رسالة دكتوراة-pdf -Environmental effects of multi-stage flash (MSF) desalination plan
النتائج 1 إلى 8 من 8
    الصورة الرمزية drisseto
    drisseto
    drisseto غير متواجد حالياً
    Received: 9
    هاته رسالة دكتوراة من جامعة Newfoundland بكندا. حملت لأخواني الذين يعملون على نفس الموضوع desalination.
    أرجوا أن تنفعكم.
    Environmental effects of multi-stage flash (MSF) desalination plant at Al-Jubail, Saudi Arabia
    by Ahmad, Mansoor, M.Eng.,
    Memorial University of Newfoundland (Canada), 2002, 225 pages
    Abstract (Summary)
    This study presents and compares the marine and atmospheric discharges,
    with an attempt to assess the environmental effects resulting from Al-Jubail
    MSF desalination plant, the largest in the world, producing 253.5 million
    gallons of desalinated water per day. For the analyses of air pollution,
    AERMOD, an air dispersion model, is used to simulate the ambient concentrations of sulfur dioxide,
    oxide of nitrogen, and fine particulate matter. The emission results/pollutant levels were compared
    with the Meteorological and Environmental Protection Agency (MEPA) standards.
    Similarly, for brine discharge, CORMIX a hydrodynamic mixing model is used for
    the prediction of plume dilution. Thermal effects and elevated total dissolved solids concentration in
    brine discharge were also simulated and the results were compared with the U.S. EPA approved Surface Water
    Quality Standards. It has been found in this study that the plume elevated temperature drops to ambient
    temperature within five minutes, traveling a distance of 101.4 meters along the downstream, and the TDS
    concentrations in the brine plume drops to 4700 ppm above the ambient concentration, while traveling a distance
    of 217 meters, downstream, which is 10 percent above the ambient concentration, which shows that both
    the pollutants (elevated temperature and elevated TDS) were within the limits as specified by the Surface
    Water Quality Standards. However, a detailed information regarding the site specific meteorological data,
    fuel and brine characteristics, and plant specific information should be carried out.
    الرابط :
    http://mihd.net/q80ub1k
    http://rapidshare.com/files/10226865...n_S.A.pdf.html
    أهل الحديث
    أهل الحديث غير متواجد حالياً
    Received: 205
    Given: 261
    وعليكم السلام ورحمة الله و بركاته
    جزاك الله تعالى خيرآ ونفع بك
    { الَّذِينَ آتَيْنَاهُمُ الْكِتَابَ يَعْرِفُونَهُ كَمَا يَعْرِفُونَ أَبْنَاءَهُمُ }
    ramzi etaher
    ramzi etaher غير متواجد حالياً
    بارك الله فيك
    مهندس ميكانيكيsqu
    مهندس ميكانيكيsqu غير متواجد حالياً
    شكرا جزيلا لك
    yas-2022
    yas-2022 غير متواجد حالياً
    شكرا جزيلا
    abu mohd
    abu mohd غير متواجد حالياً
    please put the phD theses of MSF in PDF file & send it to all.
    Thank you
    enas2
    enas2 غير متواجد حالياً
    شكرا لك بس ياريت روابط اخري عشان انا محتاجة لموضوع ده جدا
    mkamal6160
    mkamal6160 غير متواجد حالياً
    الصورة الرمزية mkamal6160
    جزاك الله خيرا
    ياريت روابط اخرى مهم بالنسبة الى للغاية
    MKamal
