كتب لمهندسي القدرة الكهربائية
النتائج 1 إلى 10 من 39
    الصورة الرمزية Haroutuon
    Haroutuon
    Haroutuon غير متواجد حالياً
    عضو فائق التميز
    Haroutuon
    عضو فائق التميز
    Power System Protection: Volumes 1-4
    الرابط هو
    http://rapidshare.com/files/36250946...olumes_1-4.rar
    اسرع في تحميل الكتاب قبل نفاذ صلاحية الرابط
    Haroutuon
    عضو فائق التميز
    Electrical Power Distribution Systems 6th Ed by A. S. Pabla
    Haroutuon
    عضو فائق التميز
    Computer Aided Power System Analysis (Power Engineering, 15)
    محتويات الكتاب
    Table of *******s:
    Series Introduction
    Preface
    1 Introduction 1
    2 Line Constants 11
    3 Power Flow Analysis 27
    4 Short Circuit Studies 49
    5 Transient Stability Analysis 77
    6 Motor Starting Studies 107
    7 Power Factor Correction Studies 131
    8 Harmonic Analysis 149
    9 Flicker Analysis 171
    10 Insulation Coordination 189
    11 Cable Ampacity Analysis 215
    12 Ground Grid Analysis 235
    13 Lightning Surge Analysis 261
    14 EMF Studies 283
    15 Data Acquisition Systems 303
    16 Relay Coordination Studies 319
    App. A Conductor Data 343
    App. B Equipment Preferred Ratings 353
    App. C Equipment Test Voltages 363
    Index 371
    والروابط هي
    http://mihd.net/x0hozm
    http://rapidshare.com/files/49196163/0824706994.rar
    Haroutuon
    عضو فائق التميز
    Power Electronic Control in Electrical Systems
    Haroutuon
    عضو فائق التميز
    Power System Analysis: Short-Circuit Load Flow and Harmonics (Power Engineering)
    محتويات الكتاب
    Table of *******s:
    Series Introduction
    Preface
    1 Short-Circuit Currents and Symmetrical Components 1
    2 Unsymmetrical Fault Calculations 39
    3 Matrix Methods for Network Solutions 72
    4 Current Interruption in AC Networks 116
    5 Application and Ratings of Circuit Breakers and Fuses According to ANSI Standards 145
    6 Short-Circuit of Synchronous and Induction Machines 179
    7 Short-Circuit Calculations According to ANSI Standards 219
    8 Short-Circuit Calculations According to IEC Standards 267
    9 Calculations of Short-Circuit Currents in DC Systems 302
    10 Load Flow Over Power Transmission Lines 328
    11 Load Flow Methods: Part I 360
    12 Load Flow Methods: Part II 391
    13 Reactive Power Flow and Control 435
    14 Three-Phase and Distribution System Load Flow 478
    15 Optimization Techniques 500
    16 Optimal Power Flow 525
    17 Harmonics Generation 554
    18 Effects of Harmonics 597
    19 Harmonic Analysis 619
    20 Harmonic Mitigation and Filters 664
    App. A Matrix Methods 712
    App. B Calculation of Line and Cable Constants 736
    App. C Transformers and Reactors 756
    App. D Sparsity and Optimal Ordering 784
    App. E Fourier Analysis 792
    App. F Limitation of Harmonics 809
    App. G Estimating Line Harmonics 819
    Index 831
    والروابط هي
    http://mihd.net/py7nu9
    http://rapidshare.com/files/49243621/0824707370.rar
    Haroutuon
    عضو فائق التميز
    ABB Electrical Installation Handbook 4th edition
    المحتويات
    Volum 1: Protection and control devices
    This volume deals with the following subjects:
    protection releases and trip curves of ABB circuit-breakers;
    derating tables for circuit-breakers (temperature and altitude);
    co-ordination tables;
    special applications (direct current, 400 Hz and 16 2/3 Hz, 1000 Vdc and 1000 Vac);
    electrical switchboards;
    examples with advanced protection functions.
    Volum 2: Electrical Devices
    protection and dimensioning of feeders;
    protection and switching of lighting circuits, generators, motors and transformers;
    power factor correction - protection and switching of capacitors bank;
    protection of human beings against direct and indirect contacts - distribution systems;
    calculation of short-circuit current;
    harmonics.
    Software: "Curves 1.0" (available exclusively together with the printed version)
    It is an tool dedicated to who works in the electrical engineering field.
    This program can display:
    trip curves;
    specific let-through energy curves;
    limitation curves;
    cable and fuse characteristic curves;
    the discrimination and back-up values which can be obtained by the different combinations of ABB circuit-breakers.
    Besides, thanks to the software "Curves 1.0", it is possible to export the curves and settings of the circuit-breakers
    to any text editor or drawing program
    والروابط هي
    http://search.abb.com/library/ABBLib...&Action=Launch
    يا زمن
    يا زمن غير متواجد حالياً
    الصورة الرمزية يا زمن
    مشكور يا أخو العرب
    سحر فولت
    سحر فولت غير متواجد حالياً
    الراوبط لاتعمل لماذا محتاجه رد حالا
    وليدباسلامه
    وليدباسلامه غير متواجد حالياً
    الصورة الرمزية وليدباسلامه
    ما هي كلمة السر؟؟؟؟؟
