كتاب Finite Element Analysis: Theory and Application with ANSYS - S. Moaveni
النتائج 1 إلى 5 من 5
    alizuhair
    alizuhair غير متواجد حالياً
    Author: Saeed Moaveni | Publisher: Prentice Hall | ISBN 0-13-785098-0 | Ed. 1999 | djvu, 527 pages | language: english | 8 MB
    While many good textbooks cover the theory of finite element modeling, this is the only text available that incorporates ANSYS as an integral part of its *******. This book presents the theory of finite element method, explores its application as a design/modelling tool, and explains in detail how to use the ANSYS intelligently and effectively. It shows how to use ANSYS step-by-step to model a physical problem. Each chapter first discusses the relevant basic theory and then demonstrates it using simple problems with hand-calculations. Examples that are solved using ANSYS follow. Various sources of error that can contribute to wrong results are discussed. The design optimization and parametric programming is also included. This book is directed to students and practitioners using ANSYS. (D H Hodges). [/center]
    *******s
    1. Introduction.
    2. Matrix Algebra.
    3. Trusses.
    4. Axial Members, Beams, and Frames.
    5. One-Dimensional Elements.
    6. Analysis of One-Dimensional Problems.
    7. Two-Dimensional Elements.
    8. More ANSYS.
    9. Analysis of Two-Dimensional Heat Transfer Problems.
    10. Analysis of Two-Dimensional Solid Mechanics Problems.
    11. Dynamic Problems.
    12. Analysis of Fluid Mechanic Problems.
    13. Three-Dimensional Elements.
    14. Design and Material Selection.
    15. Design Optimization.
    Appendix A: Mechanical Properties of Some Materials.
    Appendix B: Thermophysical Properties of Some Materials.
    Appendix C: Properties of Common Area Shapes.
    Appendix D: Properties of Structural Steel Shapes.
    Appendix E: Conversion Factors.
    Index.
    http://rapidshare.com/files/39721017/M_FEAT_xyp.rar
    مهندس على أبوالحسن
    مهندس على أبوالحسن غير متواجد حالياً
    الرابط لا يعمل نرجو الإفادة
    grafidustrial
    grafidustrial غير متواجد حالياً
    الصورة الرمزية grafidustrial
    سعد أبو صهيب
    سعد أبو صهيب غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية سعد أبو صهيب
    Received: 8
    Given: 7
    أين الرابط يا علي زهير ؟
    yahia_slah
    yahia_slah غير متواجد حالياً
    الصورة الرمزية yahia_slah
    جزاك الله خيرا ولكن كنا نتمنى منك ان يعمل الرابط
