-Interactive System
    • On-Line System (recommended)
    Why do we Use UPS?
    • Spikes (rapid Voltage transitions at the system)
    • Electrical Noise
    • Surges ( Upnormal Voltage values continues for a short time)
    • Brownouts (Upnormal Voltage values continues for a while)
    • Blackouts
    What the UPS consists of?
    Charger & Battery + Inverter (it will convert AC-current to DC and then to AC again to assure purity of the output current, without noise, harmonics or spikes).
    UPS Rating:
    • Small ranges (up to 2kVA)
    As an example of you want to connect a PC-Computer to a UPS to make sure it will not cut-out then you have to choose a small range UPS which rating is 0.25kVA ,but if you want to connect the printer and the computer together, then you have to choose a 2kVA UPS….and so on.
    Notice something that the UPS here will be rated for 3-Hours….and the selection of its rating will be on the supplier.
    • Medium Ranges ( 3 – 20kVA )
    As an example , if you want to connect lighting circuits in Villa or a small motor at your home ,or computers network in a company….
    You have to notice something here is that your UPS will in average work for 3-Hours and its rate of selection will be used by the supplier.
    I mean :
    You have a 10 Computers which together make one network, and you want to connect them to a UPS…you know that every computer is 0.5kW (as ex) so as total you have 5kW…that all what you want, is to tell the supplier that you need a UPS enough for 5kW and nothing more…( I will not go through design Criterias)
    In this case also you have to notice that the UPS is getting bigger in which it will be a Panel separated by its self and you can’t put it inside the same panel of load distribution because it is BIG.
    • Large Ranges (more than 20kVA in which it can reach 5MVA)
    They are very big sizes and cost a lot of money, and they are used in the important projects only…
    As an example … a 300kVA UPS will consist of 9-racks….each rack will be 600mmW x 2000mmH x 600mmD which is big.
    It continues for 3-5minutes in average because there will be a diesel generator which will support after 30seconds of the blackout.
    Note: kVA=kW/PF
    Wish you get educated…
    Have a nice day…
    ahmed shaban
    ahmed shaban غير متواجد حالياً
    المهندس محمد انا فنى كهرباء وكل شغلى كان على فازة واحة واليوم احتاج لشرح العمل على 3 فاز واتمنى ان يكون مع التوضح بالرسم للوحة توزيع منزل
    بشير الهيتي
    بشير الهيتي غير متواجد حالياً
    الصورة الرمزية بشير الهيتي
    Received: 47
    الاخت الاء المحترمة ان الجهاز الذي تسالين عنه وبالاسم ups له عدة معاني في الهندسة الكهربائية ارجو اعلامي اي نوع او لاي غرض تريدين المهندس بشير الهيتي
    ahmed_sss101
    ahmed_sss101 غير متواجد حالياً
    استاذى الكريم محمد عبد الرحمن اعمل فى مجال صيانة جسور فى احد المطارات ولدى 2 موتور 3فاز تعمل فى حالة مصدر الجهد الثابت وهو 380 فولت وتعمل هذة المواتير على انفرتر موديل altivar31 ولكن فى وضع الطوارئ وانقطاع مصدر الجهد تعمل هذة المواتير على وحدة upc ولكن 1 فاز وتعمل حتى ينتهى شحن البطاريات وهذا النظام تمت تجربتة اكثر من مرة وهو يعمل بكفائة ارجو الافادة فى كيفية عمل هذا النظام ولك منى جزيلالشكر والاحترام
    sardar77
    sardar77 غير متواجد حالياً
    سلام عليكم.....
    لدي ups 10kv كوري الصنع لديها 16 بطارية 12v-31AHمربوطة توالي ولكن البطاريات ماعاد تشتغل يعني خلص عمرها والان اريد ان ابدل بطارياتها دورت بالسوق ما حصلت عليهابس البطاريات الموجودة 12v-100AH فهل استطيع ان اركب هذه النوعية من البطاريةمع وجود فارق الامبيرية .....جواب من فضلكم
    alssafee
    alssafee غير متواجد حالياً
    السللام عليكم اخوتى الافاضل
    انا اقوم بتصميم مبنى اداري مكون من اربع طوابق وكل طابق ينقسم الى ادارتين كل ادارة تحتوي على حمل اجهزة الحاسوب بحدود (10 ك.ف.أ ) بالاضافة الى حمل الانارة .
