خلينا نتشارك افكار مع بعضنا في مشاريع التخرج
صفحة 6 من 10 الأولىالأولى ... 2 3 4 5 67 8 9 10 الأخيرةالأخيرة
النتائج 51 إلى 60 من 95
  1. [51]
    فلسطين والنضال
    فلسطين والنضال غير متواجد حالياً
    الصورة الرمزية فلسطين والنضال
    Portable Network Service Monitor
    This portable network service monitor was developed to help network administrators supervise datacenters. The handy monitor—which features a WIZnet WIZ810MJ module and Atmel ATmega128 microcontroller—is equipped with a 4 × 20 LCD that can display important messages from any configured server in a local network. It also continuously checks connectivity to predefined services on different machines. When problems occur, it triggers an alarm.
    Abstract | Entry
    سوف نقتلهم جميعا وسوف نشرب دمائهم في كاس انتفاضتنا وليكن نخبه الموت لنا ولهم ولتحيا فلسطين
  2. [52]
    فلسطين والنضال
    ThermoNet
    The ThermoNet is a web-based, remote control, residential HVAC thermostat. The well-designed system includes an easy-to-use LCD front panel and a built-in web server. The front panel includes four buttons: Mode, Fan, Up, and Down. The hardware consists of a WIZnet WIZ810MJ module connected to an Atmel ATMega128 microcontroller external memory interface via direct memory mapping. An Atmel DataFlash chip provides ample storage for embedded web pages and is easily updated with new web pages and other files via a Windows-based program.
    Abstract | Entry
  3. [53]
    فلسطين والنضال
    FATE: Flexible Audio Transmission Over Ethernet
    This project addresses the idea of digital audio for the masses. The purpose of flexible audio transmission over Ethernet (FATE) is to set up a simple dedicated wired Ethernet network. You can then use the network to coordinate the distribution of high-quality audio signals throughout a building and the area around it. The useful design uses a full parallel bus interface to a WIZnet W5100 IC. The IC is memory mapped on the “auxiliary bus” (expansion bus) of the processor core. Its register values can be seen and manipulated at any time. Interrupts aren’t used.
    Abstract | Entry
  4. [54]
    فلسطين والنضال
    Web Camera
    The versatile Web Camera system can take a picture at a resolution of 640 × 480 or 320 × 240, pan the camera horizontally and vertically, and change its IP and gateway address to match a network. Photos are taken with a C328 JPEG compression module, which serves as a JPEG-compressed still camera. The host can send a snapshot command to capture a full-resolution, single-frame still picture. The picture is then compressed by the JPEG engine (OV528) and transferred to the host. After each photo is divided in 64-byte segments, a WIZnet WIZ810 Ethernet module transmits the packets over the Internet.
    Abstract | Entry
  5. [55]
    فلسطين والنضال
    Time Server
    The well-designed Time Server keeps a master time and date clock that is synchronized to the U.S. WWVB time-code signal. It exists on the Ethernet network and serves time and date information according to the SNTP, DAYTIME, and TIME protocols. Client devices can connect to the system, request the time/date, and synchronize their local clocks. Because the Time Server doesn’t rely on Internet servers, it can be used in secure networks that aren’t connected to the Internet. A WIZnet W5100 provides the interface to the Ethernet network. A Freescale MC9S08QG8 microcontroller is used to decode the time-code pulse stream, update a real-time clock, and serve time/date information to clients on the Ethernet network.
    Abstract | Entry
  6. [56]
    فلسطين والنضال
    Greener Lawn: A Sprinkler Control System
    The well-made Greener Lawn system gathers historical weather data and forecasts and then makes intelligent watering decisions based on that data. The design features an ATmega128 processor connected to the Internet through a WIZnet WIZ810MJ. The weather forecasting and rainfall totals come from the National Weather Service’s FTP server. Linux shell and Perl scripts gather the data and parse out the rainfall totals. This is stored as plain text files on the Linux web server. A PHP script running on an Apache web server enables you to configure the sprinkler controller. A second PHP script ties all of this information together into a single downloadable file that is requested by the WIZ810MJ.
    Abstract | Entry
  7. [57]
  8. [58]
    فلسطين والنضال
    اتعجب من عدم التفاعل حتى كلمة شكر او نقد مافي على الرغم من ان المشرف جازاه الله الخير ثبته!!!!!
    اخواني انا مقدرتي محدوده ونفسي الكل يشارك بافكار اخرى في تخصصات مختلفة علشان الكل يستفيد وهذا هو هدف المنتدى ويارب توصل رسالتي لكم اخواني وشكرا
  9. [59]
    محمد القني
    محمد القني غير متواجد حالياً
    والله الف شكر يا اخ يتكتب في ميزان حسناتك ان شاء الله
    وتحيا فلسطين و اطفال الحجارة
  10. [60]
    فلسطين والنضال
    شكرا اخي محمد وبارك الله فيك وشكرا على وتحيا فلسطين و اطفال الحجارة
    والله يكثر من امثالك
