ماهي خدمة smtp في الانترنت او الشبكات بشكل عام
النتائج 1 إلى 5 من 5
    همدان الصبري
    همدان الصبري غير متواجد حالياً
    سوفين
    سوفين غير متواجد حالياً
    Smtp
    SMTP
    Simple Mail Transfer Protocol
    you can say its an Protocols for Email
    SMTP is a relatively simple, text-based protocol, in which one or more recipients of a message are specified (and in most cases verified to exist) along with the message text and possibly other encoded objects. The message is then transferred to a remote server using a procedure of queries and responses between the client and server. Either an end-user's email client, a.k.a. MUA (Mail User Agent), or a relaying server's MTA (Mail Transport Agents) can act as an SMTP client.
    An email client knows the outgoing mail SMTP server from its configuration. A relaying server typically determines which SMTP server to connect to by looking up the MX (Mail eXchange) DNS record for each recipient's domain name (the part of the email address to the right of the at (@) sign). Conformant MTAs (not all) fall back to a simple A record in the case of no MX. Some current mail transfer agents will also use SRV records, a more general form of MX, though these are not widely adopted. (Relaying servers can also be configured to use a smart host.)
    The SMTP client initiates a TCP connection to server's port 25 (unless overridden by configuration). It is quite easy to test an SMTP server using the telnet program (see below).
    SMTP is a "push" protocol that does not allow one to "pull" messages from a remote server on demand. To do this a mail client must use POP3 or IMAP. Another SMTP server can trigger a delivery in SMTP using ETRN.
    يمكن ان نختصر الكلام بالعربي ونقول :
    ان (المراسلات)التي تتم بين جهازي حاسب (سيرفر و عميل)تكون عبر البروتوكول SMTP لارسال البريد الإلكتروني و البروتوكول POP لاستقبال البريد الإلكتروني .
    تحياتي
    همدان الصبري
    اشكرك اخي سوفين على المعلومات المفيدة جزيل الشكر
    محمود سطاس
    محمود سطاس غير متواجد حالياً
    ارجو ان اضيف على الرد السابق
    لأني اعمل في هذا المجال
    ان mail server تستخدم بروتوكولات عديدة و اهمها smtp , pop و حاليا نستخدم imap
    اما ال smtp - pop ف تستخدم في السريفرات المخدمة isp الهيكلية تكون على الشكل التالي بحسب برتوكولات الشبكة المعروف :
    - عند ارسال الرسال او ال***** يستقبها ال smtp ثم يرسلها الى ال pop ليقوم بإرساله الى العنوان او الجهة المطلوبة و يعني مستقبل و مرسل . و هذه الطريقة ضرورية لمراقبة و حماية ال*****ات . و هي فعالة جدا ..
    و تكون البرمجة فيها بلغة برمجة او برنامج يسمى seand mail
    ام الـ imap فتستخدم حاليا في المواقع مثلا :
    ازا كان هنالك موقع لشركة ما و اراد انشاء عدة *****ا بنفس اسم الموقع مثلا
    [email protected]
    [email protected]
    [email protected]
    و هذا بحسب الخطة او ما يسمى host المحجوز للموقع و يختلف من موقع لأخر و تستخدم فيها بما يسمى الان ajax
    ارجو ان تكون معلومة مفيدة و اذا اخطئنا ف ارجو التصحيح و لكم جزيل الشكر
    kaboke
    kaboke غير متواجد حالياً
    الصورة الرمزية kaboke
    Given: 3
    يا مهندسين هل توجد مزايا بين تلك البرتولات تفضلها عن بعض مثلاً ( الحمايه - سرعه توصيل البيانات ) واي برتكول افضلsmtp , pop .stmb
