Introduction 2 Instrumentation Page1
النتائج 1 إلى 8 من 8
    awadelrahman
    awadelrahman غير متواجد حالياً
    Instrumentation is a field of study and work centering the measurement and control of physical processes such as: pressure, temperature, flow and so on.
    Instrument is the device that used to measure and/or control the physical quantity.
    Electrical-based instruments are used widely because of the easiness of measuring, manipulating, and transmitting for long distances.
    Signal is a physical quantity that used to convey information; this text for example is a signal to convey information about some instrumentation principles.
    Signals can be classified mainly into two types: analog and digital.
    Analog signals are those types continuously vary to represent any small amount of change. They have a continuous scale. Their resolution is ideally infinite. Typical analog ranges are: 4-20 mA, 0-5 V.
    Digital signals have specified steps to represent a restricted amount of values, the values between scale steps can not be measured. They are mainly used to indicate on-off controls such as valves.
    ? You may have a question about why we used 4-20 mA and not 0-16mA, why do we should complicate the problem!!
    The answer will lead to an important concept in many (and not all) analog instrumentation signal systems, that is: "Live Zero". Suppose a working instrument with 0-16 mA that indicates a level in a tank, then 0mA will indicate an empty tank (0%) and 16mA will indicate a full tank (100%) and any mA between 0 and 16 will indicate its associated % of the liquid amount of tank, you may say: this is perfectly what we want. Now take a fault problem (e.g. a wire cut, transmitter malfunction… etc), of course a 0mA will be measured even if the tank is full 100%. This may mislead the control system and a problem (sometimes a disaster) may happen!!
    So 4-20 mA range is used to distinguish the malfunction from the 0% physical quantity. And this is called: Live Zero to refer to an analog signal scale using a non-zero quantity to represent 0% of real-world measurement.
    • Reference: Lessons in electric circuits, volume-I: DC,
    By R. Kuphaldt.
    بوغريب
    بوغريب غير متواجد حالياً
    مشكوووووور اخوي
    ادور
    ادور غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية ادور
    Given: 5
    رائع جدا علي المقال
    مشكورررررررررر
    awadelrahman
    جزاكم الله خير بوغريب و ادور
    مشكووورين على المرور
    أفضل الناس
    من فك كفيه
    و
    كف فكيه
    فريشمان
    فريشمان غير متواجد حالياً
    بسم الله
    شكرا أخي الكريم
    موضوع رائع:)
    awadelrahman
    شكرا فريشمان
    أفضل الناس
    من فك كفيه
    و
    كف فكيه
    الجناحي
    الجناحي غير متواجد حالياً
    many thanks
    awadelrahman
    شكرا الجناحي
    أفضل الناس
    من فك كفيه
    و
    كف فكيه
