Applied Fluid Technology - Arrow 2.0 with Crack
النتائج 1 إلى 2 من 2
    zeeshan bin zaki
    zeeshan bin zaki غير متواجد حالياً
    AFT Arrow 2.0 for Windows - Compressible Flow Analysis For Pipe Networks.
    Reduce installed cost, increase operating efficiency and do it in less time. Today's demands on the systems engineer leave the traditional methods of compressible flow analysis lacking. Simplifying assumptions and approximations do not yield answers with sufficient precision to assure an efficient and reliable system. The days of compromise are over. With an efficient, easy-to-use interface providing access to a powerful
    compressible flow solver, AFT Arrow provides the systems engineer the capability to model real gases undergoing real processes. Along with its equipment simulation capabilities and extensive output reports, AFT Arrow is uniquely qualified for modeling real compressible flow systems including steam, compressed air, chemical and petrochemical process gases, flare headers including gas mixing, natural gas transport and many more.
    Whether your system is a single flow path or complex network, open or closed loop, AFT Arrow handles it all. With a library of system components from fittings to compressors to control and relief valves, AFT Arrow
    provides the capabilities to optimize a new system design, analyze an existing system for modifications and explore the operating envelope. The optional Chempak thermo-physical property database makes available 600
    gases and non-reacting mixtures as defined pre-mixtures and dynamic flow stream mixtures.
    AFT Arrow's powerful solution engine simultaneously solves the five fundamental equations of flow; mass, momentum, energy, state and Mach
    number. Users may select ideal or real gases, and isothermal, adiabatic or
    generalized heat transfer conditions. An intelligent solver sets a new
    standard in solver robustness and speed by dynamically selecting the
    optimum calculation method based on the solution progress. This analytical power is readily accessible through an interface that assures a short learning curve and high productivity. Models are assembled graphically in a familiar schematic format. Extensive reporting features are user configurable for easy selection of data and units in both tabular and graphical output.
    Building on the confidence of thousands of applications of its predecessor, AFT Arrow 2.0 brings a new level of capabilities and ease of use to compressible flow analysis. AFT Arrow's leading edge flow analysis is
    backed by technical support provided by a team of customer oriented engineers with real world experience who understand your projects. More than software support, AFT provides the pipe flow analysis knowledge that comes with extensive engineering experience.
    http://rapidshare.com/files/6175425/AFT.ARROWv2.0.rar
    30,164 KB
    Password: serbia
    احمدهارون
    احمدهارون غير متواجد حالياً
    السلام عليك اخي
    المرجو رفع البرنامج مجددا لانه به مشكلة وانا في امس الحوجة له
    ولك الشكر وجزاك الله خيرا
    سبحانك اللهم وبحمدك اشهد ان لا اله الا انت استغفرك واتوب اليك
    (اخوتي اكثرو من هذا الدعاء بما له من ثواب)
