عاجل جدا ....الرجاء المساعده في اسرع وقت
النتائج 1 إلى 4 من 4
    بندر البدر
    بندر البدر غير متواجد حالياً
    انا ادرس هندسه مدنيه وعندي اسئله لم اعرف حلها , وهذه هي الاسئله واتمنى المساعده :
    choose the correct word from the list:(client, surveyor, contractors, plasters, carpenters,joiners, workmen,tillers,glaziers, sub-contractors,architect)
    1-)the........receives a commission from the............
    2-)the........measures the plot of land and makes a plan.
    3-)..........bid for the job of constructing the building .
    4-)the work of independent crews known as.........is coordinated by the contractor.
    5-)the...........mix cement ,sand,pebbles,and water to make concrete.
    6-)rough woodwork is done on the house by...........
    7)the woodwork is finished by the..........
    fill in blanks with the following words :
    ( swollen , fine , durable accelerating , preparation , tensile , process , course , density , reinforced , reaction , bind , mix , compressive)
    1). you have to .............. cement paste and aggregates to make concrete .
    2). cement paste is used to .............. the aggregate to make concrete .
    3). cement hardens through a chemical .............. called hydration .
    4) ............... concrete has foreign materials added to it to take a ........... load .
    5) fine sand can be used in the .............. of lightweight concrete .
    6) concrete has a high .......... force .
    7) large aggregates are known as ............ , while small aggregates are called ............ .
    8) concrete is used for construction because it is ............... .
    رزق حجاوي موجود حالياً
    الصورة الرمزية رزق حجاوي
    Received: 4,986
    Given: 1,442
    1-)the... Contractors.....receives a commission from the. Architest.
    2-)the...Surveyor.....measures the plot of land and makes a plan.
    3-)........bid for the job of constructing the building .
    5-)the.......Workmen....mix cement ,sand, pebbles, and water to make concrete.
    6-)rough woodwork is done on the house by....Joiners.......
    7)the woodwork is finished by the...Glaziers.......
    1). you have to ....Mix.......... cement paste and aggregates to make concrete .
    2). cement paste is used to ...Bind........... the aggregate to make concrete .
    3). cement hardens through a chemical ....Reaction.......... called hydration .
    4) Reinforced. concrete has foreign materials added to it to take a ...Tensile.. load .
    5) fine sand can be used in the Preparation of lightweight concrete .
    6) concrete has a high .... Compressive...... force .
    7) large aggregates are known as Course., while small aggregates are called Fine.
    هاني سليمان
    هاني سليمان غير متواجد حالياً
    الصورة الرمزية هاني سليمان
    Received: 16
    اعتقد ان الاسئلة سهلة لو بحث عن اجابة... عليك البحُُُُُُُُُُُُُُُُُُُُُُُُُُثثثثثثثثثثثثثثثثثث
    ماجدان
    ماجدان غير متواجد حالياً
    Received: 99
    Given: 8
    فعلا الأسئله سهله جدا .......... كان مع قليل من البحث كل شىء يبقى تمام
    شكر للمهندس رزق على كل المشاركات عموما
    وإن كنت أرجح ان يتم م.بندر البندر حلها بنفسه بعد البحث فى تلك المواضيع إذ انها فى غاية السهوله
    شكرا للجميع
    سالدان للهندسه والإنشاءات
    ماجدان للهندسه والإنشاءات
    م.أحمد جليدان
