اخواني اخواتي السلااااااااااام عليكم ارجو مساعدتي
الدكتور طلب مني حل هذا البروجكت وماني عارف ارجو كم سااااااااااااعدوني
Assalamu Alikum All,
As we are reaching the second project in this semester, all teams are expected to present a high quality product design.You are working in a machinery design office. A client asked for the design of a highly compact hoisting drum to be used in Safola maintenance workshop.
Due to space limitations, the speed reducer system is to be embedded inside the drum itself.
The lifting load is 1.5 ton. Meanwhile the lifting speed is 0.25 m/s. The available motor's speed is 1450 rpm.
Compactness is a very important measure according to the client.
Hint:
think about using both internal and external gears as an alternative design.
As a team you are asked to deliver the following:
1st presentation:
-Problem definition
-Generating solutions
-Decision analysis
-Preliminary Calculations
2nd presentation
-Complete System analysis
-1st draft construction drawings
3rd Presentation
-Complete construction Dwgs.
-Complete working Dwgs.
-Cost Analysis
Final Presentation :
- A comprehensive presentation (almost 20 min.) is to be delivered to the client showing complete design procedure and results using the SANDWICH STRUCTURE.
