Acanthite-actinolte-adamite-adularia-aegirite
النتائج 1 إلى 10 من 24
    الصورة الرمزية alshangiti
    alshangiti
    alshangiti غير متواجد حالياً
    مشرف وإستشاري هندسة المناجم
    Received: 89
    Given: 8
    ACANTHITE
    Acanthite is a mineral very similar to argentite, differing only in internal structure; the crystal of Acanthite being monoclinic - acanthite can be turned into argentite by heating. Acanthite is an important ore of silver, and forms spiky-looking crystals
    ACTINOLITE
    Actinolite is a mineral that commonly occurs in crystalline schists, often being the chief constituent of green-coloured schists and greenstones. It is used somewhat as an asbestos material. It has the formulae Ca2(Mg,Fe)5Si8O22(OH)2 (the same as nephrite, but being less attractive and harder to cut and polish is less valuable than nephrite) and a relative hardness of 6.
    ADAMITE
    Adamite is a rare mineral with a brilliant fluorescence, it is of scientific interest and is much desired by collectors for its bright colours and general attractiveness, but has no industrial use. It has the formulae Zn2(AsO4)(OH) and a relative hardness of 4. Adamite was discovered by the French mineralogist Gilbert-Joseph Adam at Chanarcillo, Chile during the 19th century, and the mineral was confirmed as a distinct species in 1886 and named after its discoverer.
    ADULARIA
    Adularia (Moonstone) is a semi-precious, clear, transparent, glassy form of potash feldspar which is found mainly in the crevices of crystalline schists and gneisses, often in beautifully perfect crystals. It has sometimes a pearly, opalescent reflection or play of colours. It derives its name from Adula, a mountain peak in Switzerland, where fine specimens are found.
    AEGIRITE
    Aegirite (Aegirine) is a rock-forming mineral of the pyroxenes group, distinguished by it's long needle-like crystals, found mainly in rocks rich in soda and poor in silica. Named after Aegir, Icelandic god of the sea. It has the formulae NaFe(Si2O6) and a relative hardness of 7.
    أبو حمزة السلفي
    أبو حمزة السلفي غير متواجد حالياً
    الصورة الرمزية أبو حمزة السلفي
    Received: 53
    Given: 316
    شكر :
    مشكوور يا أستاذنا الشنقيطي ومزيد من التميز وانا قد قرأت معظم مواضيعك الرائعة والتي إن دلت فإنما تدل على خبرة عميقة في مجال التعدين
    طلب :
    ياريت تعطيني فكرة عن اتزان المنحدرات Slope Stability وتصميم الأنفاق Tunnel Design تحت أي قسم يتبعان (الهندسة المدنية - هندسة المناجم) بوصفك خبير في المناجم السطحية والتحت سطحية
    alshangiti
    Received: 89
    Given: 8
    أخى العزيز اتزان المنحدرات يتبع ل هندسة التعدين فى المناجم السطحية و للهندسة المدنية فى اتزان المنحدرات فى تسوية الجبال لأقامة الطرق والمبانى وكذلك تصميم الأنفاق فى المناجم او ا لأنفاق المدنية المستخدمة فى الطرق او التخزين .
    alshangiti
    Received: 89
    Given: 8
    AS GENERAL SLOPE STABILITY DEFINTION
    The field of slope stability encompasses the analysis of static and dynamic stability of slopes of earth and rock-fill dams, slopes of other types of embankments, excavated slopes, and natural slopes in soil and soft rock.[1]
    As seen in Figure 1, earthen slopes can develop a cut-spherical weakness zone. The probability of this happening can be calculated in advance using a simple 2-D circular analysis package.[2] A primary difficulty with analysis is locating the most-probable slip plane for any given situation.[3] Many landslides have only been analyzed after the fact.
    Slope stability issues can be seen with almost any walk down a ravine in an urban setting. An example is shown in Figure 2, where a river is eroding the toe of a slope, and there is a swimming pool near the top of the slope. If the toe is eroded too far, or the swimming pool begins to leak, the forces driving a slope failure will exceed those resisting failure, and a landslide will develop, possibly quite suddenly.
    NEXT WILL BE SLOPE STABILITY IN OPEN PIT MINING
    alshangiti
    Received: 89
    Given: 8
    Rock Cut Slope Stability:
    Not all rock slopes are conducive to calculations. Some like this one, where the failure mechanism is sliding, can be analyzed using limiting equilibrium analysis.Other slopes, whose failure mechanism is raveling, in not conducive to calculation, and design and remediation must be empirically based.Slopes like this must be remediated or stabilized by removing loose or supporting loose rock. Scaling is usually more cost effective, and can be done manually by mechanized means. Often the quantities of loose rock are not evident until after scaling begins.In some cases the rock must be supported.In many cases it is more cost effective to mitigate damages from slope failures rather that to try and prevent them. Mitigation measures include, draped mesh and catch fences to stop or slow down falling rock and sculpting slope and building ditches large enough to contain the failed material.Viewed from the bigger picture, with a large network of roadways and diminishing budgets, a large number of rock cuts must be analyzed and and remediation efforts need to be prioritized on a RISK basis. In assessing RISK, both we have to consider both the probability of failure and the consequence of failure. Here again empirical formulation and classification can be used to identify cuts with both high probability of failure and serious consequence to life or property. Add to this equation the cost of remediation for each instance and the process of selecting the optimum number and locations of remediation efforts is achieved.
