Help Please you GR
النتائج 1 إلى 2 من 2
    هندسة رابعة
    هندسة رابعة غير متواجد حالياً
    Help Please you GR
    Hi
    I connected the IR Repeater circuit part by part but:
    1) The Led that must be off for testing was on with no input ( Why is that?)
    2) The oscillator has no clear signal on the screan ( I connected it on the 2.2k resistor), but when I point the ir signal at the photodiode as I get closer to it the amplitude became larger.
    3) I know that the function of the photodiode is to convert ir signal to current in order to deal with it in an electronic way rather than electromagnetic way, but , on the hand when I tryed to measure the current that is passing through 3.3k resistor , there was a very small reading (0.006mA) after pointing the ir signal , is that true? or does this indicates that the photodiode does not work properly? How can I test a photodiode?
    Please Answer ASAP, I need to try your suggestions.
    Thanks
    ماجد عباس محمد
    Received: 151
    اقتباس المشاركة الأصلية كتبت بواسطة هندسة رابعة مشاهدة المشاركة
    [LEFT]Hi
    [COLOR=purple]1) The Led that must be off for testing was on with no input ( Why is that?)
    The IC you use is a full function IR chip, this means it is sutable for IR remote control signal, which is a signal on a 38 KHz carrier
    Download the data sheet to understand its operation
    the IC output is 0-5V
    Also It may need a pullup resistor on its putput pin try 47K ohms
    You should connect it between LM555 pin 3 and ground which is the output pin
    if the IR chip has an output, then 555 will oscillate
    This is a chip not an IR diode so you cant measue the IR current , you read the total chip current
