Autodesk 3ds max 2008 - DVD
النتائج 1 إلى 5 من 5
    أهل الحديث
    أهل الحديث غير متواجد حالياً
    Received: 205
    Given: 261
    Autodesk 3ds Max software is a powerful, integrated 3D modeling, animation, and rendering application. Its easy-to-learn environment enables artists to quickly ramp up for production. 3ds Max is used by film and video artists, game developers, multimedia designers (print and web), design visualization professionals, and 3D enthusiasts to achieve stunning results in less time. 3ds Max is the leader in 3D animation for game development, design visualization, visual effects, and education.
    Autodesk® 3ds Max® software is a powerful, integrated 3D modeling, animation, and rendering application. Its easy-to-learn environment enables artists to quickly ramp up for production. 3ds Max is used by film and video artists, game developers, multimedia designers (print and web), design visualization professionals, and 3D enthusiasts to achieve stunning results in less time. 3ds Max is the leader in 3D animation for game development, design visualization, visual effects, and education.
    Create rich and complex design visualization. Generate realistic characters for a top-selling game. Bring 3D effects to the big screen. Autodesk® 3ds Max® 2008 3D modeling, animation, and rendering software helps design visualization professionals, game developers, and visual effects artists maximize their productivity by streamlining the process of working with complex scenes.
    Key New Features and Enhancements:
    Accelerated Performance
    The integration of new technology into the software’s Adaptive Degradation System improves interactive performance by automatically simplifying scene display to meet a user-defined target frame rate. You control how 3ds Max adjusts scene display—whether the smallest objects are hidden, or distant objects have less detail, etc.—and 3ds Max calculates how best to achieve it. When combined with the new Direct3D® mesh caching that groups objects by materials, the result is that tens of thousands of objects can be just as interactive as ten objects. In addition, loading, arrays, Autodesk® FBX® and OBJ export, and other areas of the software perform significantly faster.
    Scene Explorer Scene Management
    3ds Max 2008 delivers Scene Explorer, a robust new tool that provides you with a hierarchical view of scene data and fast scene analysis, along with editing tools that facilitate working with even the most complex, object-heavy scenes. Scene Explorer gives you the ability to sort, filter, and search a scene by any object type or property (including metadata), with stackable filtering, sorting, and searching criteria. This new tool also enables you to save and store multiple Explorer instances and to link, unlink, rename, hide, freeze, and delete objects, regardless of what objects are currently selected in the scene. You can also configure columns to display and edit any object property, and because this feature is scriptable and SDK extendable, you can use callbacks to add custom column definitions.
    Review
    This powerful new toolset gives you immediate feedback on various render settings, enabling you to iterate rapidly. This means you can now quickly hone in on your desired look without waiting for a software render—perfect for over-the-shoulder client/boss feedback sessions and other iterative workflows. Based on the latest game engine technology, Review delivers interactive viewport previews of shadows (including self-shadowing and up to 64 lights simultaneously), the 3ds Max sun/sky system, and mental ray® Architectural and Design material settings.
    MAXScript ProEditor
    3ds Max 2008 marks the debut of the new MAXScript ProEditor. This intuitive new interface for working with MAXScript includes multilevel undo functionality; fast, high-quality code colorization; rapid opening of large documents; line number display; regular expressions in search/replace; folding of sections of the script; support for user customization; and many other features.
    Enhanced DWG Import
    3ds Max 2008 delivers faster, more accurate importing of DWG™ files. Significantly improved memory management enables you to import large, complex scenes with multiple objects in considerably less time. Improved support for material assignment and naming, solid object import, and normals management facilitate working with software products such as Revit Architecture 2008. Plus, a new Select Similar feature identifies all objects in an imported DWG scene that contain characteristics similar to those of a selected object. This capability lets you select and edit multiple imported objects simultaneously—dramatically streamlining DWG-based workflows.
    Artist-Friendly Modeling Options
    3ds Max 2008 gives you a more streamlined, artist-friendly modeling workflow through a collection of hands-on modeling options that let you focus more on the creative process. These options include selection previewing and the ability to have existing modeling hotkeys and pivots become temporary overrides.