    alshangiti
    Received: 89
    Given: 8
    اليك كل ما تريد عن
    SLOPE DESIGN
    http://www.dur.ac.uk/~des0www4/cal/slopes/
    أبو حمزة السلفي
    Received: 53
    Given: 316
    شكر :
    مشكور يا أستاذنا الشنقطي على هذا الموقع الرائع
    استفسار :
    لو ممكن يا أستاذنا الشنقيطي تعطينا فكرة عن استخدام الإسقاط الإستيريوغرافي Stereographic Projection في تحديد أنواع الإنهيارات المختلفة التي ذكرتها أنت مثل : Plane failure, Wedge failure ,circular failure and toppling failure وياريت لو فيه برامج كمبيوتر لحساب مثل هذه الإنهيارات بالإسقط الإستيريوغرافي
    alshangiti
    Received: 89
    Given: 8
    Regarding Tunneling design:
    There are two reasons to go underground of excavate:
    • To use the excavated space eg. Storage transport etc., (Civil)
    • To use excavated material e.g. Mining operation.
    In both cases tunneling forms an important part of the entire operation.
    In underground construction it is necessary of gain access to the construction site by tunneling, but tunnel can be a purpose in itself. E.g. Road, water cable tunnels etc.
    In mining operation tunnels are used as adits to the mining site and for preparatory works as well as for internal communication.
    Tunnels are driven mainly in horizontal (Decline) or close to horizontal dir3ection but also inclined (incline) from vertically upwards to vertically upwards to vertically downwards.
    Work scale as follows
    - drilling
    - charging
    - blasting
    - ventilation
    - scaling
    - grouting
    - loading & transport
    If you require any detail about the above let me know.
    Best regards,
    أبو حمزة السلفي
    Received: 53
    Given: 316
    شكر :
    مشكور يا أستاذنا على هذه المعلومات القيمة
    تعليقات :
    1- ماذا تقصد بالحفر (Drilling) هل تقصد به حفر ثقوب شحن المتفجرات ؟؟ أم تقصد به
    (Excavation) وهو فتح أو حفر النفق ميكانيكيا (بالآلات) ؟؟
    2- ماهي أهم انواع المتفجرات المستخدمة حالياً (إذ أننا أيام الدراسة كنا ندرس الأنفو AN/FO
    والجيلاتين Gelatine .....وغيرها هل هناك أنواع جديدة مستخدمة حالياً؟
    3- ماهي أهم الآلات المستخدمة في فتح الأنفاق؟؟ قديماً كنا ندرس Road header و TBMs
    بأنواعها المختلفة هل هناك آلات جديدة مستخدمة حالياً؟
    4- أي الطريقتين السابقتين تستخدم أكثر الحفر والتفجير (Drilling&Blasting) أم الحفر بالآلات؟؟
    أم هذا يعتمد على قوة الصخور؟؟؟؟
    5- أنظمة التهوية ؟
    6- ماذا تقصد بالحقن (Grouting) هل المقصود به حقن الأرض بالإسمنت للتثبيت؟ أم المقصود به
    حقن مسامير التثبيت (.......Rock bolts ,Anchors,Dowels) كما درسناها سابقاً؟
    باختصار : كل ماله علاقة بالأنفاق وياريت تكون موضوع موضوع لنتناقش وأستفيد
    alshangiti
    Received: 89
    Given: 8
    ما شاء اللة عليك معلوماتك جيدة مما درستة فى الجامعة
    1- الحفر هو حفر الثقوب لشحنها با المتفجرات لأن عمليات المناجم جميعها تتم بالحفر والتفجير الأ فى مناجم الفحم فتستخدم الالات .
    2- ANFO ما زال يستخدم و emulsion explosives
    -4 -3- فى مناجم الذهب التى اعمل بها نستخدم الحفر والتفجير لشق الأنفاق وما زالت Road header وTBMsتستخدم فى الأ نفاق المدنية
    5- انظمة التهوية كيف تهيء التهوية للعمال فى باطن الأرض على بعد 400 -500 تحت سطح الأرض موضوع طويل يحتاج الى تفصيل .
    6- الأثنان معا
    - حفر الثقوب وتثبيت المسامير با ستخدام ماكينة التثبيت ) swellex)
    سوف اقوم بشرح هذة الخطوات با التفصيل لاحقا ابتداء ب ال DRILLING
