Training Material, Diesel Engine, Heat Exchangers, Pumps, Valves
النتائج 1 إلى 10 من 11
    الصورة الرمزية يحي الحربي
    يحي الحربي
    يحي الحربي غير متواجد حالياً
    عضو فائق التميز
    Received: 16
    The Mechanical Science Handbook was developed to assist nuclear facility operating contractors in providing operators, maintenance personnel, and the technical staff with the necessary fundamentals training to ensure a basic understanding of mechanical components and mechanical science. The handbook includes information on diesel engines, heat exchangers, pumps, valves, and miscellaneous mechanical components. This information will provide personnel with a foundation for understanding the construction and operation of mechanical components that are associated with various DOE nuclear facility operations and maintenance.
    The Mechanical Science handbook consists of five modules that are contained in two volumes. The following is a brief description of the information presented in each module of the handbook.
    Volume 1 of 2
    Module 1 - Diesel Engine Fundamentals
    Provides information covering the basic operating principles of 2-cycle and 4-cycle
    diesel engines. Includes operation of engine governors, fuel ejectors, and typical
    engine protective features.
    Module 2 - Heat Exchangers
    Describes the construction of plate heat exchangers and tube and shell heat
    exchangers. Describes the flow patterns and temperature profiles in parallel flow,
    counter flow, and cross flow heat exchangers.
    Module 3 - Pumps
    Explains the operation of centrifugal and positive displacement pumps. Topics
    include net positive suction head, cavitation, gas binding, and pump characteristic
    curves.
    Volume 2 of 2
    Module 4 - Valves
    Introduces the functions of the basic parts common to most types of valves.
    Provides information on applications of many types of valves. Types of valves
    covered include gate valves, globe valves, ball valves, plug valves, diaphragm
    valves, reducing valves, pinch valves, butterfly valves, needle valves, check valves,
    and safety/relief valves.
    Module 5 - Miscellaneous Mechanical Components
    Provides information on significant mechanical devices that have widespread
    application in nuclear facilities but do not fit into the categories of components
    covered by the other modules. These include cooling towers, air compressors,
    demineralizers, filters, strainers, etc.
    http://mihd.net/yezj4i
    نامل الفائدة والدعاء
    من مواضيع يحي الحربي :
    اللَّهُمَّ أَنْتَ رَبِّي لَا إِلَهَ إِلَّا أَنْتَ
    خَلَقْتَنِي وَأَنَا عَبْدُكَ وَأَنَا عَلَى عَهْدِكَ وَوَعْدِكَ مَا اسْتَطَعْتُ
    أَعُوذُ بِكَ مِنْ شَرِّ مَا صَنَعْتُ
    أَبُوءُ لَكَ بِنِعْمَتِكَ عَلَيَّ وَأَبُوءُ لَكَ بِذَنْبِي
    فَاغْفِرْ لِي فَإِنَّهُ لَا يَغْفِرُ الذُّنُوبَ إِلَّا أَنْتَ
    وليد النور
    وليد النور غير متواجد حالياً
    الله يوفقك ويزيدك من علمه
    م محمد حمدى السيد
    م محمد حمدى السيد غير متواجد حالياً
    thanksssssssssssssssssssssssssssssssssssssssss
    drilling engineer
    drilling engineer غير متواجد حالياً
    الرابط لا يعمل
    مهندس لم يتخرج بعد ~
    bakker
    bakker غير متواجد حالياً
    no such file
    صالح السكيكدي
    صالح السكيكدي غير متواجد حالياً
    الرابط لايعمل
    مصطفى مشرفه
    مصطفى مشرفه غير متواجد حالياً
    الصورة الرمزية مصطفى مشرفه
    Given: 6
    اخي الكريم نرجو اعادة رفع الملف مرة اخرى..وجزاك الله كل خير
    اللهم هب لي نفسا مطمئنه تؤمن بلقائك وترضى بقضائك وتقنع بعطائك
    مصر ستظل ارض العروبه والاسلام رغم انف الحاقدين
    صفدي
    صفدي غير متواجد حالياً
    الصورة الرمزية صفدي
    thanks alot
    upload again please
    لا اله الا انت سبحانك اني كنت من الظالمين
    اسألكم الدعاء لي بظاهر الغيب ان يفرج الله كربتي
    اللهم صلي وسلم على سيدنا محمد وعلى آله وصحبه
    الحفاشي
    الحفاشي غير متواجد حالياً
    الرابط لا يعمل ممكن تعمل رابط في محل آخر
    mohanna34
    mohanna34 غير متواجد حالياً
    يا إخوان اللي عندوة الكتاب يرد يرفعه على الموقع مع الشكر
