ارجوا المساعدة اريد برنامج PipeData-PRO
النتائج 1 إلى 10 من 18
    معاذ قابيل
    معاذ قابيل غير متواجد حالياً
    من مواضيع معاذ قابيل :
    zeeshan bin zaki
    zeeshan bin zaki غير متواجد حالياً
    Thumbs up Link for Pipedata pro
    اقتباس المشاركة الأصلية كتبت بواسطة معاذ قابيل مشاهدة المشاركة
    http://www.pipedata.com/01_pdp/prog/setup7371.exe
    Here is the link for Pipedata Pro 7.3.7.1
    Try it, if it does not work I will send new link Inshallah.
    Inshallah I will send a crack if I can soon.
    Akhoukum fiddeen
    zeeshan bin zaki
    Thumbs up New Link
    http://mihd.net/wusa3j
    Password: Allaho Akbar
    zeeshan bin zaki
    Crack
    I will find a crack for you, if I can, inshallah. I ask other brothers to help.
    وليد_المغيربي_1
    وليد_المغيربي_1 غير متواجد حالياً
    بحثت عن هذا البرنامج لمدة 6 اشهر ولم اجد الكراك
    zeeshan bin zaki
    I made a registry patch at my office for renewing install date for version 7.2 or maybe older. This version does not create the same registry entry for install date. If it had done so, I could have sent the patch.
    You can use it by changing the date of your system to the first install date . If I find a another way I will send you inshallah..
    وليد_المغيربي_1
    This is the version that I was looking for, if you have the patch please link it.
    وليد_المغيربي_1
    Please any crack??
    zeeshan bin zaki
    Arrow How to run pipe-data-pro 7.2 once again
    I am sorry that I am a bit late. Here is the small registry file that you may need to run Pipe-data-pro (30 day Trial) version 7.2 once again.
    Double click on this file and add the registry entries into the registry.
    Download registry file here 127 bytes only.
    http://mihd.net/knpjfc
    Advanced users could change the registry entry for
    themselves using regedit.exe.
    It works with version 7.2 only and not 7.3.
    Version 7.3 requires a license file. If any brother can share license file then please do so.
    If any brother can share version 7.2 then this file will
    work for you Inshallah.
    after 30 days run this file again and ver. 7.2 will work for you as 1st day of trial.
    وليد_المغيربي_1
    Thank you zeeshan bin zaki, but I made the changes you mentiond and nothing happened even when I restart the computer, and this
    my registry file
    http://rapidshare.com/files/90581762/aa.reg.html
    Windows Registry Editor Version 5.00
    [HKEY_CURRENT_USER\Software\VB and VBA Program Settings\PipeData-PRO72\Settings]
    "Size"="78332"
    "MainLeft"="-60"
    "MainTop"="-60"
    "MainWidth"="12000"
    "MainHeight"="9500"
    "aa"=""
