مطلوب تصميم مرسى قوارب بسيط
النتائج 1 إلى 2 من 2
    خالد الغنيم
    خالد الغنيم غير متواجد حالياً
    الرجاء من الاخوة المهندسن التكرم بتزويدي بمخطط تفصيلي ( انشائي + معماري ) لمرسى قوارب بحدود 30 متر + سقالة بحرية
    ولكم جزيل الشكر
    ماجد امان
    ماجد امان غير متواجد حالياً
    Hello, Brother
    for having such a plan, you have to advance your design with some data work, cause the design will depend greatly on it
    first, the position of this port, cause you need to have wind direction estimation in order to start your design safetly from wind effect (sedimentation, offshore problems)
    second, you have to choose the kind of use for this port, the yachts are of what capacity, so that you can get the most reliable depth for the port, which will reflect on the cost of excavation under the water, which is expensive
    third, what's the standard of this port, is it a luxorious or economic port