    فهل اقوم بوضع يو بي اس خاص لكل ادارة ام يكون هناك يو بي اس مركزي للمبنى ويتم تجميع احمال كل طابق بلوحة توزيع ومنها الى اليو بي اس المركزي ام انه يتم وضع يو بي اس خاص لكل جهاز حاسوب
    2-وكذلك كيف يمكن ربط الانارة لتشتغل في حاله الطوارئ ( انقطاع التيار )
    3- ايها افضل من الناحية الفنية والاقتصادية استخدام اليو بي اس ام المولد الكهربائي
    ارجو المساعدة وجزاكم الله خير
    moon04
    moon04 غير متواجد حالياً
    الاستاذ المهندس محمد :
    انت قلت ان جهاز ال ups يتكون من شـاحن بطاريات (A/C to DC converter ) وهو يقوم بشحن البطاريات + تغذية الـمولد الآستاتيكى للكهرباء (Inverter). والذى يقوم بتحويل الجهد المستمر للبطاريات الى جهد متردد مره أخرى ومن ثم تغذية الحمل.
    هل من الممكن تزويدي بمخطط الـمولد الآستاتيكى للكهرباء (Inverter) في اسرع وقت لاني هذة الدائرة هي مشروعي لهذا الترم واريد تسليمها في 20/6
    محمد_شحاته
    محمد_شحاته غير متواجد حالياً
    مصدر الطاقة الكهربائية الغير قابلللانقطاع
    في أثناء التشغيل العادي (أي في وجود جهد متغير وأثناءالتغذية العادية للأحمال) يتم تخزين الطاقة داخل البطاريات يتم شحنها بواسطة شاحنيحول الجهد المتردد إلى جهد مستمر converterوعند انقطاعالتيار المتردد يكون هناك inverter يحول الجهدالمستمر الى جهد متغير والذي يستخدم في تغذية الأحمال
    هناك ثلاث انواعمن الــ UPSيمكن أن نتعرف عليهماكالتالي :
    النوع
    الاولوهوOff line-Standby UPS
    يعمل هذا النوع
    كجسر للطاقة الكهربائية حيث انه يقوم بتزويد الحملالكهربائيبالطاقةمن مصدر الكهرباء
    المتغيرAC voltage بشكل مباشروفينفسالوقت يتم شحن البطاريات ولكن في حالة انقطعتالكهرباء منالمصدر , يقومالــUPSبتغذيه الحٍمل منالبطارياتخلال الـ inverterفي وقت لا يتجاوز 5 مليثانيةأو اقلأحيانا
    النوع الثانيوهوOff line-interactive UPS
    وهو مثل النوع الاول تغذيةالاحمال بالجهد المتغير وفي نفس الوقت شحن البطاريات إضافة إلى منظم للجهد سواء عنطريق محول بنقاط متغيرة أو عن طريق دائرة تنظيم اليكترونية
    النوع الثالث هوOn line-Continuous UPS
    وظيفةهذاالنوع هو تغذيه الحمل بشكل مباشر منالبطارية الموجودة داخل الـUPS وليس منمصدرالطاقة كما في النوع السابق , وفي نفسالوقت يتم شحنالبطارية الداخلية منمصدرالكهرباء حيث أنها تظل جاهزة للعمل في أيوقت
    ويتم الاستفادة منه في المناطق التيتنقطع فيها الكهرباء بشكل متكرر , أوفي المناطق الصناعيةالتي تكون الأحمال فيهاكبيرة ومتغيرة وفى أوقاتمختلفةأمابالنسبة للمستخدم الذي يتعامل مع أحمالحساسة وتتسبب في حدوث مشاكل عند انقطاع التيار عنها مثل أجهزة الكومبيوتر التيتستخدم في مراقبة أنظمة أو عليهابرامج يلزم أن تعملبصورة مستمرة او أجهزة إنذار أو أجهز الخادم Serversيعتبر هذا الجهاز احدالأجزاءالأساسية التي يجب اقتنائهابجانبالحاسبالآلي .
    تختلف مواصفات وقدرات كل من وحدات الـ UPSحسب الأحمال الموصلة عليهاحيث هناك وحدات كبيرة توصل الى الاحمال الضخمة بالمصانعومحطات توليد الطاقة وتوصل مع غرفة البطاريات بالمحطات بينما في الاحمال الصغيرةتكون عبارة عن وحدات صغيرة يوجد بداخلها البطارية القابلة للشحن تصاحب الحمل
    هذه بعض المواقع المفيدة في هذا
    المجال
    http://business-directory.brg8.org/c2/business/
    http://www.smps.us/uninterruptible-power-supply.html
    http://www.apcc.com/tools/ups_selector/index.cfm??
    http://carsnology.blogspot.com/2008/10/uninterrupted-power-supply.html
    1 Not allowed!
    راشدة
    راشدة غير متواجد حالياً
    الصورة الرمزية راشدة
    جزاكم الله خيرا على كم المعلومات مهندس محمد وعندى معلومة جهازupsيستخدم فى غرف العمليات
    وسلالالالالالالالالالالالالالام الله عليكم
ups
