Question for Civil engineering profissionals
النتائج 1 إلى 5 من 5
    مهندس مثالي
    مهندس مثالي غير متواجد حالياً
    Dear Friends,
    I am a graduate student in Mechanical engineering and I just found out that my intersts located on Structural Engineering. I did may bachelor degree in Saudi Arabia and I think it is time to change to Civil Engineering ( Structural Engineering)Could u please tell me what courses should I take in order to be successful in Structural Engineering.
    I have already planned to take the following courses,
    Finite element method
    vibrations
    mechanical behavior of materials
    Applied Stress analysis
    Engineering Management
    Engineering Mathematics
    design of bridges
    advanced structural steel design
    advanced reinforced concrete design
    structural dynamics
    Structural mechanics
    Structural Connections
    Do you think there are other courses I should learn from bachelor degree?
    Is it necessary to start working with structural programs from now or I will lear while working?
    Should I be profissional in AutoCad before I start working?
    I really appreciate your response since you are really expertise in this major.
    Your respnses are really important to me . Thank you in advance
    aalmasri
    aalmasri غير متواجد حالياً
    عضو تحرير المجلة
    الصورة الرمزية aalmasri
    Received: 10
    Dear friend
    The course list you mentioned is not enough. You will need couple of courses in structural analysis, building construction, material science , engineering economics, foundation design, and couple of LABs.
    AutoCad will help you a lot whether in mechanical engineering or civil engineering.
    You will not be allowed to work in sturctural engineering unless you have a license in that area
    I hope this helps. Don't hesitate to ask about anything if you need to
    Good luck
    مهندس مثالي
    my brother,
    Should I need the license after graduation immediately or after some work experience?
    because I don't think it is hard to take it after 1 to 3 years experience.
    Your response is very helpful. Thank you
    aalmasri
    عضو تحرير المجلة
    Received: 10
    By License I meant university degree. You will not be able to take responsibilities and sign structural documents without that degree.
    مهندس مثالي
    Thank you very much Mr. aalmasri
    I appreciate your answer.
    are there another comments, engineeeers?