    Biped Enhancements
    This latest release provides you with new levels of flexibility with regard to your Biped rigs. A new Xtras tool lets you create and animate extraneous Biped features anywhere on your rig (for example, wings or additional facial bones) and save them as BIP files. These files are supported in Mixer and Motion Flow, as well as in Layers, where new layering functionality enables BIP files to be saved as offsets from each layer to isolate character motion. As a result, each layer can be saved as its own asset for export into a game.
    Expanded Platform Support
    3ds Max 2008 is the first full release of the software officially compatible with Microsoft® Windows Vista™ 32-bit and 64-bit operating systems and the Microsoft DirectX® 10 platform.
    3ds Max 2008 includes toolsets for:
    * Modeling and texturing
    * Animation
    * Visual effects
    * Rendering
    * Hair and fur
    * Cloth
    * Asset management and collaboration
    plus
    * 3ds Max API/SDK and MAXScripts
    * Tutorials and documentation
    http://rapidshare.com/files/79189854/Aut3dsMax2008_DVD_D1..by.uman_c.part01.rar.html
    http://rapidshare.com/files/79190838/Aut3dsMax2008_DVD_D1..by.uman_c.part02.rar.html
    http://rapidshare.com/files/79191444/Aut3dsMax2008_DVD_D1..by.uman_c.part03.rar.html
    http://rapidshare.com/files/79191998/Aut3dsMax2008_DVD_D1..by.uman_c.part04.rar.html
    http://rapidshare.com/files/79204905/Aut3dsMax2008_DVD_D1..by.uman_c.part05.rar.html
    http://rapidshare.com/files/79205171/Aut3dsMax2008_DVD_D1..by.uman_c.part06.rar.html
    http://rapidshare.com/files/79206071/Aut3dsMax2008_DVD_D1..by.uman_c.part07.rar.html
    http://rapidshare.com/files/79206478/Aut3dsMax2008_DVD_D1..by.uman_c.part08.rar.html
    http://rapidshare.com/files/79206715/Aut3dsMax2008_DVD_D1..by.uman_c.part09.rar.html
    http://rapidshare.com/files/79206960/Aut3dsMax2008_DVD_D1..by.uman_c.part10.rar.html
    http://rapidshare.com/files/79207132/Aut3dsMax2008_DVD_D1..by.uman_c.part11.rar.html
    http://rapidshare.com/files/79211942/Aut3dsMax2008_DVD_D1..by.uman_c.part12.rar.html
    http://rapidshare.com/files/79213004/Aut3dsMax2008_DVD_D1..by.uman_c.part13.rar.html
    http://rapidshare.com/files/79213364/Aut3dsMax2008_DVD_D1..by.uman_c.part14.rar.html
    http://rapidshare.com/files/79214150/Aut3dsMax2008_DVD_D1..by.uman_c.part15.rar.html
    http://rapidshare.com/files/79215023/Aut3dsMax2008_DVD_D1..by.uman_c.part16.rar.html
    ادور
    ادور غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية ادور
    Given: 5
    مشكوررررررررررررر لك ولك التقدم
    حمدى الديب
    حمدى الديب غير متواجد حالياً
    اين الروابط هى فييييييييييييييييييييييييييييييييييييييييييييييييي ييييييييييييييييين
    دنيا الخشاب
    دنيا الخشاب غير متواجد حالياً
    الصورة الرمزية دنيا الخشاب
    السلام عليكم ور حمة الله وبركاته ... ارجو تزويدي بمشروع تخرج جاهز ومبرمج عن الشبكات الى الايميل التالي
    [email protected] وجعله الله في ميزان حسناتكم واكون شاكره جدا للمنتدى واعضائه الاعزاء
    دنيا الخشاب
    ان امكن ان يكون مشروع التخرج باللغه العربيه بالله عليكم ساعدوني لااني بأمس الحاجه اليه وبالسرعه الممكنه جزاكم الله كل خير
